Engine Modding Advice
Old Nov 11, 2011 | 03:06 AM
tanman12's Avatar
tanman12
Default Engine Modding Advice
hey guys..i bought a 2003 350z not to long ago..i am wanting to do some motor work but not exactly sure what to do..i was thinking of doing a low boost turbo but am worried about throwing it on the stock motor.i have 4k to spend..what i have done to it right now is a cold air intake, nismo exhaust and a cb hood
Old Nov 11, 2011 | 03:42 AM
Dr. Venture's Avatar
Dr. Venture
build the motor. you'll get some sufficient power out put. then if you still need more i am sure you can save to upgrade to a turbo.
but in the long run don't waste your money. my Z with bolt ons still beats a lot of other worked Z's. LOL
Old Nov 11, 2011 | 04:27 AM
Jenkins651's Avatar
Jenkins651
I vote you slap a turbo in there lol. The stock de motors can handle a significant amount of boost, hr can handle a lot more, but your de should be fine running 400whp no sweat. If you are worried about it you can just run 350whp all day long.
I say this bc my Z has basically every bolt on there is excluding test pipes/hfc which is coming next, and I can tell a difference, but I still want more. There are tons of threads about what our engines can handle in the forced induction section. Go check it out if you are serious about boost.
Old Nov 11, 2011 | 05:07 AM
JCITY's Avatar
JCITY
Cool
4K is not going to get you anywhere near a turbo and/or a supercharger.
Check your prices.If you do come up with enough cash,you stock motor
will handle a single turbo set up such as a Momentum with no problem.
Old Nov 11, 2011 | 05:26 AM
tanman12's Avatar
tanman12
im currently deployed right now..but when i was on leave i talked to a shop and they said they can do it for around 4k..but thats good to know the motor will handle it. if i dont do the turbo what would you guys recommend i do? intake manifold? different exhaust?
Old Nov 11, 2011 | 06:03 AM
tylerxfire's Avatar
tylerxfire
to buy a kit, have it installed, have it tuned your not gonna do it for 4k..the only way ur gonna do it for 4k is to buy a used kit and put it on yourself and then have it tuned..That would put u around 4k...To do things right you will def. need more than 4k...
Old Nov 11, 2011 | 06:34 AM
Cass007's Avatar
Cass007
THIS!! Any shop that tells you otherwise is just plain lying to you. Unless they meant they can do the install and tune for $4K if you bring them all the parts. Care to share the name of said shop?
Just so you know, VQ's are made of glass, so I wouldn't let a shop that isn't VERY familiar with our platform near the car.
Old Nov 11, 2011 | 06:49 AM
tanman12's Avatar
tanman12
yeah there shop is called tuning gruppe from Mesa Arizona
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
