Newly purchased used 350, having issues...
Old Feb 7, 2011 | 03:09 PM
Jake8267's Avatar
Jake8267
Default Newly purchased used 350, having issues...
Specifically, cooling issues. Test drove the car the other day for about half an hour and didnt notice mechanically anything wrong with the car. Now today when i drive it off the lot, i get about 2 miles down the road, and do the standard gauge check when i notice the temp gauge creeping up, to about 75%. Pay close attention to it for a bit while driving and it goes down to about 50%. Stop at a light for a few minutes and boom now its near peak. Pull over pop the hood, the overflow container is SUPER full. Slowly release the radiator and its full too. Grad the hoses leading into and out of the block, give them a good squeeze and feels like they are empty. Wait a couple minutes at idle to make sure the fans are running ect and to see what the over flow and radiator do. nothing noticable happens. My question is this, does this sound like a a hung or bad thermostat or a water pump, or am i totally off base.I also noticed the windows were fogging up, while it was cool and raining out, im not sure if this issue is seperate or related.
I really doubt these cars run this hot, and this is my first real experience with one.
FYI its an 04 with 42k.
Thanks for your help guys and sorry for the long read.
Old Feb 7, 2011 | 03:11 PM
lgear080's Avatar
lgear080
these cars do not run hot. where did you purchase from?
how recently bought?
Old Feb 7, 2011 | 03:18 PM
Jake8267's Avatar
Jake8267
I bought from a wholesaler here locally, today. FML
Old Feb 7, 2011 | 04:25 PM
90 percent certain it is the thermostat. Do you know how to check the thermostat after removing?
Old Feb 7, 2011 | 04:38 PM
Jake8267's Avatar
Jake8267
No i do not, but im fairly able when it comes to messing around with cars, so any advice would be appreciated. Also when i checked the coolant, it looked clean, like way to clear almost. So im wondering if the car had just been sitting for a while when i initially drove it, and the thermostat was hung open, and now maybe its hung shut.
Thanks again man.
Old Feb 7, 2011 | 04:49 PM
Thanks again man.
Put it on the stove in a pot of water with a thermometer. It should open and close at the specs above.
Old Feb 7, 2011 | 05:45 PM
Jake8267's Avatar
Jake8267
thanks man ill give it a shot.
Old Feb 7, 2011 | 06:26 PM
lgear080's Avatar
lgear080
Good advice keep us posted. Great troubleshoot advice.
Old Feb 8, 2011 | 12:00 AM
winchman's Avatar
winchman
Be sure and rinse the thermostat well before you put it in the pot, and wash the pot before using it for anything else. Antifreeze is poisonous.
Old Feb 8, 2011 | 04:58 AM
baileyrx's Avatar
baileyrx
if not the thermostat(probably not). vq's are notorious for being difficult to get all the air bubbles out of the cooling system. It normally takes about 15-20 minutes, to get them all completly out. There is a bleeder valve on a hose near the back left of the engine, that helps the process out... g/l
Old Feb 8, 2011 | 07:39 AM
porschett's Avatar
porschett
Check to see if both your fans are running. Mine started overheating 6 months ago due to the AC fan not working. There's a recall on them, so call your dealer, give them the vin, and see if it's been replaced.
Old Feb 8, 2011 | 01:14 PM
Jake8267's Avatar
Jake8267
awesome will do thanks man.
Old Feb 8, 2011 | 01:19 PM
KornerCarver's Avatar
KornerCarver
Once you remove your thermostat, I would just replace it.
Jambo016
Sep 16, 2016 01:08 PM
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
