What does advancing the timing 2 deg do?
Old Oct 3, 2003 | 08:52 PM
infidsg35's Avatar
infidsg35
Default What does advancing the timing 2 deg do?
Im going to the dealership tomarrow to bump up the idle about 150 Rmps.. Iv seen people have the dealer advance timing 2 deg. What does this do??
Old Oct 3, 2003 | 09:14 PM
webcarconnection's Avatar
webcarconnection
The car respond better... I recommended
Old Oct 3, 2003 | 09:31 PM
infidsg35's Avatar
infidsg35
will it cause any problems with my mods that i have on my car now?? I just Installed the crawford tonight.. What do you mean it respondes better?? Better throttle response???
Old Oct 4, 2003 | 04:28 AM
infidsg35's Avatar
infidsg35
bahh nevermind found my info that i wanted in a search thanx anyways guys..
Sorry for being soo lazy...
Old Oct 4, 2003 | 07:25 AM
spazpilot's Avatar
spazpilot
don't do it. If you plan on running any mods it could make your engine detonate when it starts to get warm outside and if your area only has 91 octane fuel it will hurt the motor. to many negatives for unproven power imo!!!
Old Oct 4, 2003 | 09:19 AM
FLY BY Z's Avatar
FLY BY Z
First of all, it is not unproven power. And B, isn't winter coming? And 3, you should do it. It isn't like it costs anything, and it isn't like you can't do it, listen to the motor, and if it pings going up a hill in warm type weather, get it bumped back down. All they do is plug a little handheld into the dash and puch a couple of buttons. Woop dee do. Try it out man. Don't let anyone make a decision for you except you.
Old Oct 4, 2003 | 09:43 AM
Michael-Dallas's Avatar
Michael-Dallas
IIRC, factory settings are 15 degrees +/- 4 degrees BTDC. Meaning, you should be able to run from 11 degrees BTDC to 19 degrees BTDC.
Here's an excellent article on Pre-Ignition and Detonation; there is info in it on how ignition timing affects it: http://www.streetrodstuff.com/Articl...e_Basics_I.php
Michael.
Old Oct 4, 2003 | 09:57 AM
Eric1h's Avatar
Eric1h
i went to my dealership in Raleigh, NC and they wouldnt do it for me, bastards!! Anyone know of a dealership in NC that would know how to do it.
Old Oct 4, 2003 | 04:29 PM
webcarconnection
Here in PR is always 90+ Temp. I have Headers, TD Exhaust, injen, Cat pipes and Pulley... the car have some Detonation on the dyno but not because of the ign. timing (lean cond.) its was the opposed, to rich on the high rpm's ... I put the Iridium SP and the car feels better than ever
PS here we have 93 gas that I recommend to use always!
Old Oct 4, 2003 | 04:43 PM
Dissolved's Avatar
Dissolved
what effect does this have on the ECU?
Old Oct 4, 2003 | 07:07 PM
spazpilot's Avatar
spazpilot
Pure Tremble
the way to advance the timing on our cars is through a scan tool of some sort that hooks up to our ECU. CJ
Obadabot
Jun 18, 2023 11:31 PM
sherm
Apr 11, 2020 05:21 PM
Cashwin
Oct 1, 2015 06:36 AM
