Port Polishing good or bad?
Old Oct 6, 2003 | 10:28 PM
KhanMan's Avatar
KhanMan
Default Port Polishing good or bad?
Ok I was watching Horsepower TV the other day and they were talking about that if the cylinder gets more air it will equal to more hp and imporved mpg and you would do that by getting the engines ports polished. Now I want to know if some one polishes their ports on their VQ engine would that helping in making more hp or not?
Old Oct 7, 2003 | 12:38 AM
teh215's Avatar
teh215
Port and polishing should be done using a flowbench to make certain what you are doing is actually increasing the c.f.m. of airflow otherwise you are just guessing. But yes, it can make a dramatic increase in the airflow through an engine which will relate to a h.p. gain. One thing to keep in mind is that there will be a limitaion to the increases due to port designs and the amount or wall thickness in the heads/intake that is available to be removed.
Old Oct 7, 2003 | 06:15 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Port & Polish will ALWAYS be good.. if you have N.A., then you need to make sure all cylinders are getting similar cfm. If you have force induction, then the bigger the port, the better
Old Oct 7, 2003 | 02:38 PM
VQ35DES's Avatar
VQ35DES
Any drawbacks in doing this? How much would it cost to have a pro do it? This can be done with a bone stock 350?
Old Oct 7, 2003 | 04:40 PM
KhanMan's Avatar
KhanMan
Like VQ35DES how much and where can I get this done in southern Cali? I have a G35 sedan so how much hp should I be expected to gain more the 10hp or less or close to?
Old Oct 7, 2003 | 04:45 PM
jcv's Avatar
jcv
Polishing may help, porting helps more but it maybe at the expense of low and mid-range torque. Got gears
Old Oct 8, 2003 | 08:54 PM
KhanMan's Avatar
KhanMan
how much does it cost?
Old Oct 9, 2003 | 07:50 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Call around, Cali has lots of shops that does it... one come in mind is Extrude Hone. They even have price list on their website.
http://www.extrudehone.com/powerflow.html
Old Oct 10, 2003 | 03:27 PM
KhanMan's Avatar
KhanMan
sounds good. So what is the expected hp gains anyone know?
Old Oct 12, 2003 | 02:06 PM
KhanMan's Avatar
KhanMan
any other place jw because that one had no price.
