Need More Help with SWAP!!
Old May 27, 2008 | 12:27 PM
m79kaplan's Avatar
m79kaplan
Default Need More Help with SWAP!!
Ok...i found a VQ35 out of a Z with auto tranny....i have CVT auto with my altima coupe. I know the engine will fit since the 3.5 has the toned down VQ.
My question is ...can i use a Z VQ with FWD and/or what mods will be needed to make it work?
thanks guys
Old May 27, 2008 | 12:36 PM
Z04's Avatar
Z04
but why waste your time and money swapping one 35 for the other? all you have to do is change the way the altima engine breathes (since that is the main restrictor) and you got Z power. a lot cheaper as well. basically what the early G35C group did when it had less hp than the Z. some raised theirs to match what the Z did stock, so i don't see why it can not be done with the altima 3.5
***EDIT** never mind, i see yougot the 2.5 sorry, there is no help for you since i doubt the transmission for a 4 cylinder will mate to the v6 anyway. no reason to waste your money. should have bought the 3.5 instead, it would be a lot cheaper than to go this route
Old May 27, 2008 | 12:58 PM
dkmura's Avatar
dkmura
General & DIY Moderator
While the basic VQ block is much the same, most of the other critical pieces (heads, intake and ancillary systems) are quite different between the FWD and RWD versions. You'll find problems mating up engine, tranny and exhaust mounts and even bigger problems getting the ECU to work properly. Bottom line: unless you have a unlimited budget for what is certain to be BIG BUCKS on a custom install, I wouldn't even start.
It's not that we can't all dream- just don't expect that a precision engineered application can be swapped that easily.
David Muramoto
Editor-in-chief
Nissan Sport Magazine
Old May 27, 2008 | 02:29 PM
sintaxeror's Avatar
sintaxeror
Just go for broke and get yourself a V8.
Old May 27, 2008 | 02:35 PM
Boostd4's Avatar
Boostd4
Seems like you'd actually save money by selling your current car and buying the V6 version...or even the Maxima.
Pun1sh3RZ's Avatar
Pun1sh3RZ
Should not have bought a 2.5 altima coupe when you obviously desire a Z, I have the 2.5 coupe as a DD and love it. Great on gas mileage, etc. you are wasting your time/money looking for a swap imo
edit: Sell your coupe and buy a Z
Old May 27, 2008 | 03:39 PM
Hoooper's Avatar
Hoooper
wrong wrong and wrong. the only real difference in the engine mount locations and the upper intake manifold. the ECU would work the same if it connects to all your BCM and other connectors. the ECU of the 6th gen maxima and the Z is the same, as well as the equivalent altima 3.5 (i think 04-06 but not sure) so there is a chance. but the truth is that you will be able to get a 3.5 FWD for a good price and it will most certainly end up costing you less.
This is all assuming non-revup and non-HR
Old May 27, 2008 | 03:42 PM
saberphx's Avatar
saberphx
Convert to RWD FTW
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
SpartanZ32
Oct 22, 2015 09:36 AM
SharX59
Sep 27, 2015 09:23 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
