Help with Valves and Compression mods!
Old Mar 20, 2011 | 03:19 PM
surfo's Avatar
surfo
Default Help with Valves and Compression mods!
Hi guys!, I´m new around here, I just bought my 350z and installed the usual intake, headers, testpipes and y pipe... I usualy race on track days but our race track is at high altitudes (around 6,500 feet over sea level) and I live at sea level, so Trust me, I can feel how a lot of Horses die inside my engine! hahaha )
well, I´m not aiming on a SC or Turbo, I already had a 500hp Seat Leon (same engine than the Audi S3 1.8t) and is just to much money to be wasted also in adding brakes, and more stuff... I just need some good HP´s back in a totally Fun N/A car !!!
So I´m thinking on getting oversized Intake Valves, polishing and Porting, and a kinetix intake manifold or maybe just the spacer, and increasing engine compression but not willing on buying new pistons, so I would like to know how much is the maximum amount I can (don´t remember the exact word) take off from the bottom of the head without problems... I´m used to the VW engines were we coult take up to .040 or so.
Thanks guys... Sorry if I have mistakes on my english and terms but is hard to convert daily metrical numbers and think in ft´s, inches, and so on...
Old Mar 21, 2011 | 12:13 AM
terrasmak's Avatar
Just buy pistons, decking the head will change your cam timing and there are no (that i know of ) adjustable timing gears to correct that. If you go ahead and do this, throw some cams in it. Valves, i have no idea on how much extra flow you get, something i need to look into as i'm about to start a motor build.
Is this straight line driving or roadcourse?
Old Mar 21, 2011 | 08:11 AM
surfo's Avatar
surfo
now I see... this is for Roadcourse... so if I deck the head I will have problems with my timing. hum... Dam this car is expensive to modify hahahha...
Ok so:
Pistons
Intake valves +1mm
and head porting + polishing...
Any other ideas?
Old Mar 25, 2011 | 02:42 PM
surfo's Avatar
surfo
BUmp!... would I need to get a UTEC / E-manage or AEM Controller after installing the new Pistons for higher compression?
If Yes... wich one to get?
Old Mar 25, 2011 | 09:31 PM
terrasmak's Avatar
Set of Cams.
Old Mar 26, 2011 | 08:06 AM
shakuya88's Avatar
shakuya88
Neither, get the Uprev Osiris.
Old Mar 26, 2011 | 08:22 AM
kacz07's Avatar
kacz07
get UpRev Osiris tuning, a set of JWT springs/shims, and JWT cams. You'll save yourself some considerable money.
Old Mar 26, 2011 | 08:28 AM
0jiggy0's Avatar
0jiggy0
Ok so:
Pistons Yes
Intake valves +1mm Not sure if youll see gains with them NA but hey why not try and see what happens. Dont know of any documented NA gains.
and head porting + polishing... Stock Z heads flow very well but again see above, cant hurt I suppose.
Any other ideas?
Cams and Uprev osirus. If you want to go crazy you can go haltech. What heads did you buy?
What suspension mods have you done? Diff?
Old Mar 26, 2011 | 11:48 AM
surfo's Avatar
surfo
So instead of High Comp Pistons, getting UpRev, JWT springs/shims, and JWT cams I will get more power when racing at high altitudes?
No heads bought yet, we are going to do the porting and polishing down here.
Suspension mods will be K-sport Coilovers, and still no Diff.
By the Way... the guys from Piassini Engineering offered me the Ecu Flash. this guys are heavy at Europe and there is a dealer down here wich I can send my Ecu and logs, so maybe I`ll give a try with them, but first I need to define which setup I will use in my car.
Old Mar 26, 2011 | 12:13 PM
djamps's Avatar
djamps
Don't do 'e-tuning'... get it a proper dyno tune. There are several locals that have gone from 240whp to 270+whp with basic bolt ons and a dyno tune with osiris. A proper dyno tune will yield more gains than any other single bolt on, even on a completely stock VQ. Cams will just shift the power curve to the right...unnecessary for anything other than a full time track car IMO.
Old Mar 26, 2011 | 12:20 PM
terrasmak's Avatar
If your going to pull the motor apart and do all that stuff, do everything including cams. If not just tune for now and drive, then use the money for a diff. The diff will probably make the biggest difference.
I would actually do a full suspension and brake build before the motor. Hell i would probably do everything to the car before i built the motor. Our cars have plenty of power as is.
I've got 130k on mine now, valve covers have yet to come off.
Old Mar 26, 2011 | 01:55 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you cannot increase compression on this engine without
1. new pistons
2. NISMO heads
the larger valves are a waste
step 1 is setting a budget, as that sort of dictates what really can and cannot be accomplished
Old Mar 28, 2011 | 08:40 AM
surfo's Avatar
surfo
1. new pistons
2. NISMO heads
Well, Budget is around $2,000-$2,500 usd... that`s why I was thinking on Pistons, and work the head (this is free since we have the machinery) and a k-sport setup or brake setup... This car is a Daily driver.
Old Apr 2, 2011 | 07:56 AM
CustomGsedan's Avatar
CustomGsedan
^^^ thats an extremely low budget for what you want to accomplish
Old Apr 2, 2011 | 09:55 AM
e30cabrio's Avatar
e30cabrio
I really like that 1.8T motor, had it in my 2000 A3 when I lived in Morelia.
I started out simple with a 3k budget and am 10k+ into my NA stroker. I strongly suggest you define what exactly it is you want. I have 271/262 on UPREV with bolt ons.
Old Apr 2, 2011 | 10:04 AM
surfo's Avatar
surfo
You guys are right... I`ll start with Diff and Suspension.. I already have all bolt ons except the plenum spacer wich next week I`ll order...
Yesterday I got really scared by my car, I went to the road, and suddenly my accel pedal simply stoped working!!!, let go, press again, NOTHING HAPPEND! car simply stayed on any rpms when I press the pedal... let go again, down to 3k and pedal worked fine... but after 4k if I let go it simply wouldn`t react until under 3k...
My head simply started spining around on costs, parts, and all that...
Finally a friend says... hey, your rear lights don`t work... DAM IT!!! that was all the problem
That was funny.
Old Apr 3, 2011 | 03:37 PM
Lalo350z's Avatar
Lalo350z
hi im new here too and i have the same questions of surfo, actually we live in the same city and our cars have the same mods. i was doing some research and i found that some people buy a pulley kit that cames with 3 lightweight pulley The pulley kit includes the crank pulley with correct timing marks, alternator pulley, and idler pulley. do you think that this kit help us to gain some Hps combined with the other mods like headers, test pipes, HKS dual exhaust and the plenum spacer??
PS: sorry for my english i have not practice in a while !
Rev_Night
Nov 7, 2020 06:00 PM
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
