weird nose
Old Mar 22, 2004 | 11:08 PM
*510*350Z's Avatar
*510*350Z
Default weird nose
have you guys ever heard a squeeking nose when you back up? or another nose for example when you back up and shift your gears back to 1st gear then a clicking nose comes out for a sec? i get kinda affraid that my 350z my be a defect... but i dont think so cuz everything else is cool... please let me know if you guys hear the sounds too... thanks
Old Mar 22, 2004 | 11:28 PM
yobri's Avatar
yobri
If you're referring to the notchiness (and concurrent noise of) of the tranny, it's fairly common. I'm not too sure if the noise that you're getting is the same noise that I tend to over look, but I wouldn't sweat it unless it sounds REALLY bad or gets progressively louder. You could always go to the dealer (close to you Hanlees), but they'll more than likely tell you it's either normal, or they don't hear it. If you are getting a grinding noise, then you MIGHT have a legitimate claim for a tranny replacement.
Nice to see another Richmond-ite on the board
Old Mar 22, 2004 | 11:32 PM
K.G's Avatar
K.G
I also sometimes hear weird noise when I back up but I don't know what it is
I just ignore it
Old Mar 23, 2004 | 06:33 AM
j's350z's Avatar
j's350z
If then noise you are hearing is a tick tick or like a clicking noise, then yes, take it to the dealer. Their is a known problem with the rear axles. Some dealers are just tightening down the bolts and some are rebuiding them. You can hear the noise when going slow from forward to reverse and back and forth......
Old Mar 23, 2004 | 08:46 AM
blowdry's Avatar
blowdry
Could be as simple as the dealer knowing its the axles or a bolt that needs retorquing for the clicking noise, which is a known issue as j's350z stated. In my case the noise was being caused by the spring rubbing a rubber piece. If it's like my noise, it sounds like a bed spring creaking in reverse and acceleration. It took like four visits to my dealer in Torrance, Power Nissan for them to find . Props to Power Nissan, Torrance CA.
Old Mar 24, 2004 | 12:05 AM
*510*350Z's Avatar
*510*350Z
Default i have that same sound actually
that sound you are speaking about is the exact sound i hear when i accelerate or reverse... i dont understand why that noise is there... can you please tell me what was the problem exactly and how may i go about fixing it or how to tell it to the service people at the dealership?
Old Mar 24, 2004 | 03:18 AM
j's350z's Avatar
j's350z
Just go to the dealer and tell them you have the problem with the axles. Their is a TSB on this and they should give you no problem fixing it...
Jason
Old Apr 1, 2004 | 05:43 PM
blowdry's Avatar
blowdry
Default Re: i have that same sound actually
Ooops sorry it has taken so long for me to see this. Anywayz, have you got the noise to go away? To answer what the dealer said they did, supposedly they lubed some rubber piece that the spring is against. But who really knows, I am just glad it's gone. I asked them to check the axles, but they said the axles were unrelated to the problem. Good Luck.
aarrgghh
May 1, 2022 11:04 AM
Uriyo_
Sep 8, 2021 08:46 AM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 18, 2015 05:42 AM
