Sikky 350z/G35 LSX swap
Old Jun 6, 2011 | 04:05 PM
  #481
Cass007's Avatar
Cass007
Guys, I asked for a sub-forum and was denied till we establish more swap traffic. Mike was nice enough to give us a sticky thread to put our info and questions in.
Old Jun 6, 2011 | 04:54 PM
  #482
Quamen's Avatar
Quamen
I have a thread in the suggestions forum about 6 months ago that they denied me also...
Old Jun 6, 2011 | 04:57 PM
  #483
Quamen's Avatar
Quamen
Define "retro fitted" please
By retro fit I mean I swap a Nissan sensor into a GM motor. The example is the oil pressure sensor in which the Nissan sensor is 1/8" BSP and the GM sensor is 16mm. I took a 16mm hydraulic o-ring plug and put in a lathe, drilled a hole through the plug and then tapped the hole so it is 1/8" BSP. I then JB welded the stock Nissan oil pressure sensor into the 16mm plug and now you have a VQ sensor that can be directly installed on an LS motor.
Old Jun 6, 2011 | 06:08 PM
  #484
rcdash's Avatar
rcdash
JB Weld and anything oil related have failed on me more than once - just saying...
Old Jun 6, 2011 | 06:31 PM
  #485
Quamen's Avatar
Quamen
Really? When prepped correctly I have never had a failure of any sort as long as it was in an application under four hundred degrees.
Old Jun 13, 2011 | 08:50 PM
  #486
wrecker's Avatar
wrecker
Default engine question
quick question here...
could u use a 2007 corvette C6 LS2 engine ?
would a t56 tranny bolt up to it..?
thx for your time
Old Jun 13, 2011 | 11:23 PM
  #487
bbs350z's Avatar
bbs350z
thx for your time
motor will work, t56/tr6060 will work and gto. fbody (w/ ls2 knock sensor adaptor)/custom harness will work. corvette trans/harness wont work
Old Jun 15, 2011 | 10:30 AM
  #488
10-E-C-350Z's Avatar
10-E-C-350Z
concerning swap traffic, I'm definately in. Parts are ordered I just need need time. Let's get this sub forum going!
Old Jun 15, 2011 | 01:29 PM
  #489
Cass007's Avatar
Cass007
Sub-forum is not happening right now. Please use the sticky at the top of the forum or feel free to start your own detailed build thread on the process. I will most likely do a step by step thread with costs and parts when my TT kit sells and I am ready to move ahead. I was ready to buy parts yesterday and decided to throw the wife a bone and get the driveway re-paved instead... FAIL!!
Old Jun 15, 2011 | 02:58 PM
  #490
10-E-C-350Z
When I read that you threw her a bone I was thinking a piece of jewelry or a sexy outfit but getting a driveway re-paved? That's a huge bone to throw! I found the sticky right after posting in this thread and sub'd to it. I will definately be tracking other builds and imputting things from mine once I start it next year. Thanks!
Old Jun 15, 2011 | 03:49 PM
  #491
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I'm a long-time advocate for the Swap forums myself, but just because I can doesn't mean that I will create a new forum for something that currently can't justify its own section. It will happen, though. I just can't promise when. As Cass stated, please use the sticky for now as a reference and a place for you to submit relevant info.
Old Jun 15, 2011 | 05:06 PM
  #492
dikspiel's Avatar
dikspiel
Chestons Toilet
How about an off topic subsection for br0s
Old Jun 16, 2011 | 06:45 AM
  #493
bbs350z's Avatar
bbs350z
^lol
threefive, for now a sticky is perfect until we get more info, pics, links, etc and organize it. i feel once we get a few more members doing this, and get a couple different setups going then well be ready
Old Jun 21, 2011 | 09:04 PM
  #494
Band-Aid's Avatar
Band-Aid
Wow. Can't wait to do this when I get back from Afghanistan. Seems to be the better route than a built FI VQ. Awsome info guys. Quick question for ya. I think I read in this thread that there's no kit yet for the LS3. Has anyone done or thought about the LS3 erod? http://www.gmperformanceparts.com/erod/
Seems like a good route for California residents (which is my home state) and makes good power. Definitely going to be following close over the next year or so until I can start. Thanks for paving the way. Hopefully all the issues will be solved by the time I start. Plug n' play LSx swap lol.
Old Jul 11, 2011 | 04:38 AM
  #495
Cass007's Avatar
Cass007
Bumping this because I am too lazy to keep going back 3 pages to look at pics for reference
Old Jul 11, 2011 | 09:17 AM
  #496
SikkyMFG's Avatar
SikkyMFG
Vendor - Former Vendor
Hey everyone,
I'm writing to clarify all the A/C confusion there has been. The A/C can work, with some custom modification. You will need to wire up a one-off external switch to turn on the A/C compressor. You will also need to do custom A/C lines. Sikky does not offer either of these items. We are tying to avoid releasing one without the other, so we are waiting until we have both pieces fully designed and ready for production. There is currently no ETA on our A/C components. Feel free to PM or email us if you have any further questions. Thanks a lot and sorry for all the confusion there has been involving this topic.
-Sikky MFG
Old Jul 11, 2011 | 12:27 PM
  #497
STL 350Z's Avatar
STL 350Z
With an external switch will that allow the a/c to clutch on and off when it needs to so it doesn't run 100% all the time or does it run constantly? The a/c confuses me...
Old Aug 4, 2011 | 04:16 PM
  #498
350Z_Al's Avatar
350Z_Al
Just from my general knowledge of automotive wiring I'm going to say the switch enables and disables the AC clutch and it is not on all the time.
Anybody who's done that care to confirm?
Old Aug 4, 2011 | 06:43 PM
  #499
Cass007's Avatar
Cass007
I believe that is correct.
Old Aug 4, 2011 | 07:30 PM
  #500
bbs350z's Avatar
bbs350z
i had sikky leave my 350z ac wiring alone. i hope that would be a simple solution
