its that Time
Old May 28, 2007 | 06:02 PM
BojanC350z's Avatar
BojanC350z
Default its that Time
my clutch is almost done for it, and tomorow i was thinking of going into nissan and asking them to check it out.. i have the nissan warenty and the extended one,....just got the Z last year so there shouldnt be a problem for them to do it for free... my car has 22k miles, the z was my first car i learned how to drive stick on it, i dont race it thats not why my clutch is screwd up its just from learning driving and sometimes driving it hard...
any advice what i should say tomorow when i walk in nissan so it dont seem like i just want to come in and get it replaced asap cause i screwd it up i dont want them to give me BS so they try to say i did it from racing or something? i just want them to do their job with no problems
Old May 28, 2007 | 06:19 PM
iknowitsfast's Avatar
iknowitsfast
How did you know your clutch was going bad? Just trying to see if I need to replace mine.
Old May 28, 2007 | 06:20 PM
DavesZ#3's Avatar
DavesZ#3
Good luck. From the Warranty manual that comes with our cars:
MAINTENANCE SERVICE EXPENSE
This warranty does not cover normal maintenance services
as specified in your NISSAN SERVICE & MAINTENANCE
GUIDE such as engine tune-up; cleaning and polishing;
wheel alignment; headlight aiming; replacement of filters,
replacement of windshield wiper inserts, lubricants, coolant;
worn brake shoes, pads, drums and rotors and worn clutch
discs
Old May 28, 2007 | 06:21 PM
BojanC350z's Avatar
BojanC350z
when i try to shift it just grinds sometimes, i know the difference when you miss a shift and it grinds but mine sometimes just grinds going into the gear like your supposed to, and it also makes noise when i shift you can notice it if you know how the car is supposed to work, amaturs probably wouldnt notice it but you can tell its not right
Old May 28, 2007 | 06:24 PM
BojanC350z's Avatar
BojanC350z
discs
i dont think thats right because i heard they should cover it for free if you have a warenty....
anyone else know anything on this?
Old May 28, 2007 | 06:25 PM
DavesZ#3's Avatar
DavesZ#3
Are you have trouble with the transmission (grinding) or the clutch?
Old May 28, 2007 | 06:26 PM
BojanC350z's Avatar
BojanC350z
the clutch, my clutch feels a lot different then the other Z's i sat in which were almsot new, the others felt a lot softer mine is hard when u step on it
Old May 28, 2007 | 06:27 PM
DavesZ#3's Avatar
DavesZ#3
If your clutch fails prematurely, then yes, it would be covered. If it shows signs of excessive wear or abuse, then you'll get the same response that dozens of others here have gotten in the past - "wear and tear" items are not covered.
Old May 28, 2007 | 06:30 PM
BojanC350z's Avatar
BojanC350z
--------- so what do you think i should do
Old May 28, 2007 | 07:07 PM
Blk03G35's Avatar
Blk03G35
Clutch = Not covered
Old May 28, 2007 | 07:18 PM
DJShan209's Avatar
DJShan209
+1 on wear and tear not being covered. You can always try but theres no gurantee.
Old May 28, 2007 | 07:22 PM
Blk03G35's Avatar
Blk03G35
Anyone running a Spec S1?
Old May 28, 2007 | 08:30 PM
roxtarinc's Avatar
roxtarinc
mine has a really stiff feel to it as well....
any tips on how to fix that
Old May 29, 2007 | 05:31 AM
Marino Z's Avatar
Marino Z
Know it all
basic warrenty does not cover the worn clutch
Old May 29, 2007 | 07:38 AM
BojanC350z's Avatar
BojanC350z
i have the extended warenty?
Old May 29, 2007 | 07:54 AM
zeekle's Avatar
zeekle
extended just means it is longer but it doesn't mean it covers more.
If its defective then they will replace it free. If its worn out because you have been riding the clutch then its going to cost you some money
Only way to know is to take it in and see what they say.
Old May 29, 2007 | 01:45 PM
LG_z33's Avatar
LG_z33
If they see even one burn mark on your clutch, they wont cover it under warranty and the labor will be billed to you.
Most dealerships will dismiss the problem as "wear and tear" right off the bat before doing any work to your car.
Old May 29, 2007 | 01:47 PM
LG_z33's Avatar
LG_z33
By the way, the grinding issue almost sounds like its a tranny problem. A slipping clutch will have different symtoms like hesitant engagement even after your foot is off the pedal or your engine will rev but the car wont accelerate (especially in high gear)
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
