Changing the Differential / Transmission Oil
Old Jun 2, 2008 | 09:38 PM
  #281
saberphx's Avatar
saberphx
Dumb *** question but how many quarts you need for the tranny? Bout to change out my diff and trans fluid.
Old Jun 2, 2008 | 10:41 PM
  #282
PhiSig's Avatar
PhiSig
Wheel Whore
^ Read the Thread -- buy 4, you should use 3 and some change
Old Jun 3, 2008 | 08:23 AM
  #283
Swiffer's Avatar
Swiffer
4 for the trans, 2 for the diff. Oh, and make sure that you have a suction gun...it makes a big difference!
Old Jun 3, 2008 | 08:46 PM
  #284
SponGer's Avatar
SponGer
Originally Posted by PhiSig
Still up in the air about everything after reading this post front to back AGAIN.
Would prefer the redline products, but some people are reporting the MT90 is no good, others say something else. Sounds like the 50/50 mix is working ok.
Now for diff, I still am left up in the air now as well, after seeing some people say the redline diff fluid is no good either.
Anyone running anything they REALLY like alot???
I'm using the Redline 50/50 mix (MT90 and MTL) in my tranny and am pleased.
Old Jun 5, 2008 | 01:10 PM
  #285
raf84ny's Avatar
raf84ny
For the MT should I mix all 4 quarts together prior in one separate container (2QT Redline MTL: 70W-80GL-4 and 2QT Redline MT-90: 75W-90 GL-4) and then put it in to the tranny? I think that the tranny only takes a lilltle bit more than 3 QT and I want to keep the proportions of the two equal. What should I do?
Old Jun 5, 2008 | 06:28 PM
  #286
SponGer's Avatar
SponGer
Do one quart each and then combine the two in one of the empty containers.
Old Jun 6, 2008 | 02:03 AM
  #287
quakerroatmeal's Avatar
quakerroatmeal
I don't get what the purpose of mixing anything is? Why not just buy the specific fluid so you won't have to mix anything? Been two weeks since I have changed mines, Motul Differential, OEM Nissan Tranny Fluid, works great so far.
Old Jun 6, 2008 | 01:22 PM
  #288
raf84ny's Avatar
raf84ny
Well, Red Line Fluids are preffered over Motul and showed better results. Red Line fluids have the appropriate coefficient of friction for most manual transmission synchronizers (many gear oils, engine oils, and ATFs are too slippery for proper synchro engagement). And, the wide viscosity of MTL and MT-90 allow proper shifting over the entire temperature range which the transmission will experience. The synthetic base oils used have a very high viscosity index which provides relatively constant viscosity as temperature changes.
I've ordered mine for MT and differential. Can not wait to replace them.
Old Jun 8, 2008 | 03:33 PM
  #289
quakerroatmeal
I've read through most of the threads, I there are some bad things said about the Redline MTF. I just went with OEM for tranny fluid anyways.
Old Jun 9, 2008 | 12:27 PM
  #290
Fluid1's Avatar
Fluid1
If you use Motul, the bottles have semi-funnels built-on. I didn't need a suction gun.....
Anyone use Mobil 1 75w 90 synthetic for diff oil? I have an open diff but I'd like to see what people use.
Old Jul 27, 2008 | 07:27 PM
  #291
03aeroZ's Avatar
03aeroZ
didn't really find anything that said what was better for a daily driver, never tracks...any input?
also, if i do the amsoil, do i need the additive for an 03 touring?
Old Aug 1, 2008 | 04:23 PM
  #292
PhiSig's Avatar
PhiSig
Wheel Whore
Just did mine last weekend. 50/50 redline mix seems to be working great, I am pleased. The fluid I pulled out of both the trans and lsd seemed fairly clean which was good I guess. Very pleased with the end results -- no issues to report. Now clutch fluid and coolant is next on my list.
Old Aug 9, 2008 | 08:08 AM
  #293
SnyperZ's Avatar
SnyperZ
What do you guys think of royal purple MAX-GEAR 75W-90 synthetic?? On the back it says meets both GL-4 and GL5 req. And that its non corrosive for gl4. I have 29,000 miles on my car and the trans fluid.....hoping this makes a difference.
Old Sep 1, 2008 | 06:18 PM
  #294
nick2730's Avatar
nick2730
ok im an auto noob when it comes to hands on experiance, i understand everything just need some clarification before i go and screw something up. Ok is the tranny and diff housed seperatly or are they in the same casing. car is 2003 bout 33k miles never had tranny fluid replaced so i bought 4q of redline fluid which they reccomended. I understand i drain and then use suction gun to refill, but i dont get where the differential comes into play? Is it just teh same procedure just a different location or same thing wtf. Please helpage thanks
Old Sep 1, 2008 | 06:41 PM
  #295
nick2730's Avatar
nick2730
Also i have after market headers, and have noticed the car shifts ok when colder but once it gets warm its gets clunky and notchy not grinding at all, redline fluid has a high heat tolerance and should cope with it better right? Also does the added heat from headers effect clutch, clutch master cyl or the fluid line? After a while the clutch seems to get wierd i dont know how to explain it like a spongy feeling
Old Sep 3, 2008 | 05:39 AM
  #296
VQdriver's Avatar
VQdriver
i'm like you, a car enthusiast, but i would suggest you read up about the various BASIC mechanical components of any car. remember, the 350z is rear wheel drive (RWD). so that would mean the differential gear would be on the rear axle. here, enjoy:
http://en.wikipedia.org/wiki/Differe...hanical_device)
also:
www.google.com
Old Sep 3, 2008 | 12:58 PM
  #297
SlipZ's Avatar
SlipZ
this thread is ver y useful!, my question is, i used Valvoline high performance 80w-90 GL4,GL5,MT1 oil for the tranny is this OK???. Its notchy in the morning but other than that its smooth once warmed up. On the diff i used Mobil 1 LS 75w-90 synthetic GL5.
please confirm,
Thanks
Cris
Old Sep 17, 2008 | 03:30 PM
  #298
chia's Avatar
chia
What do you do with the drained oil? Do recycling centers take this stuff?
Can I drain both oils together into one pan and still dispose of it safely?
Old Sep 17, 2008 | 03:39 PM
  #299
dnguyent's Avatar
dnguyent
Transmission and diff fluids can be recycled with motor oil. One of the few fluids that cannot be dumped with motor oil is brake fluid.
Old Sep 26, 2008 | 07:45 PM
  #300
jserman's Avatar
jserman
did this today changed both the trans and diff... my trans was starting to shift funny so I figured it was time for a change... I have an 04 G35 6MT and it has 48K miles on it so I am sure it was the original fluid...
I used Royal Purple Max Gear 75w-90 in both the trans and the diff...
trans shifts like butter now car is driving like a champ.....
