RevUp Oil Consumption TSB and discussion
Old Oct 14, 2007 | 09:09 PM
  #1701
ZeeForce's Avatar
ZeeForce
Originally Posted by antennahead
I should be at the mileage for my first normal oil change (changed out initial oil at about 200 miles) next week (week of the 22nd). I will update at that time. I haven't checked it since 1000 miles and all was fine. Been watching the pressure gauge and it seems better than the V1, good pressure. With the V1 I could tell when I was getting low from the lack of oil pressure.
Thanks, I updated the previous post.
Just curious, what type/brand and weight are you running now, if any change?
Old Oct 15, 2007 | 04:07 AM
  #1702
antennahead's Avatar
antennahead
Still 10w30, Pennzoil. The mechanic that did the swap had previous experience with swaps in the G35. He recommended a switch to 10w40 at the change.
Old Oct 15, 2007 | 01:21 PM
  #1703
Theatrix's Avatar
Theatrix
Professional
Just an update..............3500 on V2.............still NOT burning oil!
Old Oct 15, 2007 | 01:23 PM
  #1704
RBlover69's Avatar
RBlover69
im telling you the revup loves thick oil.
Old Oct 15, 2007 | 03:46 PM
  #1705
luvZcar's Avatar
luvZcar
V2 'installees' update
Known V2 install recipients and their results:
1) Dbasal - maybe not fixed. (no new update as of 10/12/07)
2) Theatrix - 3500 mi looks good... is not consuming
3) RBlover - Success - Done w/Break-in. 4k mi…No OC when running Mobil 1 0w-40 synth w/synth oil filter.
4) 4Shizzil - Success 2k on synth and not a drop, dyno’d at 265-275
5) Zmaximus - still consuming (no new update as of 10/12/07)
6) Antennahead - 4k mi (changed oil at 200 mi) – so far so good - still pending
7) Creationv2 - dont know yet...only 100 miles
8) Hexxum001 - G35 with V2 motor - so far so good (no new update as of 10/12/07)
9) ZMedic16 - Still Pending (no new update as of 10/12/07)
10) ZLOC06 – 1400 mi and some OC - but still pending. (no new update as of 10/12/07)
11) ZPHILE - 45mi on V2 - still pending
12) luvZcar -5000 miles and still consuming ( new v1 under oil consumption test )
13) ZeeForce - 800 miles so far so good - pending break-in (oil changed at 500 miles, still full on dipstick)
14) jkim1978 - 0.5 qt per 1k mi – still pending (no new update as of 10/12/07)
15) pooch15 - still pending
16) neverbonestock – still pending
17) doublins – 1k mi - still pending
18) joe blow xbox – replaced with V1 – still pending
19) Mid117 – replaced with V1 – still pending
20) 9kFever – replaced with V1 – still pending
21) king67rsss – 20 mi – still pending
22) ROGERD – V1 longblock installed - consuming 2 qt per 3k mi
^ Hey guys, is the info current and correct?
If not, please update and repost this list.Thank
Old Oct 15, 2007 | 04:26 PM
  #1706
antennahead
Excellent!!!
Old Oct 15, 2007 | 04:30 PM
  #1707
antennahead
actually, I am at 3000 right now
Old Oct 15, 2007 | 07:42 PM
  #1708
andy2434's Avatar
andy2434
My new engine for my '05 G35 6MT Coupe arrived from Japan, today. Car is going in tomorrow for the swap. I hope this resolves the OC issue.
Old Oct 15, 2007 | 07:45 PM
  #1709
ZeeForce's Avatar
ZeeForce
I am running 5w-30 Castrol GTX dino, so far so good. During my initial OC testing the dealer suggested a heavier weight oil and did change it out to 10w-30 although the results were the same, it burned oil. Once this is all over I probably will run Mobil 1 0w-40 or Amsoil 0w-30 both are synth. I am pleased so far that it is not burning oil with the mfg recommended weight of 5w-30.
Awesome, looks like another success; I will update the V2 list. Thanks!
What oil did you settle on?
I am going to start updating the list with the type/brand oil currently using.
All the folks that had V2 & V1 installed engines please give us an update.
I am sold, and as soon as I hit the 4k mi mark I will probably swap it over. I am still reading the Oil Analysis thread.
Old Oct 15, 2007 | 07:54 PM
  #1710
ZeeForce's Avatar
ZeeForce
Congrats on your V2!
Please do yourself a favor and check the part number on the actual box of the engine. Take the actual part sticker from the box, its peace of mind. Again congrats!
Let us know when install is completed so we can add you to the list.
Old Oct 15, 2007 | 07:57 PM
  #1711
ZeeForce's Avatar
ZeeForce
Updated List
2) Theatrix - 3500 mi ….still NOT burning oil
6) Antennahead - 3k mi (changed oil at 200 mi) – so far so good - still pending
13) ZeeForce - 800 miles so far so good - pending break-in (oil changed at 500 miles with 5w-30 Castrol GTX, still full on dipstick)
Old Oct 15, 2007 | 08:33 PM
  #1712
ZeeForce's Avatar
ZeeForce
Here is a new list of installed V2 & V1 stats.
Let me know if there is any other stats we would like to track.
Please post up your data so I can udate the spreedsheet.
Old Oct 15, 2007 | 09:28 PM
  #1713
creationv2's Avatar
creationv2
im at apprx 2300miles, the first 1700 was weird, so i didnt pay attention to that except break in. at 1700 i had the oil changed(dino oil =(, no synth yet or for a while), and im currently 600miles into it. but since my mileage is still at the minimal stages, nothing i can see yet thats bad =D lets hope it stays that way.
Old Oct 15, 2007 | 09:31 PM
  #1714
creationv2's Avatar
creationv2
7) Creationv2 - 2300miles, nothing odd yet, with the engine at least.
Old Oct 15, 2007 | 09:34 PM
  #1715
creationv2's Avatar
creationv2
if it performs better with thicker oil, why didnt the engineers just opt to put in thicker oil to begin with...
it might work and solve the problem, but im just not so sold on this idea just yet.
Old Oct 15, 2007 | 11:31 PM
  #1716
myZter's Avatar
myZter
PREMIER MEM.FTW
it should also learn to love thin oil
Old Oct 16, 2007 | 02:50 AM
  #1717
markiev37's Avatar
markiev37
My 06 6mt consumes about 1 quart every 2300 miles.. which equate to about 1.5 quarts every 3700 miles. My question is over a long period of time if my consumption does not get any worse what kind of damage if any will occur to my engine and or exhaust system??? I have a lot of mods to remove before taking it in for an OC test that would fall into an "acceptable" OC category.
Old Oct 16, 2007 | 07:03 AM
  #1718
dbasal's Avatar
dbasal
I have not been driving much, but mine is 1qt per 3000 miles. I would label it as a 2 consuming oil for sure. Not nearly as much, but still consistent every 1000 miles.
Old Oct 16, 2007 | 07:07 AM
  #1719
Mid117's Avatar
Mid117
You'll need to de-mod before you bring it in. The dealer will try to blame it on your mods, don't give them any excuses to deny it. Also, be sure to have your maintenance/oil change reciepts.
If not, please update and repost this list.Thanks
Old Oct 16, 2007 | 07:25 AM
  #1720
MasterRacer's Avatar
MasterRacer
Oil consumption problems don't get any better as the car ages. I have
almost same consumption rate as you and I find it very hard to believe
Nissan finds this tolerable or normal. I am not gonna deal with the
whole take my car and replace engine 1 or 2 times, Lemon Law folks.
It's there for a reason, I have contacted an attorney already and I will
let you all know how it goes.
