new ecu and the immobilizer system
Old May 6, 2004 | 06:21 AM
g356gear's Avatar
g356gear
Default new ecu and the immobilizer system
Does anyone know if the 350Z ecu is coded directly to each ignition immobilizer/key type.....or is the key simply paired with an individual ignition module in the steering column??
Old May 6, 2004 | 06:37 AM
PoWeRtRiP's Avatar
PoWeRtRiP
i believe that the ecu is coded to the chip in the key, not a key type, ask technosquare or chebosto for more details they know a lot about the ecu in the z
Old May 6, 2004 | 07:27 AM
2003z's Avatar
2003z
the ecu comes uncoded, the minute you put your key in the ignition for the first time, it matches up to the key/car.
Old May 6, 2004 | 08:00 AM
g356gear's Avatar
g356gear
And what if the ecu has been used in another car first??
Old May 6, 2004 | 08:33 AM
mpowers's Avatar
mpowers
Then you will need to have it programed to the key.
Old May 6, 2004 | 08:44 AM
alphared's Avatar
alphared
Wait, isn't the security in the BCM (Body Control Module) and not the ECU?
Old May 6, 2004 | 12:14 PM
2003z's Avatar
2003z
if its been used in another car, it needs to be reset. My experience is from going back and forth with technosquare. THey sent me a loaner ecu once, and then they did an ecu reset on my car's ecu while it was in another car after doing the immobilizer reset. It didn't work on mine and had to be sent back.
Old May 7, 2004 | 05:34 AM
g356gear's Avatar
g356gear
Can the dealer reset the ecu?? They should be able to if someone ever had to change a key set for a car.
Old May 7, 2004 | 06:17 AM
2003z's Avatar
2003z
they should be able to, if it hasn't previously been reprogrammed by Technosquare or someone else.
sales@czp
Sep 23, 2019 03:30 PM
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
