HELP!! Complete loss of power!
Old Apr 25, 2007 | 07:21 PM
gabez33's Avatar
gabez33
Default HELP!! Complete loss of power!
I was on my way to the store when I decided to drive a little aggressive, I was in 4th gear and about 4000rpm's and then the car just completely shut down. Not turned off, but NO POWER. I gave it gas and nothing would happen. The rpm's didnt go up and the car didnt accelerate. The SES light came on and the slip and TC lights are on also. Not even in neutral would the rpm move normally, it took a while to get them up. I turned the car off for about 10mins and started her back up again, everything worked fine, but the SES light is now continuously. I drove around a little and it all happen again! Anyone know what this could be?!? Any help would be greatly appreciated!
Old Apr 25, 2007 | 07:31 PM
Sean's Avatar
Sean
recent mods? wheels? anything...
Old Apr 25, 2007 | 07:34 PM
gabez33's Avatar
gabez33
No mods, my car is bone stock, and my warranty is out! Am scared to take it to the dealership!
Old Apr 25, 2007 | 07:35 PM
chuquison's Avatar
chuquison
that happend to me, its on safe mode take it to the dealership
Old Apr 25, 2007 | 07:53 PM
gabez33's Avatar
gabez33
Is there any reason why it would just go to safe mode for no reason?!?
Old Apr 25, 2007 | 09:23 PM
Bevo's Avatar
Bevo
You can try unplug the battery and pump the brakes, see if it helps
Old Apr 25, 2007 | 09:51 PM
tourinz's Avatar
tourinz
it has hapened to me as well.. i work at a dealership and i was on my way to work when it happened.... i had shut de veh off and there was no codes stored on the ecu.... if you seen forza motorsports, the 350z had the same problem on the race.....
Old Apr 25, 2007 | 11:00 PM
black06z's Avatar
black06z
damn, that's pretty scary. I hope you get it fixed.
Old Apr 26, 2007 | 05:30 AM
g356gear's Avatar
g356gear
Limp mode.
Old Apr 26, 2007 | 05:33 AM
VicPham's Avatar
VicPham
Lifetime Member
possible bad fuel??? your car is going into safe mode for a reason. So your car will be alright.
Old Apr 26, 2007 | 05:34 AM
drap660's Avatar
drap660
Its called limp mode... unplug the negative cable on the battery, pump the brakes and wait 15 minutes... plug the negative back in and the ses light will be gone and car will run fine... This happens some times from a bad sensor read.
Old Apr 26, 2007 | 01:12 PM
gabez33's Avatar
gabez33
you guys are never gonna beleive hat was wrong...U took to the deal and turns out that the gas pedal assembly that gives the drive by wire voltage, was doing an over charge to the ECU...AT LEAST that what I understood! thansk for all the replies!
Old Apr 26, 2007 | 01:19 PM
chriskabobbers's Avatar
chriskabobbers
this happen to me, a COMPLETE loss of power but that was because i upgraded to larger sized tires, i had like a different number on the front and on the back. i had 35's on the front and 30s in the rear and so my slip always came on. it was so ghey. so i got 35's in the rear and it never came on again. good luck let us know what you are going to do
350z82
Oct 1, 2015 06:25 PM
