Stroker Kit
Old Jun 29, 2004 | 05:09 PM
  #201
jreiter's Avatar
jreiter
Originally posted by sausage5000
i know the other thread was about boring the motor out. i did not mention a comparison for boosting or not... i don't know why you mention that. i guess you think i don't know the differences in low compression used for boost VS high compression for N/A.
I don't think it was a personal jab of any sort. From years and years participating in forums like these, I find that many people (myself included) often tend to overexplain things just for the sake of completeness in case other less knowledgeable folks might be reading along in the thread.
Old Jun 29, 2004 | 08:55 PM
  #202
phile's Avatar
phile
exactly
Old Jun 30, 2004 | 01:31 PM
  #203
sausage5000's Avatar
sausage5000
you people are okay... i probably should be flamed hard, as a noob coming at an authorized site vendor like that.
i have to learn to remember that how i picture it in my mind doesn't always make it correct in real terms.
Old Sep 14, 2004 | 03:03 PM
  #204
fineout's Avatar
fineout
so did anyone here actually get one ?
Old Oct 31, 2004 | 08:11 AM
  #205
Machupo's Avatar
Machupo
guess not...
i would love to do this
what kind of cams would you need, would the nismo fairlady ones be appropriate?
arrrgggg... i've got to turn off the internet... more impulse buying...
Old Oct 31, 2004 | 01:25 PM
  #206
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I'm concerned as to why no one has showed up with a kit yet. If they sold out of the first batch, then what is taking so long for people to get them and/or post about it? Does this mean they are already selling into the second or third batch and not one person has contributed any first-hand information?
Old Oct 31, 2004 | 02:45 PM
  #207
joenismo's Avatar
joenismo
You haven't seen any yet because Cometics has yet to sell the headgaskets required for the new bore. I spoke to them last week and the new gaskets have been designed they are just about ready to sell. Probably one more week. Then the machine shops who have the few stroker kits ready to go can finish building their motors.
Old Nov 7, 2004 | 07:42 AM
  #208
RallyBlueWRX's Avatar
RallyBlueWRX
AEBS is a joke. That is all.
Old Nov 11, 2004 | 11:04 AM
  #209
Machupo's Avatar
Machupo
any updates?
Old Nov 11, 2004 | 09:35 PM
  #210
joenismo's Avatar
joenismo
I just spoke to cometics today and they are still waiting on some tool they need to finish production of their headgaskets. So probably another couple of weeks.
Old Nov 14, 2004 | 06:55 PM
  #211
350fanatic's Avatar
350fanatic
in a couple weeks it'll be another month. another month after itll be another couple months
Old Dec 5, 2004 | 09:42 PM
  #212
east1999bt's Avatar
east1999bt
any updates on this kit????
Old Jan 7, 2005 | 05:10 AM
  #213
InjectedPerf's Avatar
InjectedPerf
Injected Performance
Cometic still has not released the head gaskets for the stroker. We had a set of stock ones cut and they look perfect.
-Greg
Injected Performance, LLC
Old Feb 18, 2005 | 07:31 AM
  #214
rclab1's Avatar
rclab1
Default i guess this Stroker kit isn't meant for daily driving?
cant be used for daily driving on 91/93 octane PumpGas????
is this true?
someone said the company made it for drag racing purposes only?
Old Feb 18, 2005 | 07:50 AM
  #215
InjectedPerf
It all depends on the tune. Right now there is not much out there for tuning the 350z. Most companies can't get around drive-by-wire. The ECU we are using will be able to tune the stroker or any modified or stock engine from a daily driver to full out race applications. The stroker motor that we are installing will have maps for full race gas and also for 93 octane.
-Greg
Old Feb 18, 2005 | 08:06 AM
  #216
jeffw's Avatar
jeffw
-Greg
Is your stroker for NA for FI? What compression are you running? Also, what ECU are you using? Do the anti-lock brakes and VDC still work?
Thanks and good luck with your project.
Jeff
Old Feb 18, 2005 | 08:13 AM
  #217
InjectedPerf
Jeff,
The stroker is setup for forced induction. The compression is 8.5:1. We are designing a plug and play ecu for the z using the Magnetti Mirelli ecu. This is the same ecu used in F1 cars. It will actually be very affordable compared to other engine managements on the market. We will either be offering a piggy back system so your VDC and everything else would work or a stand alone system. We will know within the month what is the best option to provide.
-Greg
Old Feb 18, 2005 | 09:12 AM
  #218
jeffw's Avatar
jeffw
Jeff,
-Greg
I think I've heard of people setting up a stand-alone ECU that passes thru data to the stock ECU to get VDC and everything to continue to work. The stock ECU is ignored in terms of engine control. I'm just curious if that trick truly works. Seems like the stock ECU might figure out things aren't working correctly in open loop situations and flake out (e.g. emissions feedback).
Thanks,
Jeff
Old Feb 18, 2005 | 12:39 PM
  #219
Brandon@Forged
Z1 Auto has a customer that has an AEBS stroker kit, and GReddy 20G turbo kit. Just recently had an accident in his Z and now is building the G35c up.
Old Feb 18, 2005 | 01:00 PM
  #220
sentry65's Avatar
sentry65
the burninator
hmm that's too bad
does anyone have any info on what numbers he was putting down
was the accident caused by having so much power or was it something else?
