oil cooler kits
Old Nov 23, 2009 | 05:45 PM
ironx's Avatar
ironx
Default oil cooler kits
hey im looking for a oil cooler kit with a thermostat in the sandwich i saw a few kits some were at one time but i cant seem to find them any more could some one point me in the right direction .... i search on the forums too and could not come up with any thing any help would be great
Old Nov 24, 2009 | 03:24 AM
DavesZ#3's Avatar
DavesZ#3
I would think being in Saskatchewan you would need an oil warmer, not a cooler.
Stillen sells a oil cooler kit but I don't know if it's thermostatically controlled or not.
Old Nov 24, 2009 | 03:49 PM
Zazz93's Avatar
Zazz93
Hello,
The Stillen Kit is not thermostatically controlled, however it is a good kit to consider. I'm going the Mishimoto cooler and Earls or Jegs thermostat (about + $35) route. I've seen some better units priced up around $100 (Mocal) but couldn't justify the amount knowing that Jegs and Earls are both reputable companys with quality products. For these thermostatic adpaters its simply a switch of the plates to get them on the car. Other nice kits include the Nismo version, but at $700+ it gets pricey.
Old Nov 24, 2009 | 03:53 PM
Zazz93's Avatar
Zazz93
Here's one for reference...http://www.holley.com/503ERL.asp (note this one is not the proper mounting boss size s/b 20mm I believe).
Jegs...http://www.jegs.com/p/JEGS/JEGS-Ther...32937/10002/-1
Old Nov 24, 2009 | 04:02 PM
DavesZ#3's Avatar
DavesZ#3
Check on Amazon, the Mocal thermostatically controlled plate is about $75. Since the OP is in Canada, I'd highly recommend getting the thermostat type plate. That's why I semi-seriously questioned the need for one in the first place. You don't want to oil getting too cold, it needs to be around 200ºF and in his cold environment that could be a problem with a non-thermo. controlled setup.
Old Nov 24, 2009 | 04:28 PM
ironx's Avatar
ironx
that's why i want one with a thermostatic our climate changes so much here one day its really hot next days its mild ..... Ive done a few drag races and been to a few road courses with the car so far and i just want some extra protection just to be safe ......
well the cold environment is sort of true but in summer we get some pretty hot days this summer i saw the z temp gauge in the first pod hit 89 Ive seen it hit 90 in the summer here so it does get hot ... i only drive the car in the summer any ways
thanks for the help so far
Old Nov 24, 2009 | 04:36 PM
DavesZ#3's Avatar
DavesZ#3
I'm currently in the process of putting my own "kit" together. Check out this thread...
https://my350z.com/forum/engine-driv...-pictures.html
It's a great starting point although I'm not using the exact same parts. There's a reference in there to another DIY thread, no pics, but it also has some great background info.
Old Nov 24, 2009 | 07:16 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you're a long way from actually needing an oil cooler IMHO unless it's a dedicated track car
Old Nov 24, 2009 | 10:12 PM
ironx's Avatar
ironx
sweet thanks for the info
Old Nov 24, 2009 | 11:44 PM
CAB350z's Avatar
CAB350z
Unless hes driving in winter the temperatures are the same in canada as they are in most of the normal/middle states
Old Nov 25, 2009 | 03:12 AM
halfass872's Avatar
halfass872
I was curious about that too. If you are FI yet don't track your car, just spirited driving, would this still be a worthwhile addition?
Also (Dumb question) but judging by the sandwich plate, the in and out go to the plate, with no need to tap into the pan right? Does the plate restrict flow to or from the filter at all?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
