Fluctuating Idle with tendency to stall???(video)
Old Mar 27, 2008 | 08:23 AM
350Zforlife's Avatar
350Zforlife
370Zforlife
Default Fluctuating Idle with tendency to stall???(video)
Ok, here the history on my car... I bought car in November from a private seller... car is in great shape..it's 03 with 73k miles...I still have factory warranty from nissan. till dec 08
I was hit on the rear left bumper hence my car spend couple weeks in the body shop for the dent + paint.. after I took the delivery of the car, I noticed that my idle is vibrating...It constantly fluctuating whenever I stopped at a stop/red light....It didn't do it before... I have included a video where you can see how it fluctuates and at around :40 seconds(remaining sec as shown on vid) you can see it almost takes a dive to 500/200 RPM and car is close to stalling itself....Whenever I rev to drive away in first gear, I can feel it... on higher gears is hard to feel because car is accelerating at higher speed... I can feel the vibrations very distinctively during idling......Why this is happening??? Any idea what could be causing this???
I have just read a thread where OP had vibrating Idle with fan starting and he was told to unplug the battery overnight and then 10 sec on off procedure..... should I try that???
Your opinion/idea is highly appreciated..
Old Mar 27, 2008 | 04:23 PM
350Zforlife
370Zforlife
no one?
Old Apr 9, 2010 | 04:24 PM
lenakance4life's Avatar
lenakance4life
I have the same issue with my car... going to take it in tomorrow. Ill let you know whats up if i find out
Old Apr 12, 2010 | 02:20 PM
binder's Avatar
binder
the basic answer, try a idle reset and tps relearn.
Old Apr 14, 2010 | 11:15 PM
350Zforlife
370Zforlife
Thank you. Appreciate your help. But this thread is about 2 years old. I have sold this car, bought a 370Z. I'm sure your findings will help other 350Z owners.
Old Apr 15, 2010 | 07:12 AM
VO...'s Avatar
VO...
Administrator
Can't fault him though. It means he was using the search feature...
Old May 20, 2010 | 03:26 PM
vics350z's Avatar
vics350z
Check your TPS sensor I think you will find it to be dirty or you will need to replace it. And dont unplug your battery never unless you need a charge
Old May 20, 2010 | 03:47 PM
Waiz's Avatar
Waiz
No need to bump 2 year-old threads brocifer...
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
Justin100
Nov 29, 2015 03:58 PM
Darkspy
Sep 7, 2015 09:09 PM
