Z overheating...
Old Nov 5, 2009 | 07:54 PM
zcar03's Avatar
zcar03
Default Z overheating...
I have an 03 Z with a procharger 12psi setup. The car will overheat. Sometimes it will be at almost H then go down right away to normal temp, but then it climbs back up. I have a koyo 53mm radiator and slim fans I wired in. The fans are turning on right after the temp is in the middle of the gauge. Both fans work I can see and feel them and hear them. The car eventually hits H and bogs and I shut it down. This gets to H real fast say about 7 min of driving even in cold temps like 40 degrees tonight.
Someone said there may be air in my radiator. Im wondering maybe it is a faulty thermostat. When I squeeze the upper and lower radiator hose it is firm so I know there is antifreeze in both hoses. Think my thermostat is sticking? It is an OEM Tstat. Thanks!!
Old Nov 5, 2009 | 08:04 PM
zcar03's Avatar
zcar03
Also I have no heat!
Old Nov 5, 2009 | 08:53 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Thermostat. If the temperature is going way up, then suddenly dropping, that's when the thermo is opening. Get a new one.
Old Nov 5, 2009 | 08:54 PM
defnowtones's Avatar
defnowtones
same thing happened to mine a couple months back. i removed the radiator cap and turned the car on. all the anitfreeze shot out the top, i am assuming there was air in my radiator. it stopped overheating immediately.
Old Nov 5, 2009 | 08:58 PM
TreeFiddyZee
Do WHAAAAT!?
Sounds like a major belch!
Old Nov 5, 2009 | 10:16 PM
redman333's Avatar
redman333
Air, I had the same problem when i burned thru my radiator hose a couple months back. I filled it back up and it would be fine for a lil while then the temp would shoot up, and I had no heat. Although I would get a little heat when the temp came back down from the tstat opening.
Old Nov 5, 2009 | 10:22 PM
WhiteNoiz's Avatar
WhiteNoiz
I would start by bleeding the system, then a new thermo if needed
Old Nov 6, 2009 | 06:12 AM
redman333's Avatar
redman333
+1 ^ All I had to do was bleed the system and its been fine since.
Old Nov 6, 2009 | 06:19 AM
RandomHer0's Avatar
RandomHer0
Same thing happened to me this summer, burped the system, everything is fine, heat is back.
Old Nov 6, 2009 | 07:10 AM
zcar03's Avatar
zcar03
So whats the best way to bleed the system gonna try sunday afternoon when I have some time. I know where the bleeder screw is buts whats the method. Thanks!!
Old Nov 6, 2009 | 03:53 PM
shiftdrift06's Avatar
shiftdrift06
If you wanna make sure to get all the air out, park on an incline/ have the front side lifted. So all the air bubbles can travel towards the front. Make sure heater is on full blast.
But sounds like a problem with your thermo. Nismo offer one that opens at a lower temp.
Old Nov 6, 2009 | 03:57 PM
RandomHer0's Avatar
RandomHer0
Heres my overheating thread, lots of good info. You don't "need" that funnel to burp the system though...
https://my350z.com/forum/forced-indu...erheating.html
lucidazn
Aug 5, 2006 07:18 PM
maximumsportZ
Jul 6, 2006 04:29 AM
thepostman
Jun 24, 2004 02:56 PM
