Extreme Sensitive 'Slip'
Old Nov 26, 2007 | 10:10 PM
tresani's Avatar
tresani
Default Extreme Sensitive 'Slip'
So I have a 2004 350z enthusiast.
My slip light comes on at some odd times. 99% of the time its fine. Ok some specific corners, sometimes, the slip light comes on. The only thing is, it seems like it shouldn't be coming on when it does. As in, I drove a 97m3 for quite some time, it had traction control as well, and it didn't seem to come on as often as it does on my 350z, even though it really doesn't come on all that often in the first place.
So my question stands, have you guys noticed the traction control is more sensitive on a 350z than other cars? Or does it just seem that way to me?
Old Nov 26, 2007 | 10:15 PM
NGZ's Avatar
NGZ
Is the car 100% stock?
Old Nov 26, 2007 | 10:52 PM
jonnylaw's Avatar
jonnylaw
How many miles on your Z? Does you car have the VLSD? What are the conditions of your tires?
Old Nov 27, 2007 | 03:30 AM
DavesZ#3's Avatar
DavesZ#3
The important question is "what size are your tires?" as non-standard stagger is the cause of 99% of VDC/TCS problems.
Old Nov 27, 2007 | 05:04 AM
unkn0wn ryder's Avatar
unkn0wn ryder
Originally Posted by DavesZ#3
The important questions is "what size are you tires?" as non-standard stagger is the cause of 99% of VDC/TCS problems.
i found out thats what my issue is...
Old Nov 27, 2007 | 05:41 AM
350Zenophile's Avatar
350Zenophile
...And what condition are the tires in? also, what's the tire pressure?
Do you see a trend here? We need a lot more info in order to do an internet diagnosis.
Old Nov 27, 2007 | 08:31 AM
tresani's Avatar
tresani
Tires are in very good shape, probably 90% tread left, and pressure is fine.
It has 15,000 miles or so on it.
I will have to go outside and look at the wheels, but they are aftermarket 17inch, GHT or something like that - on the car when I bought it. I thought the wheel size may be a problem, however wouldn't the slip light come on more often than just a couple of places if the wheel size was wrong?
I will look at my car as soon as I can and post the tire/wheel size.
Old Nov 27, 2007 | 08:42 AM
350Zenophile
Cool...will need the tire sizes for the front as well.
Old Nov 27, 2007 | 02:23 PM
tresani's Avatar
tresani
Ok, here we go.
Rears: 275x50x17
Fronts: 225x40x17
Something about those numbers just don't seem right to me, I'm used to staggered rims ... I don't know.
Old Nov 27, 2007 | 03:09 PM
350Zenophile
Jebus! Your car must have like a 70's muscle car rake to it. Stock tire sizes are 225/50/17 front 235/50/17 rear so those tires you have on effectively drop the front 45mm and increase the rear 40mm over stock diameters. That's almost a 3.5" difference!
Ordinarily the concern is when the rear is smaller than the front, since the computer senses slip via the wheel speed sensor. In your case I'd say you probably just have a wicked case of understeer and that huge sidewall in the rear probably gets pretty bouncy and therefore would let go abruptly.
All internet theory, but regardless I'm sure you would experience a world of difference with a nice 18-19" lightweight wheel combo and some summer tires. If cash is tight at least pick up a set of factory wheels and tires in the marketplace section. Good luck.
Oh yeah, if you have pics please post them...
Old Nov 27, 2007 | 03:38 PM
DavesZ#3's Avatar
DavesZ#3
Damn! no wonder you're having problems. The standard stagger is about 3/4", the acceptable range is supposed to be about 1/4 to 3/4". Your is over 3-3/4"
You need about a 275/35/17" for the rear to have a reasonable stagger. As you widen the rear tire, you must shorten the profile to help maintain a proper tire OD.
Old Nov 27, 2007 | 06:24 PM
tresani's Avatar
tresani
I will post pics tommorow - thanks for the info, any other people chiming in would be great. Like I said, I got the car like this ... so yea
Honestly though, it seems to drive fine 99% of the time. And the more I think about it, the times it has come on has been on an angled corner, and there's a good chance that the rear tires did start to let loose a little ...
Old Nov 28, 2007 | 12:47 PM
tresani's Avatar
tresani
The pics Enjoy. Crappy weather out, and not a great camera, sorry!
Old Nov 28, 2007 | 02:57 PM
ted7450's Avatar
ted7450
On a 17" rim, he'll need more a 45 or 50 profile. A 35 profile will be a lot smaller diameter than stock even with a 275 width.
Old Nov 28, 2007 | 03:04 PM
Blooster's Avatar
Blooster
"chime"
I can vouch for tire sizes causing SLIPpage.
Old Nov 28, 2007 | 09:01 PM
tresani's Avatar
tresani
Thanks. Can anyone suggest tire sizes that would work with these rims? I was thinking about getting new ones, but these are kind of growing on me.
Old Nov 29, 2007 | 05:38 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
depends on wheek dimensions, but you might want to go back to OEM 17 inch sizes
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Justin100
Nov 29, 2015 03:58 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
