Anybody want to shed light on my modding dilemmas?
Old Mar 28, 2023 | 10:18 AM
  #301
Heel Til I Die's Avatar
Heel Til I Die
Old Mar 28, 2023 | 01:10 PM
  #302
luv350sass's Avatar
luv350sass
lol i cant help but ask, would you use seafoam once? 2003 79k miles, and may have sat at some point.
Old Mar 28, 2023 | 02:07 PM
  #303
MicVelo's Avatar
350Z/370Z Tech Moderator
Who does Nismo outsource to manufacture their different aerodynamic parts and body kits?
Originally Posted by GreyZ
Autech. And spl does their suspension. and I believe OSG does their diffs.
Actually, the Nismo body design is a joint Autech - Zagato design (well, not Zagato the Italian company which did some joint stuff with Autech 30-some years ago but supposedly designers who were with Zagato back in the day). Who makes it is another question. Would guess these are made in-house or possibly locally outsourced.
Yamaha designed the Nismo suspension system and it was spec'd out to Tokico for manufacture. All standard suspension bits are in-house design and manufacture with probably few things outsourced to specialty companies, e.g., bushings, bearings, etc.
For the record, Nismo and Autech were separate divisions within Nissan. As of 2022, Nismo and Autech are no more. They merged and are now called "Nissan Motorsports & Customizing". They've combined to provide the racing bits n' kits that Nismo did before (with Autech's help) as well as other formerly Nismo stuff like the production cars. The oft rumored and spied RZ34 Nismo is the responsibility of NM&C which I'll still call Nismo. Or maybe "Nismotech." Laff....
Pretty sure the drivetrain components - transmissions, differentials - are in house built. Doubt OS Giken had anything to do with it other than supplying some really cool, trick LSDs and such in the contemporary age. Reason I say this is when I worked for Datsun/Nissan, transmissions and diffs were shipped from the factory gear and transmission plant. Also, the original Z car ran an R180 transmission designed way back in the '60s. Later Zs used the R200. And guess what? 350Z still uses the R200, albeit NOT the same R200 I had in the '80s. It's built around the same design but the housing, gears, LSD, are not backward compatible. Why this is a key point.... OS-Giken wasn't a company until after Nissan began building cars with R180 diffs and as far as I know, OS-Giken has always been an aftermarket (vs OEM) supplier.
Speaking of OS Giken and the aftermarket....
Old Mar 28, 2023 | 02:32 PM
  #304
Heel Til I Die
I never thought I would come this thread and leave smarter. Thanks a lot, Mic.
Old Mar 28, 2023 | 02:38 PM
  #305
Heel Til I Die
I've never used it. Seems like snake oil to me.
Just make sure you use the right foam...
Old Mar 28, 2023 | 02:42 PM
  #306
Legacy406's Avatar
Legacy406
Omg hahahahah
Old Mar 28, 2023 | 02:44 PM
  #307
luv350sass's Avatar
luv350sass
lol im not that stupid. im pretty stupid w the wrench in my hand, but i even knew all about nvh on motor mounts and suspension parts and stuff before heel schooled me on it. mainly because ive been doing so much research trying to nail it down. i still didnt know what i wanted though, or what the nvh level would feel like. seafoam had always been a debated topic. i went to napa recently, and got some coolant to top it off. i also impulse bought some spark plugs without even taking engine cover off yet. i did notice it drives smooth, and rpms look good at idle. on occassion at idle though it will blurp as if it shuddered or almost died. its more the vibration but it does make a subtle exhuast note.
I may just buy the freakin coolant hoses. just one upper and one lower. without them inspecting it since im definitely getting it flushed, and why not. may buy all oem hoses after suspension fixed
Old Mar 28, 2023 | 07:42 PM
  #308
mr. sparco's Avatar
mr. sparco
Speaking of Nismo, how about Nismo Heritage. Cool tech bringing back the classics.
The damage already done could be exponential to recovery.
Old Mar 29, 2023 | 05:43 AM
  #309
Heel Til I Die
What plugs did you get and did you already install them yourself?
