Custom Engine Grounding/Earthing Kit
Old Jan 15, 2003 | 04:37 AM
  #181
insaneamine's Avatar
insaneamine
Inventor
Z-Xtreme.com
Default Import Tuner - Hyper Ground Article
Dyno_2
Attached Thumbnails Custom Engine Grounding/Earthing Kit-dyno_2-copy.jpg
Old Jan 15, 2003 | 04:39 AM
  #182
insaneamine
Inventor
Z-Xtreme.com
Dyno_3
Attached Thumbnails Custom Engine Grounding/Earthing Kit-dyno_3-copy.jpg
Old Jan 15, 2003 | 04:41 AM
  #183
insaneamine
Inventor
Z-Xtreme.com
Dyno_4
Attached Thumbnails Custom Engine Grounding/Earthing Kit-dyno_4-copy.jpg
Old Jan 17, 2003 | 10:33 AM
  #184
hfm's Avatar
hfm
Kit received yesterday. Will install tomorrow. I just want to give some kudos to Insaneamine today, let me explain why.
I ordered the kit sometime ago. It was shipped on a Friday. The next Friday, it was not yet received. So, I drop Insaneamine a e-mail and advise about the missing kit. Insaneamine says, must be lost in the mail. I will make you another kit.
No questions asked, Insaneamine steps up to the plate and was willing to make a new kit for me.
In fact, the kit shows up on Insaneamine's door step, returned to sender the next day. Insaneamine let's me know and mails it on Monday and I receive it Thursday.
Let me just say that I knew I could trust Insaneamine to foward the kit and Insaneamine trusted me when I said the kit wasn't received. In short, Insaneamine handles his little business like a pro.
Thanks and kudos to you Insaneamine.
Old Jan 17, 2003 | 11:10 AM
  #185
JimmysZ's Avatar
JimmysZ
Default SILVER PICS????
Does anybody have SILVER PICS installed???
Please...
Thanks...
Old Jan 18, 2003 | 01:18 PM
  #186
insaneamine
Inventor
Z-Xtreme.com
Default Ask and ye shall receive!
Chrome Silver Grounding Kit on a Chrome Silver Z!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-silverinstalled_covered.jpg
Old Jan 18, 2003 | 01:20 PM
  #187
insaneamine
Inventor
Z-Xtreme.com
Default Chrome Silver Grounding Kit!
again...
Attached Thumbnails Custom Engine Grounding/Earthing Kit-silverinstalled_covered2.jpg
Old Jan 18, 2003 | 09:26 PM
  #188
Zzyzx's Avatar
Zzyzx
Thumbs up
Finally installed my kit from Insaneamine. It has been sitting around on my desk for a couple of weeks. Install was a snap, Thanks a bunch Insaneamine!
Old Jan 19, 2003 | 01:49 PM
  #189
Da Gimp's Avatar
Da Gimp
I picked up my car yesterday, installed the grounding kit today. I think the only bad thing is my back is about to break, but the instructions were pretty clear. Thanks insaneamine!
Attached Thumbnails Custom Engine Grounding/Earthing Kit-dscf0678.jpg
Old Jan 19, 2003 | 02:17 PM
  #190
12SecZ's Avatar
12SecZ
Thumbs up That Blue looks great
And that's a great pic!
Old Jan 19, 2003 | 04:52 PM
  #191
Sabre's Avatar
Sabre
Is that the middle blue color set?
Old Jan 19, 2003 | 08:00 PM
  #192
hfm's Avatar
hfm
Stinger Blue Installation
Installation
Stripped the 10mm engine cover bolt under the strut bar by using the wrong tool. Took off the strut bar to get the bolt off. Installation was pretty easy following directions and pics on this thread. The pics were very helpful. Avoiding dropped bolts from reading this thread was also helpful.
Will have to have the strut bar tighted at the dealership on my next oil change as I noticed the washer markers were off by 2-4mm. Extra bolt from Insaneamine replaced the stripped engine cover bolt.
Performance change
Idle smoother. Still noticed a slight studder but not as frequent and lower in intensity. Will need a few days to feel out.
Throttle response was definitely different and improved. Prior to the installation, 4,200 to 4,500 where torque really kicked in caused raspy and rough engine feel and sound. That is totally gone. It is now a clean response all the way up to 6,500 rpm. It's like there were two power bands before the installation and now there is just one smooth power band.
