Stroker Kit
Old Apr 12, 2004 | 08:35 PM
  #141
frenzee's Avatar
frenzee
Originally posted by redva350z
what would be the best way to control fuel and everything for a stroker kit?
You'll probably need larger injectors (e.g. PE) and will very likely need to remap your ECU (e.g. TechnoSquare), although a piggy-back may also work.
Old Apr 12, 2004 | 08:46 PM
  #142
JPizzle's Avatar
JPizzle
want dynos
Old Apr 13, 2004 | 02:00 AM
  #143
Rob Nance's Avatar
Rob Nance
Originally posted by Z1 Performance
show me an H22 street car that makes 850 hp...
this is getting useless..PM me if you want to talk about it further
You've got as short of a fuse as the people I work with from the NorthEast. Is stress a big problem up there or what?
Old Apr 13, 2004 | 02:02 AM
  #144
Rob Nance's Avatar
Rob Nance
Originally posted by MySunset350Z
all i have to say is.......WOW!!!
still need some hard #'s with hp and tq outputs. the price range is pretty close to the cost of a TT. it should be able to put out as much hp and tq as the TT to be worth it. no one is going to pay more money for less power just to stay N/A. of course that is unless you have money to burn, which i dont.
That is hugely incorrect. I know a lot of people willing to pay more for FI performance from a NA setup.
Old Apr 13, 2004 | 02:22 AM
  #145
Rob Nance's Avatar
Rob Nance
10min edit is retarded. Anyhow, I guess you weren't as worked up as it appeared, disregard.
Old Apr 13, 2004 | 09:00 AM
  #146
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Nah I am not worked up at all, I just ahve zero patience for misinformation being spread.
Old Apr 13, 2004 | 01:58 PM
  #147
ThoughtZ's Avatar
ThoughtZ
I'm looking to do this mod within a month, does anyone know any compitent shops in Florida or clsoe proximity that could pull off this machine work? I've had my share of Z modification trips lol.
Old Apr 13, 2004 | 01:59 PM
  #148
JPizzle's Avatar
JPizzle
carexcess?
Old Apr 13, 2004 | 02:03 PM
  #149
ThoughtZ's Avatar
ThoughtZ
nah they don't really deal with performance i've been there a few times i want experienced engine workers, this is a hit or miss mod imo and i don't want the miss
Old Apr 13, 2004 | 02:22 PM
  #150
AboostedG's Avatar
AboostedG
Twin Spoolin
Velocity Resources in Orlando.
Old May 10, 2004 | 10:14 AM
  #151
sflg35's Avatar
sflg35
KP Technologies
maybe zfever in tampa or secret services in clearwater.
Old May 10, 2004 | 10:25 AM
  #152
Z1 Performance
Former Sponsor
If it were me, doing it mailorder, I would have AEBS do the ful install for you as well 9though they are a busy shop, its your best bet, and at least parts and install would be from teh same place).
You have to send them a block in order to purchase the kit anyway (so they can install the sleeves), so at that point, best bet is having them install everything else too. If I were unsure who to use locally, that's the route I would go.
For guys local to us (Tri State area), we can arrange for the install of this kit with our engine builder, who is in upstate NY
Old May 10, 2004 | 11:11 AM
  #153
Traffic's Avatar
Traffic
Can't wait to see some dyno numbers for this kit, esp the 11.5 setup. Anyone care to guess at what it could put out?
Old May 10, 2004 | 04:13 PM
  #154
ether's Avatar
ether
here is my guess.. a 4.4L 11.5 CR with intake, plenum, cams, headers, cats, exhaust upgrades.. 340 rwhp
here are some more pictures of the setup.. this is from a show in Japan.. tomei will be distributing this over here
http://www.tomei-p.co.jp/tomeib/tp/vq44.htm
http://www.tomei-p.co.jp/tomeib/tp/vqcylinderb.htm
Old May 10, 2004 | 04:44 PM
  #155
ThoughtZ's Avatar
ThoughtZ
I'd imagine around 360-370 w/o those aforementioned additionals. Really no way of knowing I guess.
Old May 10, 2004 | 05:05 PM
  #156
ether's Avatar
ether
yupp I guess the question is really who is going to be 1st.. my guess is conservative.. want to be pleasantly surprised
Old May 10, 2004 | 05:27 PM
  #157
johnny2105's Avatar
johnny2105
what else would have to be upgraded, to handle this size motor.?????? how much gas mileage would you even get?
Old May 10, 2004 | 05:37 PM
  #158
ThoughtZ's Avatar
ThoughtZ
Injectors, probably your fuel pump, to be safe y-pipe and cat back piping ( 3" ), gas mileage would go down because you figure you've essentially got a v8 at that point. However, if you upgrade your air intakes, maybe even add a intercooler and a plenum you could possible balance it out to near stock mpg numbers. I'd really like to see some pure na numbers on this mod or even a slightly modified na setup with the kit on it. In the mean time I'm working OT to try and buy this puppy by the end of the year. I can only imagine the implications the combination of this and my TT could form.
Old May 10, 2004 | 06:21 PM
  #159
turbo-maxima's Avatar
turbo-maxima
I am sure you can get 450-500 whp with vq30 heads, cams, custom headers with 3 inch collectors and 3 inch catback. intake manifold, and maybe some sort of water/alchohol injection to keep detonation down with the high compression, it should increae gas milage, and keep the engine clean.
Old May 10, 2004 | 06:29 PM
  #160
bigern1970's Avatar
bigern1970
Default AEBS FACILITY
heres the AEBS GURU with the t sleeve.its beefy
