Mobil 1 Oil Users - Motor oil discussion thread
Old Aug 9, 2010 | 09:21 AM
  #301
2fasst's Avatar
2fasst
Originally Posted by rich2342
Guys were swithching From Mobil 1 to Castrol, why the reverse?
Mobil 1 was shown to somewhat increase wear? Has it been reformulated?
It has been well known that Mobil 1 is NO LONGER a 'true' synthetic, but they market it as such.
Someone posted a question directly to Mobil1, and rather than be straight with the answer, they wouldn't comment, saying the 'formula' is secretive. It's not formula we're asking, but simply asking what is it that we're buying.
While Mobil1 is being secretive, Amsoil and Redline, among others, proudly list their basetocks....PAO, and GroupV, the REAL synthetic basestock!!!
Attached Thumbnails Mobil 1 Oil Users - Motor oil discussion thread-mobil1-crap.jpg   Mobil 1 Oil Users - Motor oil discussion thread-redlineoil.jpg
Old Aug 11, 2010 | 04:41 PM
  #302
geomark's Avatar
geomark
I had always used Mobil1 5W-30 on my Z except for one occasion where I used Royal Purple. Before reading this thread I had just purchased more Mobil1 for my next oil change. After reading this thread and verifying the information, I returned my Mobil1 and purchased 6 qts of Castrol 0W-30 which I found at PepBoys for $7.49/Qt. Interestingly, Autozone did NOT carry it at all, they only had 5W-30 and some 10W.
Would it be safe to top off my Mobil1 with the Castrol? My car is not due for a change for a couple thousand more miles and it may be a bit low.
By the way, I was hoping the oil was green but it was the gold. Doesn't smell like gummi bears but it tastes pretty good Goodbye Mobil 1 Hello Castrol
Old Aug 11, 2010 | 05:53 PM
  #303
NyCSnEaK's Avatar
NyCSnEaK
You will have no issues with topping it off with GC. The Gummi Bear green was the old formula and the gold is the newer formula. I have been using this oil since the first oil change and have had an UOA done that is posted in another thread. It's under Engine & Drivetrain - VQ35HR. Under the sticky section.
Old Aug 11, 2010 | 07:03 PM
  #304
Resolute's Avatar
Resolute
Prove it. Please.
You might start with something better than posting a screen clip of XOM clearly stating that their M1 oil uses PAO base oils, which you claim is a "REAL" synthetic.
Will (also read on the internets that you need backpressure to make good torque)
Old Aug 11, 2010 | 07:08 PM
  #305
Resolute's Avatar
Resolute
Seriously? You mention that you have always used M1 without any issues, but then you read a post on the interwebs that claims M1 is not a "true" synthetic despite what the API says (they regulate what is considered synthetic, btw) and M1's ability to pass a number of high performance manufacturer tests (like Honda's turbo suitability test), and so you go and exchange it for something else only to be worried that you can't mix the two blends? Seriously?
Will (also read on the internets about dynamic compression ratio and how it's important)
Old Aug 11, 2010 | 08:15 PM
  #306
geomark's Avatar
geomark
Thanks. I'll check it out.
Old Aug 13, 2010 | 04:15 AM
  #307
CBRworm's Avatar
CBRworm
Here is a UOA for M1 0-40 that I ran last year. Couple of track days, some trailer towing and some highway. Almost no city driving. M1 doesn't do bad in all VQ's.
Old Aug 13, 2010 | 11:59 AM
  #308
2fasst's Avatar
2fasst
Originally Posted by Resolute
Prove it. Please.
There's nothing to prove, use what you like. M1 is a good oil, but I will continue to use an oil brand that clearly states what base stock they use, ie Amsoil or Redline, Motul, rather than a major brand that touts so many things...but what base stocks they use (ahem..Mobil)
Old Aug 17, 2010 | 01:57 PM
  #309
JdMfREaK's Avatar
JdMfREaK
FLUCKING MOBILE 1 messed me up spun a damn rod bearing bull crap reallyu pissed guess its a good think im at 80k and have 100k warr. now i have to take off all my bolt on and back to stock FML ! FLUCK M1 NEVER AGAIN AMS OIL FOR ME !!! DAMMIT !
Old Aug 17, 2010 | 02:05 PM
  #310
angelo350z's Avatar
angelo350z
Didn't read the whole thread, but has anyone read this:
http://www.bobistheoilguy.com/cms/in...=article&id=83
Basically, thinner synthetic (0-XX) is best according to the author.
Old Aug 17, 2010 | 02:54 PM
  #311
superchargedg's Avatar
superchargedg
Damn Noobs
Long read but a pretty damn good article.
Old Jan 30, 2011 | 01:45 PM
  #312
gerrychuck's Avatar
gerrychuck
Sorry to resurrect an old thread, but there was discussion earlier in it about the availability of the German Castrol 0-30; I wondered if it was available in Canada and discovered that it is in fact available through Canadian Tire and their Partsource subsidiary, at slightly less than the price for Mobil 1, and exactly the same price that they charge for the Castrol 5-30. FYI.
Old Jul 11, 2011 | 07:46 PM
  #313
mattleegee's Avatar
mattleegee
poor guy.... another multi-month bump
oil threads are always so much to lurk around on car forums
