Ticking sound from the engine?
Old Nov 14, 2006 | 11:27 AM
jjulich's Avatar
jjulich
Default Ticking sound from the engine?
I have an '06 z with only 3k miles on it and noticed that I have a small ticking sound at idle (once per revolution). Anyone have this problem? I can't hear it above the engine with the hood open, only really on the drivers side.
Old Nov 14, 2006 | 01:36 PM
sisco534's Avatar
sisco534
Yea I have had the same thing always and mine is 03 model, think it is normal just like the loud clutch noise I have to go with it.
Old Nov 14, 2006 | 01:39 PM
pss350z's Avatar
pss350z
edit
Once per rev, isn't that over 15X per sec. how can you hear that as being a ticking? My exhaust makes a ticking sound after a spirited drive.
Old Nov 14, 2006 | 01:58 PM
dingobiatch's Avatar
dingobiatch
If it's a rapid clicking noise that you can only hear at low-medium revs, but the speed increases as you raise the revs, then it might be low oil.
Old Nov 14, 2006 | 06:32 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
sounds like some valve tap to me... nothing that uncommon...
Old Nov 14, 2006 | 06:34 PM
meatbag's Avatar
meatbag
Or injectors clicking.
Old Nov 14, 2006 | 07:10 PM
jjulich's Avatar
jjulich
Yes, but valve tap with only 3k miles? To me, it seems like an exhaust leak since i can only hear it at the driver's side, not on top of the hood. If it was an injector, wouldn't it be coming from the top? There are many clicks per revolution from the top of the engine, which I have heard in every Z. Oil level is fine.
Old Nov 15, 2006 | 08:13 AM
Dave B's Avatar
Dave B
It's the injectors. VQ injectors are very loud. Take a long screw driver and place one end on the injector housing and one end up to your ear. You'll clearly hear the ticking.
Old Jan 13, 2007 | 08:51 AM
jjulich's Avatar
jjulich
Default Injectors the culprit?
What does the injectors sound like? Do they tick maybe 2 times per second? Does it coinside with the regular rotational sound coming fro the engine? This is the sound I am getting. You can hear it when the engine warms up and idles down. Not sure if it's because the RPM or the just the engine is hot that the sound occurs. Took it to a dealship we listened to another 06 Z and it was missing the "extra tap" noise at idle. It may be because the engine wasn't warm yet.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
samansharif
Sep 25, 2015 12:31 PM
