Nismo LSD help!
Old Oct 5, 2009 | 10:07 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Nismo LSD help!
Hi guys. I've got a guy selling a virtually new nismo LSD but i've got a few questions.
1. Its a GT LSD Pro, which from my understanding are 1.5 way upgradable to 2 way. He is telling me that it came from factory already as a 2 way. Could someone confirm that you can order them as a 2 way straight from nismo? The serial number is 38420-RSZ15-4U
2. I know that the diff came with it's own oil, but it doesn't have it. What oil weight does the nismo LSD use?
3. How are you supposed to adjust the diff. I know there is an adjustment bolt on the drivers side of the diff, but we were trying to play with it a bit but couldn't figure it out. The diff hasn't got any instructions.
Thanks guys!
Old Oct 5, 2009 | 10:06 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Nobody knows? Does anyone know the answers to 1. and 2. at least? Please, it's quite urgent.
Thanks
Old Oct 6, 2009 | 12:09 AM
NismoZ123's Avatar
NismoZ123
Exclamation ....search
You need to do a search for "nismo lsd". I've seen posts with pix and so on.
Old Oct 6, 2009 | 02:53 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Yes, i have searched, and i've read the whole six threads about it. Nothing there.
I've figured out the adjustment issue, but i still need to know the oil weight and the 1.5 way and 2 way issue.
Please help!!!
Old Oct 6, 2009 | 09:28 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Ok, i think i've found it runs on 80W-90. Can anyone confirm this?
Old Oct 6, 2009 | 10:16 AM
Escobar's Avatar
Escobar
correct: http://www.greenline.jp/catalogue/bp...=&name=LSD+Oil
Old Oct 7, 2009 | 02:32 AM
Z_ology's Avatar
Z_ology
1. Its a GT LSD Pro, which from my understanding are 1.5 way upgradable to 2 way. He is telling me that it came from factory already as a 2 way. Could someone confirm that you can order them as a 2 way straight from nismo? The serial number is 38420-RSZ15-4U The units come from Nismo as a 1.5 way. You can restack the diff to make it a 2 way though.
2. I know that the diff came with it's own oil, but it doesn't have it. What oil weight does the nismo LSD use? Motul 90PA works very well to tame some of the popping and clunking that this diff is known for.
3. How are you supposed to adjust the diff. I know there is an adjustment bolt on the drivers side of the diff, but we were trying to play with it a bit but couldn't figure it out. The diff hasn't got any instructions. The side adjustment bolt has 3 positions. 60, 80, and 100 percent lockup settings. When you switch to each position when it is installed in the car will feel like the click that a torque wrench makes. You just turn the adjuster until you feel it pop then that is the next position. They come set at 60.
I hope that this helps
Old Oct 8, 2009 | 08:30 AM
Citrus's Avatar
Citrus
^^ One correction - the adjustment bolt is for the initial torque, not the lockup %. You can adjust the lock % by restacking the internal clutch plates just like a Cusco LSD.
http://www.ppi-ats.com/LSD/LSD_basics.html
The initial torque (break away torque) is a pre-load torque on a LSD. Up to that torque load, the LSD locks the differential even without any rotational difference between the wheels. The initial torque and the cam angle on the cam rings determine the responsiveness of the LSD on the driver's steering and throttle inputs. The higher the initial torque and the higher the cam angle, the more responsive an LSD becomes. However, too much initial torque makes a vehicle extremely hard to turn and very high cam angle affect the vehicle's smoothness. A good performance LSD achieves an excellent balance of those two important factors.
I posted my DIY install of my Nismo LSD here, shows lots of pictures and how the adjustments are done:
https://my350z.com/forum/engine-driv...tall-pics.html
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
Ganglio
Europe
Sep 26, 2015 07:06 PM
