guys running 13.xx w/o fi
Old Oct 5, 2003 | 06:08 PM
5thgenluder's Avatar
5thgenluder
Default guys running 13.xx w/o fi
For all you guys running 13s without forced induction what mods do you have? What are your times? and what is the best launch technique. Thanks James
Old Oct 5, 2003 | 06:52 PM
zzzya's Avatar
zzzya
To get into the mid to lower upper 13's all one really needs to do is get a set of Drag Radials on the rears so you can really get on the gas for a good launch. There have been many who are hitting upper 13's with bone stock setups. I hit 14.1 with my 5AT stock and plan on getting some Nitto 555R DRs on the rears. I now have a number of other mods as well so it will be fun to see what I will hit. The biggest weakness on the Drag Strip is the tires. Even with my 5AT I could not power brake to get the RPMs up for a good launch because the tires would light up easily.
Old Oct 6, 2003 | 04:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
13.77 @ 101.4 stock, launching at about 2500 rpm's....oh and there was a headwind that day also, my trap was a little down.
Old Oct 6, 2003 | 02:45 PM
edubbzzz's Avatar
edubbzzz
Et 13.810 @ 100.65 mph, 2.040, 5sp AUTOMATIC, Weight 3457, ummm Mods list look below!!!
ON ORDER 75sht Zex kit!!
Old Oct 6, 2003 | 06:47 PM
5thgenluder
how do you launch a 2500 rpm and not spin em thru 2nd
Old Oct 6, 2003 | 10:15 PM
ares's Avatar
ares
Veteran
he's got a solid 60 foot time as well, I can do it on a good track surface, but I dont have stock tires.
I think it depends how much he slips the clutch, but it cant be that much with that 60 foot time.
Old Oct 6, 2003 | 10:27 PM
s9am_me's Avatar
s9am_me
are you guys mostly dumping the clutch then gas it or feathering it a bit?
Old Oct 7, 2003 | 06:10 AM
CarFanatic's Avatar
CarFanatic
13.9 at 101 I launched at around 3000 feathered clutch out.
Injen intake,
Injen Exhaust
and 19" volk gt7's on t1's
Old Oct 7, 2003 | 06:14 AM
mcduck's Avatar
mcduck
The guy with the 2.04 60' time is in an Auto, so no clutch to slip. Probably powerbraking up to 3000rpm or so
This is what I typically do (with VDC off) to cut wheel spin. Usually feather in from 3000 rpm.
Old Oct 7, 2003 | 07:32 AM
BigBadBuford's Avatar
BigBadBuford
My biggest problem I have running the Z is TERRIBLE wheel hop. I usually pull 60' times in the 2.2 second range, and I have tried many different ways of launching the car. The only way I can get the car out of the hole without getting wheel hop is really slipping out the clutch which works OK, but is terrible for the clutch. Even on the street the car will get real bad wheel hop if launched agressively. Does everyone have this problem? I am running the stock tires and have varied the pressure from 25-35 psi. I'm starting to think there is something wrong with how violent the car is on the launch.
Old Oct 7, 2003 | 07:36 AM
Blue_350Z_Track's Avatar
Blue_350Z_Track
13.715@102... and a 2.0 60' I can't remember every little tenth or hundreth since I don't have the time slip in front of me.(it's at home) Bone stock Track with a K&N drop in.
Old Oct 7, 2003 | 09:46 AM
BlackNissan350z's Avatar
BlackNissan350z
so would a track model perform better than say a performance model with the same mods?
Old Oct 7, 2003 | 02:16 PM
edubbzzz's Avatar
edubbzzz
To answer a couple of comments, umm im not pre-loading at ALL, the light changes i just go from the break to the gas! And im actually not spinning at all, i hold my left foot on the break and then lay my right foot on the gas with NO PRESSURE when the light goes i mash it!!! AND WHEEL HOP can be fixed by lowering the tire pressure in your rear tires, that should solve that problem!
ZEX kit on order!!!
Old Oct 7, 2003 | 02:34 PM
VQ35DES's Avatar
VQ35DES
Some really impressive times here. 13.7s stock! Tell us your secrets and make the 350 look good. Did you take out the spare & jack? How about the tire pressure (front and back)
Oh yeah, sorry for being behind here...What the heck is feathering?
Old Oct 7, 2003 | 03:54 PM
orhanz33's Avatar
orhanz33
13.8@100 (101?i forgot)...i dropped tire pressure to 20psi, took out spare/jack, had 1/4 tank....launched at 1500 (dropped clutch)...like 2.2 60ft. i think...it was pretty cool outside, not cold...i gotta find the timeslip
Old Oct 8, 2003 | 09:55 PM
edubbzzz's Avatar
edubbzzz
IMO, dropping the tire pressure that low hurts us with the Z, i feel we might gain a couple of tenths in you 60FT but you going to loos it TOP END, if you feather out off the line you should be fine, P.S. if anyone is using race fuel (100 octane) dont bother our ECU's go crazy and compensate for it, so its just a waste of money, if anything it might hurt you a bit! I'm running better with a 1/4 tank of 94!
LaterZ,
Erich
Old Oct 10, 2003 | 02:42 PM
5thgenluder
cool went to the track the other day and ran a 14.104 @ 100.01 mph bone stock not bad in my opinion.
Old Oct 10, 2003 | 10:36 PM
edubbzzz's Avatar
edubbzzz
Default UPDATE!!!
Went to the track tonight! This was my best run!! No different mods from last time just gettin better launches, and the car felt better!!
CONDITIONS 66 dgrees
84% Relative Humidity
Results
R/t .056
60' 2.052
330 5.800
1/8 8.877
MPH 80.05
1000' 11.509
1/4 13.725
MPH 101.54
AUTO BABY!!
Next mod UR pulleys!!
LaterZ,
Erich
Obadabot
Jun 18, 2023 11:31 PM
35reilly
Sep 28, 2015 07:42 AM