Too early to tell if there is a HP increase. If K&N is really 7hp and this kit is really 2-3 HP, then I'm at about 297 HP. I don't think I've gained 10 horses but I would believe 5-7 between these two mods. Will dyno after ECU installation.
Shifting
A little early to tell but it seems to be a easier shift.
Color matching
The Stinger blue is virtually identical to the Daytona blue.
Conclusion
Overall, I highly recommend this modification if only for the improved throttle response. The change is definitely noticable at 4,200-4,500 where the rough feel is absent.
Old Jan 19, 2003 | 08:17 PM
  #193
insaneamine
Inventor
Z-Xtreme.com
Default Thank YOu!
Hey HFM,
I can't tell you how much I appreciate the kind words of praise. Your install pictures are great, thanks for sharing!
Old Jan 19, 2003 | 08:19 PM
  #194
insaneamine
Inventor
Z-Xtreme.com
Exclamation Just a reminder
Please email me with any comments, questions or requests:
InSaNeAmine@***.net
I don't check the forum every day and don't always get my PMs.
Old Jan 19, 2003 | 10:23 PM
  #195
Da Gimp's Avatar
Da Gimp
Yes, I ordered the middle blue. Its a good match.
Old Jan 19, 2003 | 10:57 PM
  #196
slay2k's Avatar
slay2k
Default This is all great but...
Anyone care to comment on the warranty and the implications of such a simple install on the warranty ?
I mean, I would assume it would have no effect, but does anyone actually have any FACTS or has actually talked to Nissan about it ?
I'd really like to get & install the kit but I obviously wouldn't want to affect the warranty in any way
Thanks and keep up the good work.
-slay
Old Jan 19, 2003 | 11:34 PM
  #197
hfm's Avatar
hfm
Default Re: This is all great but...
-slay
I'd suggest you review these sites.
http://www.granatellimotorsports.com/magnusonmoss.htm
http://www.mlmlaw.com/library/guides...s/undermag.htm
http://www.ram-it.com/Understanding%...20Magnuson.htm
The quick and dirty answer is, yes, it could create problems. However, the corporation would have to weigh the cost of litigation in State or Federal court against the cost of honoring the warranty.
If you blow up your engine causing $10k damage, it may be worthwhile for Nissan to say, no, this isn't covered by warranty and we're not going to fix it.
Since Nissan sells it's grounding kits through Nismo instead of a free article or service, Nissan may lose if you're willing to spend the legal expense. However, there is a kink. Insaneamine's kit may not identifiable by brand, trade or corporate name. What would bolster the modification is if Insaneamine's kit was identifiable by brand, trade or corporate name (ie: K&N, Stillen, Insaneamine Co. etc.)
Bottom line, it's unlikely that the grounding kit will create any problem. You should be more concerned if it were a homemade turbo kit.
p.s. None of the above is, nor should be considered, legal advice.
Old Jan 21, 2003 | 07:24 PM
  #198
hfm's Avatar
hfm
Got my strut bar realigned by the dealer at no charge after my 7500 oil change. The service guys over at Torrance Nissan are great. They were curious about the grounding kit. I explained that the idle is more stable and that the throttle response is much smoother.
They made no comments about warranty and I did not bring the subject up. I really do not believe the grounding kit will be a significant warranty issue. If it does, I would give 'em hell considering the significant improvement I've seen after the kit installation.
After a couple of days, I'm very impressed by the smoothness. The engine now feels like what it should have been from the factory.
Insaneamine, one question, how will the wires plastic cope with the heat from the engine? What if they contact metal surfaces?
Old Jan 21, 2003 | 09:16 PM
  #199
12SecZ's Avatar
12SecZ
Default Good to here
It varies from dealer to dealer I think , some are more mod friendly than others but I tell you what, they would have a legal fight on their hands if they said that a GROUND caused damage (reference the links already posted), especially when it's a factory option in the Country of the car's origin!
They would have a class action law suit on their hands!
Uhhh... Right guys? hehehe!
Power in numbers!
Old Jan 22, 2003 | 07:27 AM
  #200
mf01's Avatar
mf01
If you really worry about the grounding kit and the warranty, take it off before you take the car in. I mean if you think that they could somehow relate a problem of the car to the grounding kit for warranty work take it off before going in. There not going to know that there was grounding kit on there.
