grinding in gears
Old Jan 21, 2008 | 05:31 AM
cacdeez's Avatar
cacdeez
Default grinding in gears
when i shift fast the gears grind but when i ease it in gear then it doesnt grind. what is the problem? fluids are full and everything else looks right. is the tranny going bad? sometimes at idle theres a rattle. louder that clutch chatter. i have a stage 4 competition clutch installed. please help.
Old Jan 21, 2008 | 07:32 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
What year is ur Z>?
Old Jan 21, 2008 | 07:39 AM
dmroberson's Avatar
dmroberson
I've noticed when I'm WOT and shifting in my Z, that it was difficult to get in and out of gear. Would grind a lot. I fixed it by adding a Weapon-R engine torque damper. Now it shifts smooth, all the time.
Your engine moves laterally, when running. Moves the most, under WOT. This causes your engine to be mis-aligned with your transmission, which can cause grinding when shifting. Adding an engine torque damper will reduce this lateral movement, and may help fix your problem.
Good luck.
Old Jan 24, 2008 | 07:59 AM
cacdeez's Avatar
cacdeez
my car also makes grinding noise sometimes when i ease out of 1st gear. is the tranny going bad?
Old Jan 24, 2008 | 08:02 AM
cacdeez's Avatar
cacdeez
i have an 03 z with single kit turbo (turbonetics) stage 4 clutch (cc) . at idle sometimes it chatters really loud. louder than normal clutch chatter. the grinding of gears bothers me even more. when i ease into first gear it grinds. when i get on it it grinds. what the hell?
Old Jan 24, 2008 | 08:14 AM
psunner's Avatar
psunner
lol...i have the same problem for about 6 months now. This is my second tranny (first one was replaced due to 5th gear grinding) now this one every time i shift into second at high RPMs it grinds and sometimes doesn't even go into second. But, for normal shifting or even around 5k to 6k it is fine. It only grinds when shifting close to redline.
Old Jan 24, 2008 | 08:15 AM
ZKansasZ's Avatar
ZKansasZ
my z grinds 70% of the time...Some time I rev up JUST A LITTLE BIT then put in gear it wouldnt grind....
Old Jan 26, 2008 | 05:12 AM
cacdeez's Avatar
cacdeez
at idle it makes a loud constant rattling noise. soes your z do that? what is that noise?
Old Jan 26, 2008 | 05:16 AM
Kuruma-san's Avatar
Kuruma-san
thats your flywheel
if your grinding all the time=synchros
Old Jan 28, 2008 | 12:18 PM
cacdeez's Avatar
cacdeez
ok, so how do i fix that?
Old Jan 28, 2008 | 01:14 PM
page04Z's Avatar
page04Z
my Z rattles too, i'm pretty sure its the pressure plate, i can hear it shutter when I shut the car off
also it grinds 5th some times too
Old Jan 29, 2008 | 01:45 AM
Kuruma-san's Avatar
Kuruma-san
there is nothing to fix, its normal
Old Jan 29, 2008 | 04:32 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
also would like to add that he had a short shifter in there and i dont recommend that for these cars at all.
the throw in the shifter is so short already, i would never put one in. i have seen sooo many trannys messed up in this car due to that shifter.
Old Jan 29, 2008 | 04:39 AM
JCat's Avatar
JCat
Try this test to see if it is your synchronizers going bad (which is a warranty replacement):
At highway speeds, push the clutch peddle to the floor. Keep it there. Then move the shifter in and out of different gears. If you need to "grind" it into gear, you are a candidate for a tranny replacement.
Old Jan 29, 2008 | 07:26 AM
theking's Avatar
theking
Are you serious? What is your engine attached to the tranny with Bailing wire? JK I'm glad your problem went away but it had little to nothing to do with your ENGINE dampener. The other noise that the OP is hearing is most likely the Throw Out Bearing.
Good luck.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
Bigsyke
Sep 11, 2015 06:19 PM
