Noise in the valve tran:((
Old Oct 21, 2009 | 10:31 AM
GT-Z's Avatar
GT-Z
Default Noise in the valve tran:((
I just started hearing something in my valve tran ticking or loose. i dont have rocker arms so what could be causing this.. i have to repl the valve cover gasket so i want to see what to look for while im there.. any ideas of what it could be. its in the top part of the motor. maybe injectors goin out idk u tell me what u think. its a 2004 with 99000 miles doesnt smoke or leak runs and looks like it did off the show room floor.
Old Oct 21, 2009 | 11:23 AM
scotts300's Avatar
scotts300
Happened to me - it was the top of the piston that had blown itself off. It was above the rings, so it still had compression and was not smoking from oil. Check your spark plugs, as the piece that got loose on mine hit the center electrode of the spark plug and shorted it.
Attached Thumbnails Noise in the valve tran:((-oct09-019.jpg
Old Oct 21, 2009 | 11:37 AM
GT-Z's Avatar
GT-Z
WOW.. no i dont think its that, i still have power & idls fine. it just sounds like something lil. friends tell me when the injectors start goin bad thay tick. but i want to be fo sher while im fixing one thing i can fix it then!!!
Old Oct 21, 2009 | 11:39 AM
scotts300's Avatar
scotts300
I still had power and idle was ok until a second piece got loose. It wasn't a "tick" but more like you were gargling glass marbles.
Old Oct 21, 2009 | 11:45 AM
Motormouth's Avatar
Motormouth
the Z commonly has noise from the lash on the buckets. and injectors will tick after being run hard, but goes away after cooling down or what have you.
Old Oct 21, 2009 | 11:47 AM
GT-Z's Avatar
GT-Z
it does it when i start it and never stops.
Old Oct 21, 2009 | 11:48 AM
Nexx's Avatar
Nexx
how loud are the ticks? do the ticks get faster with higher revs?
Old Oct 21, 2009 | 11:58 AM
GT-Z's Avatar
GT-Z
Its not real loud but i know its not normal. And it get just a lil louder when reving it..
Old Oct 21, 2009 | 12:04 PM
Motormouth's Avatar
Motormouth
and you have no codes, and no smells, or hiccups when revving the engine?
Old Oct 21, 2009 | 12:17 PM
GT-Z's Avatar
GT-Z
No codes, smoke or smells nothin. Just noise. Thats what bothers me.
Old Oct 21, 2009 | 12:32 PM
Motormouth's Avatar
Motormouth
I am not by any means an expert, so take what I say as just an opinion, but I would say it's probably just what I mentioned: noise from the cams acting on the buckets. over time the clearances increase so there is a chance to get noise from the tiny point where the drivetrain goes from under tension to free and back.
without hearing it though I am simply hypothesizing.
**** it, take it as an opportunity to throw cams in. why not. (j/k)
Old Oct 21, 2009 | 12:45 PM
GT-Z's Avatar
GT-Z
jk im not. heck why not...lol
Old Oct 21, 2009 | 05:48 PM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Yea, the 300's and 350's tend to make quite a bit of valvetrain noise. Could also be a small exhaust leak, sometimes they sound like lifter ticks. Bust out a mechanic's stethescope and take a listen to the valve cover and the exhaust.
Old Oct 22, 2009 | 04:45 PM
derek173's Avatar
derek173
Step 1. Sell Car.
Step 2. Spend money on spelling and grammar lessons.
Solves most of your problems.
Old Oct 22, 2009 | 04:57 PM
derek173's Avatar
derek173
JESUS!! You even misspelled in the title.
Did you really buy a 6 speed transmission for your automatic car and then ask my350z how to install it? Wow... you really are a rocket scientist.
Old Oct 26, 2009 | 06:21 AM
GT-Z's Avatar
GT-Z
lol... ^ its more than what i wanted to do. last time i looked this wasnt english class bro. anyways i think it may be the timing chain!!!!
Old Oct 26, 2009 | 05:14 PM
Brett@AwesomeZ
If you were having timing chain problems there would likely be other driveability issues going on. Seriously, get a mechanic's stethescope
and check all those problem areas, see where the noise is loudest.
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
