ECU... what does restarting it do?
Old Jun 7, 2004 | 10:55 AM
hyuk81's Avatar
hyuk81
Default ECU... what does restarting it do?
sorry if this is a repeat post... just wondering why people reset their ecu... do you have to do it everytime you add a mod?
Old Jun 7, 2004 | 11:06 AM
ares's Avatar
ares
Veteran
you dont have to ever do it.
I donno if its proven or not, but some think the ecu learns from the data it recieves, we KNOW it learns from the way you drive(if you baby it, it will baby itself) specificly automatics for example, it will shift at a lower RPM if you never floor it, itll just be harder and harder to get it to rev. if you floor it constantly when you dont, it is likely to still shift high.
I dont think anyone knows exactly how long the memory is or how easy it is to change its patterns. but reseting the ECU basicly lets you start at ground zero; clean slate, the car learns its first set of data from that moment on.
cliffnotes: might not help, but definitly doesnt hurt, easy to do. why not then.
Old Jun 7, 2004 | 11:13 AM
maximumsportZ's Avatar
maximumsportZ
Whats the best way? Pull the negitive off the battery over night? or reset with the pedal method??
Old Jun 7, 2004 | 11:16 AM
ares's Avatar
ares
Veteran
Id go with the pedal method, I havent done it though. just rather have instant gratification than pulling the battery. also pulling the battery loses all your presets, where the pedal method is a bit more direct.
Old Jun 7, 2004 | 11:21 AM
DUKE's Avatar
DUKE
350Z ECU Resetting Procedures
http://www.technosquareinc.com/350reset.htm
Old Jun 7, 2004 | 11:23 AM
hyuk81's Avatar
hyuk81
thanks...
Old Jun 7, 2004 | 03:41 PM
ypwpat's Avatar
ypwpat
So after reseting the ECU.
The ECU have to learn everything on my car from state 0? Like putting a UR pulley have to let the ECU to adapt to it.
Old Jun 7, 2004 | 03:52 PM
maximumsportZ
I thought reseting the ECU means just resetting a error code not maps??..
etkms
Jun 19, 2022 06:30 PM
tjhands
Dec 28, 2004 07:41 AM
b3n84
Apr 28, 2004 05:15 PM
