Sikky 350z/G35 LSX swap
Old May 12, 2011 | 09:58 PM
  #421
bbs350z's Avatar
bbs350z
Originally Posted by Havok_RLS2
1. JE and Sikky have solved the A/C control issues with the LS swap. IN fact their current project car has full working A/C. I'm thinking about having them do mine this summer.
2. The LS VATS isn't a bypass. I'm pretty sure its turned off in the tuning process. Should be able to turn if off with the HPTuner.
so the sikky wiring service should still control the a/c and heat correct? also starting up the car in stock-ish trim shouldnt be a problem if the VATS is still enabled? im breaking it in on a stock e38 and stock tune before i bring it in to get hp tuned.
Old May 12, 2011 | 10:08 PM
  #422
Havok_RLS2's Avatar
Havok_RLS2
No. I'd expect that A/C control is an extra feature since it didn't come with mine but quote me on that. Another thing to remember is that getting the A/C to work require some custom lines. Best way to know for sure is to call sikky.
The VATS will still be a problem unless its disabled. Depending where you get your drop-out motor and trans sometime they'll disable the VATS for you as a service but not everywhere offers that.
Old May 12, 2011 | 11:14 PM
  #423
bbs350z's Avatar
bbs350z
will i have problems on startup with the vats still enabled?
Old May 12, 2011 | 11:48 PM
  #424
Havok_RLS2's Avatar
Havok_RLS2
If I had to guess I'd say yes. You may need to do some research on how the GM VATS functions. If I remember correctly I think it's ignition key specific.
Updated: Found this on VATS
http://www.fastfieros.com/tech/gm_vats_passkey.htm
Old May 13, 2011 | 04:01 AM
  #425
Cass007's Avatar
Cass007
I spoke with JE Imports yesterday. You mail them the GM ECM and they will disable the vats for ~$200. Tuning is a separate charge on top of that.
When I PMed Sikky I was told that I would need to install a separate on/off switch for the AC. I PMed back asking if the heat/cool and fan speed controls still work and have not received an answer back yet.
I went back and re-read some of the earlier posts and feel somewhat mislead:
SIKKY:
not sure who's saying ac doesn't work, but it most certainly does. Our kit is setup so the factory ls1 or ls2 ac compressor stays in its factory location. Then all you do is buy our ac line kit that comes with two lines, bolt em up, charge the ac system and call it a day. no biggie
I didn't see an AC line kit on their site and JE said they didn't think Sikky was mass producing the lines.
Maybe we can get a swaps sub-forum where we can start (or move) our individual build threads so others can see the options and all the steps involved such as wiring, hookup of sensors, modding the cluster, AC issues and so on. That way we can have some definitive answers to questions.
Havok, Snyper, Quamen... are any of you guys running AC? If so, do the factory controls work at all? It seems the AC controls may be in the canbus with the tach.
Old May 13, 2011 | 06:51 AM
  #426
str8dum1's Avatar
str8dum1
None of them have AC.
The only thing that kept me from the swap over my motor build was the lack of people that have done it. tough enough making a proper VQ build with a bunch of shops support.
Old May 13, 2011 | 07:18 AM
  #427
Royal_T's Avatar
Royal_T
Good info on the VATS... And I also think we should have a separate sub-forum for engine swaps or hybrid engines. That would help out a lot...
Old May 13, 2011 | 07:32 AM
  #428
dikspiel's Avatar
dikspiel
Chestons Toilet
I agree
Old May 13, 2011 | 08:22 AM
  #429
bbs350z's Avatar
bbs350z
ryans has no ac, or any creature comforst to be exact lol.
+1
i found this website for ecm reprogramming
http://www.pcmperformance.com/programming.html
then i also found that they do vats delete through an ebay ad for $110
http://cgi.ebay.com/ebaymotors/GM-VA...-/150484707224
now 1 more question arises...before we were to send it in for a vats delete, would anything else need to be changed? reason i ask is i keep seeing things like this on multiple pcm flash option lists
Speed calibration for axle ratio or tire changes
i have a 3.3 fd from my old build swapped in and no longer have my factory 3.5 so i wonder if my speed calibration will be off. also, my pcm came with a nifty egr delete, skip shift, and no speed/rev limiter. nifty nifty
Old May 13, 2011 | 09:44 AM
  #430
Quamen's Avatar
Quamen
bbs,
I still have power windows :P
Old May 13, 2011 | 10:11 AM
  #431
bbs350z's Avatar
bbs350z
Originally Posted by Quamen
bbs,
silly me, how could i forget
Old May 13, 2011 | 11:59 AM
  #432
Cass007's Avatar
Cass007
Same Here. I also wonder if the GM ECM can have other things done when the VATS is disabled, kind of like an UpRev flash.
