Rattling Sound Just Underneathe The Shifter.
Old Sep 29, 2008 | 12:25 PM
Matosman6's Avatar
Matosman6
Question Rattling Sound Just Underneathe The Shifter.
Hey I own a 2008 350z Base Model 6Speed MT. It has only about 2,500 miles on it. Once I drive the car around and it gets warmed up, I hear this rattling sound just underneathe the car, it sounds it's coming just from under the shifter. But when I press the clutch down, the noise tends to fade until I release my foot off the clutch, then the noise comes back. Is anyone having this issue? How can I get this fixed? Is it normal?
Old Sep 29, 2008 | 12:35 PM
Brrcats's Avatar
Brrcats
any mods done to the car. I've found that my nismo shifter has been coming loose lately and has been rattling. I just hand tighten it down and the noise goes away.
Old Sep 29, 2008 | 01:16 PM
VO...'s Avatar
VO...
Administrator
+1
Old Sep 29, 2008 | 01:19 PM
GenPac's Avatar
GenPac
I've got a similar issue though backwards from you... for some reason it makes me think of the pilot/clutch bearing. Haven't had time to get it checked out lately.
in neutral, clutch out noise present. in neutral, clutch in, noise gone.
Old Sep 30, 2008 | 04:18 AM
3fittyBiH's Avatar
3fittyBiH
I think this is normal on the 03-06 models, but I am not sure about the new ones . I think its normal, but you should still check it out
Old Sep 30, 2008 | 06:40 AM
4mula1 Z's Avatar
4mula1 Z
Originally Posted by Matosman6
Hey I own a 2008 350z Base Model 6Speed MT. It has only about 2,500 miles on it. Once I drive the car around and it gets warmed up, I hear this rattling sound just underneath the car, it sounds it's coming just from under the shifter. But when I press the clutch down, the noise tends to fade until I release my foot off the clutch, then the noise comes back. Is anyone having this issue? How can I get this fixed? Is it normal?
Funny that I ran across this post today. I have had an 06 base for almost a year. About 6 months ago, I started hearing this rattling noise from underneath. I just happened to be taking it into the dealer for an oil change. They changed the oil, then drove it to troubleshoot the rattling. Guess what, noise was gone. Now, 6 months later, and due for an oil change again, the noise is back. I'll report back to let you know if changing the oil resolves the rattling again.
Old Sep 30, 2008 | 07:05 AM
importpunisher's Avatar
importpunisher
clutch chatter, maybe?? thats normal
Old Sep 30, 2008 | 07:54 AM
Matosman6's Avatar
Matosman6
Thanks for the info
Old Sep 30, 2008 | 09:47 AM
4mula1 Z's Avatar
4mula1 Z
No, this is no normal sound. And, does not happen all of the time, as it has only happened twice in the year I have had mine. And, as posted earlier, when I changed my oil it stopped the sound last time. I don't know how the others rattling sounds, but I almost want to compare it to the sound of a diesel engine.
Old Sep 30, 2008 | 07:42 PM
JEFFOS69's Avatar
JEFFOS69
I just bought a used 03 today and mine does the same. Sounds like a clutch throw out bearing starting to wear but I am unsure. It has all the symptoms of one.
Old Oct 2, 2008 | 12:10 PM
Escobar's Avatar
Escobar
https://my350z.com/forum/engine-driv...b-rattles.html
Old Oct 2, 2008 | 04:34 PM
yamaguchi07's Avatar
yamaguchi07
i heard if you dont remove the gear **** porbly you will damage the tranny internally. could that be why? because when i picked up my car it didnt have that problem. until one time i twist the **** to remove it. then it start rattling everytime i rev it up abit.
Old Oct 6, 2008 | 07:11 AM
4mula1 Z's Avatar
4mula1 Z
Default Oil Change did it
My car was due for an oil change anyway, and since changing the oil stopped the rattling last time, I wanted to see if it would stop it this time. It did. No more rattling from underneath.
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
samansharif
Sep 25, 2015 12:31 PM
