5AT to 6MT Swap INFO, ***, DIY, GUIDE Thread!
Old Mar 21, 2015 | 02:17 PM
  #101
Steven Sampaga's Avatar
Steven Sampaga
Love the write up!
Old Jul 13, 2015 | 06:29 AM
  #102
AbyteZero's Avatar
AbyteZero
Here what I did to bypass the clutch pedal on my G35 sedan, which is almost the same car...
Context:
G35 Sedan A/T 2003 with parts from Coupe M/T 2003 [ Engine + Transmission + Computer (driver side under the steering) + Computer (passager side over his feet)]
Note that the wires numbers may be slightly different.
Just connected #26 to #43 according to this document and it works :-D
So I jumped inside the IPDM box the wire #43 to the empty #26 (because IPDM from the G35 sedan A/T)
Page 12
http://www.nicoclub.com/FSM/G35/Sedan/2003/sc.pdf
Old Aug 11, 2015 | 05:32 AM
  #103
yosip1115's Avatar
yosip1115
Originally Posted by Resmarted
What?
Theres a fawking plug on the OEM auto, that is identical to the plug on the manual. You just cut the factory wire in the middle somewhere and extend it.
I don't even know what you guys are on about
Then what was the OP talking about with the green/orange striped wire? If you can just use the PNSS wires from the AT harness why would you think about tapping into the green/orange stripe at the ECU to run to the PNSS on the MT?
I found a green/orange stripe under the steering column but I'm doubtful that is the same green/orange stripe. Looking for a good place to tap into that wire that isn't at the ECU for ease of install, unless what you are saying is true (confirming my theory earlier) It's tough figuring this ish out without the AT around anymore. Please confirm that there is one to extend from the AT harness for both the PNSS and the reverse lights or I will dig for the ECU so my cruise control will work.
Thanks
Old Nov 12, 2015 | 08:49 AM
  #104
thatone350z's Avatar
thatone350z
Default re-flash
I have all the parts to do a 6 speed manual swap but do I absolutely need to reflash my Auto ECU?
Old Nov 12, 2015 | 09:05 AM
  #105
thatone350z
Originally Posted by JaE35z
thanks for all the helpful information, the swap i was inquiring about is up and running
did you reflash your ecu?
Old Nov 12, 2015 | 09:40 PM
  #106
drvqz33's Avatar
drvqz33
No you don't. 5AT ECU will work just fine. If any codes pop up, you can always clear them for good. I'm using the 5AT ECU, and have not had any issues.
Old Nov 16, 2015 | 02:34 PM
  #107
thatone350z
thank you so much haha you just saved me so much time and money but last question, so your running the 5AT harness as well? or did you go with the 6MT harness
Old Nov 19, 2015 | 11:34 AM
  #108
jdm-v35's Avatar
jdm-v35
You use the 5at harness, only thing is cruise control wont work unless you connect the neutral position switch. and you need to wire up the reverse lights and IPDM.
Old Jan 4, 2016 | 12:07 PM
  #109
Edd132's Avatar
Edd132
Default Rubber Grommet w/bracket - OEM from any MT Nissan.
Do i need this?
What is it exsactly?
Where does it go ?
Old Jan 11, 2016 | 02:11 PM
  #110
yosip1115's Avatar
yosip1115
Default High Idle
Anybody experience a high idle after swapping?
95% sure it is not a vacuum leak, did some testing (smoke test)
Idle is smooth, just sits at ~1050
Wondering if I need to hook up the PNSS wire to get rid of this, but the car's in hibernation for the winter.
p0507
Edit: It was the PNSS. Perhaps mine was different since it was a G35X, but I swapped the engine/tranny into a Z and it worked fine without a high idle.
Old Jan 12, 2016 | 07:22 AM
  #111
DEMoLITIoN's Avatar
DEMoLITIoN
Originally Posted by Edd132
Do i need this?
Where does it go ?
It covers the shifter hole when you switch to 6MT shifter hole
p0507
My idle is fine with 5AT everything. A few years later and my 6mt swap is wonderful.
Old Jan 12, 2016 | 07:38 AM
  #112
yosip1115's Avatar
yosip1115
Did you hook up the neutral safety switch wire? I may have to contact my tuner. He kept blaming it on vacuum leaks... A lot happened at once... New motor, 6MT swap, TT kit. Runs fine, perfect, just idles high.
Edit: it was the PNSS
Old Jan 12, 2016 | 01:35 PM
  #113
DEMoLITIoN's Avatar
DEMoLITIoN
No, I didnt wire up PNP (used for cruise control) or my reverse lights. They absolutely have no effect on engine operation.
Old Jan 14, 2016 | 06:00 PM
  #114
yosip1115's Avatar
yosip1115
Interesting, thanks for helping me clear that up. Saves me some time and disappointment.
Edit. Hook up the PNSS. It was what caused my high idle issue and p1000
Old Feb 15, 2016 | 04:04 PM
  #115
thatone350z
Default wont start
i did this swap im at the end of finishing it but car wont start it cranks fast but wont fire
Old Feb 15, 2016 | 07:12 PM
  #116
Edd132's Avatar
Edd132
Default Same here.
Im finished with it, and my car turns on after a few trues but i have a me hanic coming to look at it tomorrow .
Old Feb 16, 2016 | 06:29 AM
  #117
DEMoLITIoN's Avatar
DEMoLITIoN
how did you guys do the wiring?
Old Feb 16, 2016 | 08:54 AM
  #118
thatone350z
i tested the spark and found out i dont have one so im pickin up spark plugs today ill let you guys know how it goes
Old Feb 16, 2016 | 12:24 PM
  #119
Edd132's Avatar
Edd132
Default Plugs arent it
I have new spark plugs. I did it from the ignition to the switch nd then to gray nd red wire
Old Feb 18, 2016 | 07:14 AM
  #120
thatone350z
i did a manual/new VQ and i guess i ****ed the cam position sensor up in the process pluggin the harness bqck in so i replaced them and it started right up, thank you for the write up just perfect haha
