Variable Valve Timing Research
Old Mar 25, 2007 | 07:22 PM
KPierson's Avatar
KPierson
Default Variable Valve Timing Research
I spent Saturday morning on the dyno doing some VVT (variable valve timeing) research. I got about 15 pull in with a mixture of no cam timing, stock cam timing, and 'aggressive' cam timing.
I won't have all the data sorted for a few days, but I definately saw some interesting things. As soon as the dyno owner Emails me the dyno charts I'll be able to compile the data and post some info.
In the mean time, what do you guys think will happen when running aggresive cam timing? How about no cam timing (this was interesting)?
Old Mar 26, 2007 | 06:50 AM
rocks's Avatar
rocks
No cam timing you lose alot of low end.
Old Mar 26, 2007 | 07:25 AM
KPierson's Avatar
KPierson
Thats the exact opposite of what we saw.
With cam timing disabled nothing changed until about 5500RPM or so, then HP slowly trailed off.
Hopefully I'll get the dyno charts today.
Old Mar 26, 2007 | 07:29 AM
chris'smax's Avatar
chris'smax
what were you using to adjust the cam timming? V-manage?
Old Mar 26, 2007 | 10:58 AM
rocks's Avatar
rocks
Strange i remember reading about a guy that used a megasquirt on a vq35de to 240sx swap and using the megasquirt he lost the cam timing and said he lost low end tq and hp. about 20-30hp and tq. Is this a revup?
Old Mar 26, 2007 | 07:04 PM
nismology1's Avatar
nismology1
VTC disabled = full retard = loss of low-end and mid-range.
Period.
How exactly did you disable the cam timing? I've seen evidence that directly contradicts your findings from dyno's to MAF voltage datalogs.
Old Mar 26, 2007 | 07:29 PM
merlin3's Avatar
merlin3
cant wait to see the results kevin, let me know. this guys a wizard when it comes to electronics.
Old Mar 26, 2007 | 07:37 PM
XxKwestxX's Avatar
XxKwestxX
signed up to see the results
Old Mar 27, 2007 | 04:07 AM
KPierson's Avatar
KPierson
Sorry, my info isn't posted on here:
Fully built 2004 G35 Coupe
8.6:1 Arias pistons
Pauter rods
Koyo radiator (350z conversion)
JWT cams
JWT valve springs
APS TT (350z conversion)
UTEC
Duestworks 650cc injectors
Custom 1 of 1 front fascia for APS FMIC
APS test pipes
APS dual exhaust (350z conversion)
KPtechnolgies stealth shift light (blue for now, white soon)
Crawford cast plenum
Custom return fuel system
Walbro 255lph fuel pump
Samco hoses
ARP stud kit
KPtechnologies OEM window up module
KPtechnologies remote sunroof module
KPtech Nav 'OK' bypass
KPtech auto lock with speed switch
KPtech Fog light switch integrator
I interuppted the ECU control signals and used my own signals to control the cam position with a custom setup that I made myself.
Old Mar 29, 2007 | 03:46 PM
KPierson's Avatar
KPierson
Sorry for the delay, I have three logs for each run, and 14 pulls. I found some misleading numbers in my Cypher logs and I wanted to research them. I thought that the cam angle had been read wrong by Cypher, but it turns out that the cam timing wasn't being modified the way I had thought. I could go 'full advance' but I wasn't controlling the retard like I should have been.
I've fixed the problem (for the most part) and have a bit more testing to do before strapping it to the dyno again. Should hopefully be within the next 2 weeks.
Old Mar 29, 2007 | 04:06 PM
nismology1's Avatar
nismology1
I seriously doubt there will be any surprises here.
Old Mar 29, 2007 | 04:14 PM
merlin3's Avatar
merlin3
[QUOTE=KPierson] I could go 'full advance' but I wasn't controlling the retard like I should have been.
QUOTE]
glad you finally figured out how to control your retard lol
Obadabot
Jun 18, 2023 11:31 PM
