oil temp sending unit mounting?
Old Oct 20, 2006 | 12:02 PM
JasonZ-YA's Avatar
JasonZ-YA
Default oil temp sending unit mounting?
HI,
I did a search and found very little.
IM wondering where might be the best location to install the oil temp sending unit for my oil temp gauge. I have an A-pillar pod set up and need to do the install.
So far im leaning to removing the stock oil pan and welding in a bung off one of the sides?
what are others out there doing? pics if you have them?
thanks,
Jason
Old Oct 20, 2006 | 12:28 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1143
Makes it very simple and gives you a provision for aftermarket oil pressure down the road too
Old Oct 20, 2006 | 12:42 PM
JasonZ-YA's Avatar
JasonZ-YA
Anyone else ? I already have an oil sandwich adapter like that. but it only has inlet and outlet for my oil cooler install. thats the reason im looking for an alternate oil temp sending unit install..
now that i think about it? what about the water temp sending unit? where has anyone been mounting that?
- J
Old Oct 20, 2006 | 10:12 PM
350Zteve's Avatar
350Zteve
I recommend an oil pan spacer like the Jim Wolfe or Altered Atmosphere. Put the sender in the spacer and get more oil capacity to boot.
Old Oct 21, 2006 | 08:13 PM
josesantigo57's Avatar
josesantigo57
Maybe you can make a T on one of your oil cooler lines? :S
Old Dec 13, 2007 | 07:48 AM
JasonZ-YA's Avatar
JasonZ-YA
What if the oil sending unit probe is 1.2 inches in length? i doubt that oil sandwich adapter 1/8 NPT port is that deep.
it seems like the oil pan spacer is the way to go...
- Jason
Old Dec 13, 2007 | 07:59 AM
Z1 Performance
Former Sponsor
I've never seen a temp sensor with 1.2 inches in length...I wouldnt want that hanging out in my block, lest it break off. The gauges we sell mainly (Defi, etc) temp sensors are very small
Old Dec 13, 2007 | 10:36 AM
JasonZ-YA's Avatar
JasonZ-YA
would it be bad sticking in the oil pan spacer? theres nothing for it to hit there?
- j
Old Dec 13, 2007 | 10:40 AM
gothchick's Avatar
gothchick
I've gone back and forth on this as well. I think I'm going to go with the AAM oil pan spacer since it's already tapped for sending units/ oil return lines.
Old Dec 13, 2007 | 10:46 AM
JasonZ-YA's Avatar
JasonZ-YA
ya, i think im gonna end up doing the same? whats the best place to buy one?
- J
Old Dec 13, 2007 | 11:26 AM
gothchick's Avatar
gothchick
Z1Auto & Mynismo have about the same prices. About $150 give or take.
Old Dec 13, 2007 | 11:34 AM
Z1 Performance
Former Sponsor
nope, the pan spacer method works just fine, I'd just be worried about the potential for a sensor that long to break and get kicked around the inside of the block that's all.
let us know if you need either one
Old Dec 13, 2007 | 01:29 PM
bbs350z's Avatar
bbs350z
ive got a greddy pan, ad an oil cooler. any ideas to help me out??
Old Dec 13, 2007 | 02:11 PM
terrasmak's Avatar
are you using all the plugs on your greddy pan?
Old Dec 14, 2007 | 02:15 AM
bbs350z's Avatar
bbs350z
there are 3. 1 for the drainplug, and 1 per turbo. so yes sir, i am
apex locator
Jul 23, 2021 02:27 AM
