It's burning oil, let's make the best of it.
Old Sep 8, 2015 | 09:02 PM
allmycarsdie's Avatar
allmycarsdie
Default It's burning oil, let's make the best of it.
I've isolated my oil burning to cylinder 4. My plug in that cylinder fouls weekly. I changed over to 10w-40 oil and that cut oil consumption and start-up smoke to less than a quart a month which is better than the quart a week i was getting from 5w-30. Because heavy weight oil stops the burning, it's only in one cylinder, and the car hasn't lost any power. I'm assuming it's the valve seal, although if it could be something else please tell me other possibilities. If no one can say against the valve seals I was planning to redo them with a maximum $800 budget to make the most of going into the valve covers and doing it the rope trick way. I was planning on buying the supertech valve seals, new valve cover gaskets, and the motordyne 5/6 copper isothermal plenum spacer since I have to remove the plenum anyway. If changing out the valve seals sounds good does anyone know of any other good mods or things to replace while I'm in there? Thank you for any input
Old Sep 8, 2015 | 10:42 PM
PP08HR's Avatar
PP08HR
I'd buy a low mileage used engine and do a swap. Swapping an engine is a lot easier than a rebuild.
Old Sep 9, 2015 | 07:48 AM
allmycarsdie
Valve seals with the heads on only takes about six hours and costs at minimum $100. An engine swap would take quite a bit longer especially for me, and the best deals I've been able to find were about $1000 for a 60k engine. I only have 150k on an engine that has lasted alot longer, until I get enough money to swap for a fully built vq, I'm not really wanting to f**k around replacing stock parts with stock parts. It may well come to a full out swap being needed but like I said all I have is about $800
Old Sep 9, 2015 | 10:25 AM
guitman32's Avatar
guitman32
How many miles is "less than a quart a month?"
Old Sep 9, 2015 | 11:31 AM
HRMoneyPit's Avatar
HRMoneyPit
I'd leak down test it before anything
Old Sep 9, 2015 | 01:07 PM
allmycarsdie
About 750
Old Sep 9, 2015 | 03:51 PM
calibredz33's Avatar
calibredz33
so you're still buring a qrt every 1000k, or sonner? yeaa, do a leak down. what motor do you have?
Old Sep 9, 2015 | 04:14 PM
allmycarsdie
Going to do one soon. I have the vq35de
Old Sep 10, 2015 | 11:02 AM
guitman32's Avatar
guitman32
Based on what youve described you dont really have that big of an issue. Personally I would just run it till it dies or starts burning a lot of oil again. You said the motor has 150k?
Old Sep 10, 2015 | 07:50 PM
allmycarsdie
Thats what I was going to do, but now that Im swapping new spark plugs into cylinder four every week after driving maybe 200 miles tops its becoming a massive nuisance.
Old Sep 11, 2015 | 04:13 PM
guitman32's Avatar
guitman32
Hrm, well as said do at leakdown at least to try and isolate.
Old Sep 12, 2015 | 11:23 AM
rcdash's Avatar
rcdash
Could just be the spark plug seal. I guess you will find out. Sounds feasible but I don't recall anyone posting up that they have done it... The leakdown will let you know if it's the cylinder ring vs valve seal, but u could just do a compression test and if that checks out then go on ahead.
Old Sep 21, 2015 | 05:35 PM
Resmarted's Avatar
Resmarted
Well the plug wouldn't be fouled on the inside would it?
+1 on figuring out if it's rings or valves.
Old Oct 26, 2015 | 05:07 AM
350z-Helsinki's Avatar
350z-Helsinki
Compression test won't tell you much. I had similar issues. Only even bigger oil consumption. Compression test was ok, but leakdown test wasn't. Piston looked like this after disassemble. So I wouldn't count on compression test results.
Old May 12, 2016 | 07:46 PM
jes1888's Avatar
jes1888
bump for the thread, what happened in the end?
Old May 13, 2016 | 04:38 PM
Resmarted's Avatar
Resmarted
With a piston like that it should show in a comp test, and in an oil test.
Black stone lab oil tests are cheap and they should pick up if things are getting burnt up.
Also I think every DIY car owner can afford a cheap usb borescope. They're pretty low resolution, but for $20 you would see that without a tear down.
Just food for thought for anyone else that might be in that situation. Save yourself the hassle of a teardown.
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
seagrasser
Oct 11, 2015 03:27 PM
samansharif
Sep 25, 2015 12:31 PM
smithmt3
Sep 11, 2015 08:25 PM
