running lean
Old Aug 27, 2009 | 12:53 PM
  #81
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by str8dum1
thnx, but i'm not anywhere in the US or even near it...
i'm actually at the other part of the world
Old Aug 28, 2009 | 10:10 AM
  #82
maXmood's Avatar
maXmood
Under Boost!
got a fast response from Jared.. i didn't expect that.
the good news is, Jared said the number Jay'Z got me is suppose to be the correct number, and even if it isn't, he will be able to correct that through emails and all.
i placed an order this morning for Osiris. and looking forward to it.
Old Aug 28, 2009 | 10:30 AM
  #83
03threefiftyz's Avatar
03threefiftyz
congrats
Old Aug 28, 2009 | 10:49 AM
  #84
maXmood's Avatar
maXmood
Under Boost!
^thnx..
and btw, exhaust and HFC are installed.. tho i'm annoyed with the noise i get at about 1.7k and 2.4k rpm..
on a side note, shifting has changed a bit. it usually shifts a little faster when it was stock.
Old Aug 28, 2009 | 10:52 AM
  #85
03threefiftyz
Auto?
Old Aug 28, 2009 | 11:18 AM
  #86
maXmood's Avatar
maXmood
Under Boost!
yeah..
Old Aug 28, 2009 | 11:23 AM
  #87
03threefiftyz
Along with the logs you send to uprev for the etune it might be beneficial to make a pull or two on the dyno and submit them with the info. Allows for timing adjustments on top of fuel modification.
Old Aug 28, 2009 | 11:30 AM
  #88
maXmood's Avatar
maXmood
Under Boost!
hmm... i'll have to see about that. a single dyno run costs around $150.
timing adjustment can only be done with a dyno run for accurate parameters?
Old Aug 28, 2009 | 11:33 AM
  #89
03threefiftyz
150?!?!?!?!?!? Jeebus.........
Yeah, it is only safe to play with the timing via looking at the dyno.
Old Aug 28, 2009 | 11:40 AM
  #90
maXmood's Avatar
maXmood
Under Boost!
yea, ridiculously expensive.! i heard in the US it's about 150 for an hour on the dyno, is that true?
well, i think uprev gives 5 maps with osiris (which includes refining the tune "if i'm not mistaken"). so, i'll just do that later once i get enough money to get it dyno'ed.
Old Aug 28, 2009 | 11:43 AM
  #91
03threefiftyz
Depends, but that is about average for an hour. I think you get 3 tunes but I could be wrong. You could just use the first two to get the fuel right and then on the last one send a dyno sheet with it for some timing adjustments.
Old Aug 28, 2009 | 11:48 AM
  #92
maXmood's Avatar
maXmood
Under Boost!
i'll probs do that.. thnx for the advice.
Old Aug 28, 2009 | 03:16 PM
  #93
Chef-J's Avatar
Chef-J
Booooosstt!!
Good! Welcome to osiris team. lol!
Old Aug 28, 2009 | 03:32 PM
  #94
maXmood's Avatar
maXmood
Under Boost!
hahaha thanks. . now i'll have to start learning how to tune.
Old Aug 28, 2009 | 03:51 PM
  #95
03threefiftyz
Did you buy the tuner version or standard?
Old Aug 28, 2009 | 04:00 PM
  #96
maXmood's Avatar
maXmood
Under Boost!
standard as of now.. and once i know a little bit about tuning, i'll upgrade to the tuner version to play with the ecu.
apex locator
Jul 23, 2021 02:27 AM
