Oil PSI at idle
what does your oil PSI idle at?
i think mine was a little under the first mark (30psi) when i first bought the car.
after i did my first oil change to full syn (48k miles), the psi idles around 15-20psi...i checked the dip stick, it was slightly under the high mark...
just wanted to see why it dropped...engine has this very faint shake every so often at red light after its warm..
thanks for any help
thanks for any help
thanks for any help
thanks for any help
are you guys seriouse?
when its kool outside and you start the car it should be above 60psi, when you drive and idle after some time the oil is warmed up it should stay above 30psi and hen you hit the gas you got to get 60psi.... might want to say what kinda oil your using and if you are puting in enough oil
15 psi-ish on both my Z running synthetic mobil1 or castrol synthetic and my cousins Z running regular dino-oil. This is after its completely warmed up though, i.e. after a drive/reaching destination.
im using amsoil, but i think im going to switch to m1 syn next change.
i think its just short a little bit of oil.
will add tomorrow and see.
thx all
The absolute worst case oil pressure is brand new oil with a brand new filter.
As the lighter components in new oil vaporize off then the viscosity increases after a few 100 miles and progressively thickens.
Read your FSM for minimums usually 14 psi on Nissan engines...........why oil coolers are so important, remember oil viscosity is speced at 212F.
Great timing on this thread cuz I was wondering the same thing. I had oil consumption issues with my first engine so I am keeping a very close eye on my oil now with this second engine. When warmed up, my oil pressure gauge is pretty steady at about 21-22psi at idle.
hmm ok i guess then. im adding another 1/4-1/2 qt of oil in.
my oil pressure gauge is dipping down to halfway between 0 and the last mark at idle... When I accelerate it jumps up to 60psi or more depending on the rpms...This is on RP 5W30 after the car has warmed up. I checked the oil level and it seems fine, but now I'm afraid to push the car at all???
My bad. Kept an eye on my oil pressure gauge today on my way to work and I am actually between 25-30psi at idle when warmed up. Let me also mention that I have a hand built engine from Japan (version 2) that replaced my original RevUp VQ that was consuming massive amounts of oil. So hopefully the specs for this VQ are the same as the o.g. VQ.
Anyways, after boosting hard then I'm around 20-17psi.
liqalu04
Jan 2, 2022 12:58 PM
