Anybody want to shed light on my modding dilemmas?
Old Mar 31, 2023 | 05:06 AM
  #321
Heel Til I Die's Avatar
Heel Til I Die
Originally Posted by luv350sass
i trust you pretty good for some reason, so youre making me wish i got iridiums. However, since that thread was either or, and oem seems good; ill prob keep them. i dont like being a problem customer and returning things.
i got an oem oil dipstick in the mail today to replace my crinkled up one
Platinum NGKs will be fine and likely sufficient for your needs. Of course, lots of other suggestions were sufficient for your needs, but you went high society, so I just thought I'd mention it.
The engineer that created the oil dipstick location and design for our engines needs to have their genitals placed in a thumbscrew which is gradually tightened over the course of the next century.
Old Mar 31, 2023 | 05:12 AM
  #322
luv350sass's Avatar
luv350sass
Awesome, thanks for the suggestions. Yes even the brand new dipstick i got has one bend in it from storage. Its in much better condition than old one. After all this trans stuff its suspension and baseline maintenance, then brakes tires headers and tune! I may not add anymore air mods other than tomei headers, to match the rest of the exhaust. This air intake may suck in hot air, but im not sure if the gains would be worth it replacing it. A bigger throttle body sounds nice, but im worried about it fitting to my intake, without proper sized tubing. I believe my intake is a 2.5in pipe from measuring diameter w tape.
The bushing labor cost will eat me alive, so this may be kind of a slow progressing thread. I hope after tune and all, that i can save money for other vehicles, or a build on the next engine.
Old Mar 31, 2023 | 05:55 AM
  #323
Heel Til I Die
Everyone will tell you that going all out with all the NA mods is going to be more expensive in net hp gains per dollar as opposed to going FI. Now, with that said, I did not go FI and basically maxed out everything other than headers and I'm NA. I might do headers in the future but it is a lot of work for minimal gains. However, I do all the labor myself and I now have a 2-post lift in my garage, so I'll probably get bored in the future and do them, because why not. I like Tomei and will either go with those or Z1.
There's a great debate of true cold air intakes versus "warm air" intakes, or those where the filter sits in the engine bay. It really seems like splitting hairs to me. If the filter is low enough to stay out of the engine bay, then it's in danger of getting wet in my opinion. You can step up to a 3.5" or 4" intake, but you will most certainly need a tune immediately after install. As far as fitting it to your TB, you just need a compatible coupling.
I did the following "breather mods" and it made just over 269 hp at the wheels on the dyno after the tune.
- conical filter
- velocity stack/venturi ring
- 3.5" admin tuning intake
- 75mm TB
- Z1 angled plenum spacer
- Berk HFCs
- Motordyne Shockwave TDX2
Old Mar 31, 2023 | 06:01 AM
  #324
i8acobra's Avatar
i8acobra
I was able to make 281 whp NA with my '06 Rev-Up. That was with every possible bolt-on. I was about to do cams, but traded for a Mustang instead.
Old Mar 31, 2023 | 06:56 AM
  #325
Heel Til I Die
With test or ART pipes and headers, I might be able to squeeze out another 10 or so. I don't really care about numbers, though. My Z is more of a hobby/fun car and just something for me to play with. Might go down that boost rabbit hole when she hits 20 years since NC doesn't require emissions for yearly inspections anymore at that point.
Or just buy that R34 with everyone else
Old Mar 31, 2023 | 07:09 AM
  #326
MicVelo's Avatar
350Z/370Z Tech Moderator
- conical filter
- 75mm TB
- Berk HFCs
You guys are missing out on the most obvious NA improvement.
I saw 450hp at the wheels.
Then it fell off. That was embarrassing.
Old Mar 31, 2023 | 07:22 AM
  #327
travlee's Avatar
travlee
Master
450 hp.... he didnt say the h stood for hamster
Old Mar 31, 2023 | 07:38 AM
  #328
MicVelo's Avatar
450 hamsters is equivalent to about 245 horsepower. You ever watch one of those xhamster wheels spin? Dayam.
Old Mar 31, 2023 | 07:52 AM
  #329
travlee's Avatar
travlee
Master
i see what you did there
Old Mar 31, 2023 | 08:00 AM
  #330
luv350sass's Avatar
luv350sass
Man those numbers are kind of depressing. I was thinking with full boltons and tune, the rev up would make over 3 barely to the wheels, and regular de just a little less than 3. i guess it was that o2 downpipe but i got good improvements on evo with bolt-ons and tune. I knew i didnt change intake, but was forgetting something. I also had to replace clutch and clutch master cylinder, because it couldnt handle it.
I guess for public roadway, i dont need way too much power without a rollcage. may just be tempting and dangerous.
Im reading on that velocity stack and plenum spacer
Old Mar 31, 2023 | 08:08 AM
  #331
Heel Til I Die
That drag coefficient from the emblem effectively negates any real gains.
When it fell off, that should have propelled you forward from the weight savings.
Old Mar 31, 2023 | 08:10 AM
  #332
Heel Til I Die
You're not getting to 300 with "full bolt-ons" on a DE unless you're getting cams.
Old Mar 31, 2023 | 08:38 AM
  #333
travlee's Avatar
travlee
Master
i hit 289 whp on a mustang dyno with my 08
current vette has almost double what my 350 had
Old Mar 31, 2023 | 08:58 AM
  #334
i8acobra's Avatar
i8acobra
Nobody cares about your stupid Corvette.
Old Mar 31, 2023 | 10:02 AM
  #335
MicVelo's Avatar
BUUUUUUUUUUUUUUUUUWAAAAAAAAAAAAAAAAAAAAAAAAAAAHAHAHAHAHAHAHA HAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!
How about my Eurotrash Benz? Can I talk about that? 457 wheel and all. No tune. Just the 80mm upper pulley/stock 168 lower pulley.
Oh butt weight, that travleeCarvette gots 5-hunnert sumpin'.
OK, I'll shut up.
Old Mar 31, 2023 | 10:19 AM
  #336
travlee's Avatar
travlee
Master
haha.. touche
Old Mar 31, 2023 | 02:35 PM
  #337
luv350sass's Avatar
luv350sass
so what do you all think about this? one intake company that sells a 4 inch intake for 350z also offers
Bosch 60lbs Injectors 630cc and 255lphFuel Pump (+ $415.00)
and they say its for e85. whats the power gains or cons of that upgrade
Old Mar 31, 2023 | 06:38 PM
  #338
DarkZ03's Avatar
DarkZ03
I don't think E85 is worth it unless you have a true flex fuel kit.
Old Mar 31, 2023 | 08:53 PM
  #339
mr. sparco's Avatar
mr. sparco
Get a rear diff with 3.69 or 3.9 final drive and be done with it. Best bang for buck to improve acceleration, becuz mechanical torque multiplier. FI if you want over 300, NA on a DE is a lost cause.
Old Apr 1, 2023 | 12:20 AM
  #340
luv350sass's Avatar
luv350sass
Okay cool. i assume it will affect a tune, so ill do it before tune. i still may wait and do brakes and everything first. I did just service my diff.
i dont want to boost it. i just want everything i can milk out of it without spending way too much for 2hp. My engine is only 80k miles, but i still wanted to have a different one built, far down the road if i make it. maybe boost after all of that. By that time ill probably have the whole audio system stripped out for weight, etc. I hope i make it to that second engine, and want someone good to build it. Maybe i should travel for that.