Old Mar 29, 2023 | 07:48 AM
  #310
luv350sass's Avatar
luv350sass
I got ngk platinum premium. I read another my350z thread and some people reccomended platinum, some irridium. it seemed like a good choice to me. The guy at napa recommended it heavily, over denso platinum. he also reccomended the seafoam, but i dont think ill do that.
No, i dont plan to put them in myself. Ive never gapped any before, or torqued anything to spec. Some night when i have a little time, im going to attempt to remove and replace front sway bar and engine cover. If the spark plugs dont look brand new, i will have them install them april 14-19, when its in the shop.
Ill def post a pic of the engine. you all have been real helpful so far, maybe youll see something i wont. ill also do some research on what im looking for. oil spots, fouled plugs, and belts.
Old Mar 29, 2023 | 09:02 AM
  #311
Heel Til I Die
NGK platinum is OEM. NGK Iridium is better (IMO). They should come pre-gapped but always best to double-check since things shift during transit, etc.
Just wanted to mention that since, you know, best/expensive parts and all.
Old Mar 29, 2023 | 09:05 AM
  #312
Heel Til I Die
Also, if you (or your shop) finds oil covering the tips of any plugs, then some new valve cover gaskets are in your future since the spark plug tube seals are not serviceable (at least not by conventional means, but there are ways around that which I wouldn't recommend).
Old Mar 29, 2023 | 03:43 PM
  #313
MicVelo's Avatar
Nismo Heritage is a godsend if you have a Skyline. Not much for early Z cars, roadsters, and most anything non-JDM. But glad they're doing it because one day - if I move out of California - I'll own that R34 I've always wanted.
Old Mar 29, 2023 | 03:53 PM
  #314
mr. sparco's Avatar
mr. sparco
Top Rank, every so often I see a R34 or two around town with Ca plates. Prices are about in line with Plaids, well a bit of added jdm tax on top.
Old Mar 29, 2023 | 06:58 PM
  #315
DarkZ03's Avatar
DarkZ03
Originally Posted by i8acobra
Do you just argue for the sake of argument? Literally the only difference is the badge.
Not a matter of ripping off. Just Nismo is a brand, not a manufacturer.
You make it sound like Nismo buys the AEM intake, slaps a sticker on it and puts it I'm a different box. That's not at all what is going on here.
It's not a damn argument, its just facts.
Old Mar 30, 2023 | 06:11 AM
  #316
i8acobra's Avatar
i8acobra
You and everyone else. When the R34 hits 25 years old, I predict the values are going to double just due to US demand.
That's exactly what's going on here, with one exception... Nismo doesn't slap on the sticker, AEM does. I've been to the AEM intake development and factory site in Long Beach. I've seen the Nismo boxes. That's how I learned about it.
Old Mar 30, 2023 | 04:05 PM
  #317
luv350sass's Avatar
luv350sass
i trust you pretty good for some reason, so youre making me wish i got iridiums. However, since that thread was either or, and oem seems good; ill prob keep them. i dont like being a problem customer and returning things.
i got an oem oil dipstick in the mail today to replace my crinkled up one
Old Mar 30, 2023 | 05:13 PM
  #318
luv350sass's Avatar
luv350sass
ohh and btw you all are talking dream cars.. id love an r34. but im still stoked about my z and would maybe choose this over an r34
Old Mar 30, 2023 | 08:18 PM
  #319
mr. sparco's Avatar
mr. sparco
Its not how much you make, but what you do with your money, that makes all the difference. Dreams can come true and I mean by legit ways. Just ask some of the members here, one guy who has responded just bought a Tesla S-Plaid to add to his collection.
Old Mar 31, 2023 | 12:52 AM
  #320
luv350sass's Avatar
luv350sass
ive got dreams of starting businesses, but i would hate to borrow money and at my rate ill never get there. im happy though. I seriously might lease a second car, and might try to track one. it probably is a bad idea to go crazy on public roadways, in a car thats becoming rare and noticable... Its just tough because idk whats near me other than autox and drift meets. and i may not even mod my car to fit a class. I may be cool with being outclassed and not care about being competitive. i really dont want to buy a truck as second car, to tow mine.
edit: that s plaid seems ridiculous. it weighs so much, how is it formidable anywhere but the drag strip? i bet it would **** me off with technology