Things are beginning to look more complicated than just plug and play. Still haven't heard back from SIKKY about the AC controls, so not assuming thats good news. I MUST have AC... period. I'm fine with hiding switches in the cubby or whatever.
I'm leaning towards letting the car be down the whole year rather than try and get the swap done in a hurry and miss things I could have changed if I wouldn't have rushed. Lots going on at work this summer as well
Old May 13, 2011 | 12:04 PM
  #433
Chi-TownWarrior's Avatar
Chi-TownWarrior
If your going to try to use your ViPec, do you need the GM ECM?
Old May 13, 2011 | 06:53 PM
  #434
Havok_RLS2's Avatar
Havok_RLS2
SIKKY:
Havok, Snyper, Quamen... are any of you guys running AC? If so, do the factory controls work at all? It seems the AC controls may be in the can-bus with the tach.
I haven't really missed my A/C yet probably due to the fact that I work nights and don't drive it much during the day. Yes. I'm Batman.
All my climate controls work like stock except I just don't get A/C cooled air. You'll probably want (NEED) it if you live in a hot climate region like Texas though. Sikky may not be mass producing the lines YET because there's not much of a demand YET but if you must have them now they can make them. At least Sikky offers you an option.
There are a lot of parts still under development at Sikky that you wont find on their website. I'm still waiting for an update on the improved Sikky sway bars for this kit.
Old May 14, 2011 | 03:32 AM
  #435
Cass007's Avatar
Cass007
That would be one of those rush vs wait issues. Who really knows what I do and don't need. I do think the VATS is a must though.
This is a huge relief, so then it would just take a separate toggle switch to turn the GM AC on/off.
I work 3~4am twice a week making our deliveries into downtown Baltimore, constantly thinking about how much fun the car would be on the completely empty roads and highways.
Old May 14, 2011 | 03:01 PM
  #436
bbs350z's Avatar
bbs350z
^i love driving late late night when the roads are dead...just worry about the sheriffs lmao. so i would imagine the ls a/c unit would just need custom lines, which mates directly to our a/c condensor? also, if we spliced the ac wire on the z harness into the ls harness (its only 1 wire for the z harness) and using the condensor, couldnt we control the ls a/c with the factory controller? or even better, if we could fabricate a mounting solution for the z a/c condensor in the ls a/c location we wouldnt need any wiring riffraff, just custom lines, to which it should operate like stock then id assume. lines would be fairly easy to hide as well (inside the fender)
Old May 15, 2011 | 04:10 AM
  #437
Cass007's Avatar
Cass007
Thinking about this more and more. I will try and do some research on the LS forum to see what they say also maybe that no rotory Mazda forum for swaps as well.
Quaman, you're on a full stand alone right? What did you end up doing? I need to go back and read through your entire thread.
These are questions that we need answers to for sure, but whom do we ask?
Old May 15, 2011 | 08:13 AM
  #438
bbs350z's Avatar
bbs350z
cass to answer your questions, ryan utilized the stock 350z oil pressure sensor and plug, oil pressure sensor and plug, alternator, starter, power steering pump, so it would start up like stock, the standalone controls everything else i believe.
also, i think i am going to attempt to make a custom bracket for the oem z a/c and work off that
Old May 16, 2011 | 03:44 AM
  #439
Quamen's Avatar
Quamen
That is correct bbs. I used all the stock Z sensors so the gauges still worked. I also made my own brackets to mount the stock Z power steering pump and alternator for less of a wiring nightmare.
The standalone I have uses it's own complete wiring harness so wiring was extremely easy since I didn't have to try integrating anything.
Old May 16, 2011 | 04:20 AM
  #440
Cass007's Avatar
Cass007
Considering doing the same thing with the accessories, kind of surprised that nobody has made brackets to do this that are for sale yet (You should do this Quamen... I would pay to have it done ). I suppose I will have a friend of mine with a machine shop stop by and take a look at things and get some measurements so he can work up a price. Still doesn't solve the tach issue though.
I need a primer on what all the sensors on the LS2 do and where they are, then get with my ViPEC guy and see what can be wired in and controlled. Right now selling all my old parts is taking a large chunk of time.
