When to replace the clutch?
Old Nov 25, 2008 | 03:57 PM
queasyrider's Avatar
queasyrider
Default When to replace the clutch?
I have an '04 with 78K. I've noticed my clutch engagement point seems to be getting higher and higher. Also, when starting the car the first time, it moves about a foot when engaging in neutral. Time for a new clutch? What are the telltale signs of a clutch on the way out?
Also, what can I expect to pay for a stock replacement clutch job?
Is there a better aftermarket clutch than Nissan's?
Thanks for any advice.
KennyG.
Old Nov 25, 2008 | 03:59 PM
Spike100's Avatar
Spike100
^^ Very good and thoughtful questions!
...subscribing...
--Spike
Old Nov 25, 2008 | 06:25 PM
Watch one of those "How stuff works" videos, and see how the clutch grabs the flywheel. The clutch has to grab a spinning flywheel, and turn the remainder of the drive train.
Drive 60 MPH.
Accelerate.
Does the engine RPM increase and the car accelerates?
Does the engine RPM increase, but vehicle speed does not? Probably time for a new clutch.
Old Nov 30, 2008 | 01:11 PM
Always happy to help. If you have other questions please do not hesitate to waste my time.
Old Nov 30, 2008 | 01:45 PM
Vengence's Avatar
Vengence
Drive 60 MPH.
Accelerate.
What your describing is actually the clutch spring. Which is different than the synchro mesh which can also go bad. Clutch springs generally go from heavy abuse. Synchro mesh on the other hand makes it harder to engage the gears, you'll get a grinding sound as you put it into gear.
Old Nov 30, 2008 | 05:57 PM
cliffordrican's Avatar
cliffordrican
o0o0o in ya face lol
Old Nov 30, 2008 | 09:53 PM
Nismo1182's Avatar
Nismo1182
If its slips under power its time for a new clutch. Changing engagement points are also a sign of a master or slave cylinder on its way out.
Drive 60 MPH.
Accelerate.
+1
Old Dec 1, 2008 | 03:24 PM
robbiesZ's Avatar
robbiesZ
[QUOTE=Nismo1182;6622484]If its slips under power its time for a new clutch. Changing engagement points are also a sign of a master or slave cylinder on its way out.
+1 next time your on the road at cruising speed 40-45 drop into what is it 3rd to get about 3rpm.. then mash the gas and if you feel like your car just acts saggy or revs then accelerates the clutch is bad. it should be if your driving at like 3-4 rpm and just kit the gas over and over again the car should buck everytime you hit the gas.
and if the clutch gets higher and higher masterslave is probally in order i had to replace my clutch and MS cylinder. (wife was a first time manual driver)
Old Dec 2, 2008 | 09:54 AM
xxbrokkxx's Avatar
xxbrokkxx
[QUOTE=robbiesZ;6625873]
Changing engagement points are not the master and slave cylindar. I replaced mine thinking the same thing and it turned out the pressure plate teeth in the middle were bending.
OP, the clutch disk is i recall like ... 100 or 180 bucks. Pressure plates i dont think are too expenive either.
Old Dec 2, 2008 | 10:23 AM
robbiesZ's Avatar
robbiesZ
thank you for correcting my ignorance didnt mean to mislead... i know i had to replace my master slave cuz the pedal would go straight to the floor and wouldnt turn the car on whatsoever. the pedal is still a little too soft for my liking but it works. my wife has tiny legs so it helps in her case to beable to press it down easily.
Old Dec 2, 2008 | 01:15 PM
xxbrokkxx's Avatar
xxbrokkxx
I'm not correcting you haha, its just after spending 2k for no reason will **** alot of people off including me when that 2k could have went to something to get gains out of. I mean it could be the master or slave its just what was described sounded just like my problem.
Good luck !
07ZEKE
Aug 23, 2021 09:15 PM
350z82
Oct 1, 2015 06:25 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
