Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Jul 19, 2011 | 01:47 PM
  #241
Quamen's Avatar
Quamen
Originally Posted by Royal_T
Thanks for the info.. I will do the same for the windows too.. Also I like the idea on the lights turning on when the car is running.. So you are just going to route the lights to the fuse panel? Would like more info on this.
Thanks
I will post some pictures soon and a bit more info. It was actually quite easy to do.
Old Jul 21, 2011 | 07:17 AM
  #242
can'tZme's Avatar
can'tZme
Where are you guys finding your LS2's? And what year are they? I was told by a diehard LS guy to go with a 05+ but I'm having trouble finding exactly what I want.
Old Jul 21, 2011 | 12:14 PM
  #243
Cass007's Avatar
Cass007
I found mine on EBAY from a company called LKQ. If you want an LS2/T56, then what you want is the 05-06 dropout from a GTO. That is exactly what I got for $6600 delivered.
Old Jul 21, 2011 | 02:19 PM
  #244
can'tZme's Avatar
can'tZme
Ok I will check them out, thanks.
Old Jul 21, 2011 | 03:31 PM
  #245
Quamen's Avatar
Quamen
ARP head studs and ACL main/rod bearings just came in! Crank, rods and pistons should be here soon!
Old Jul 21, 2011 | 11:42 PM
  #246
bbs350z's Avatar
bbs350z
quamens gonna have 2 ls builds done before i finish mine lol. im so slow
ps what crank you using??
Old Jul 22, 2011 | 03:50 AM
  #247
Quamen's Avatar
Quamen
Callies Compstar
Old Jul 26, 2011 | 04:07 AM
  #248
Quamen's Avatar
Quamen
Thanks
I finished my turn signals last night. I figured out the pun out to make the stock switch on the column work but the switch doesn't allow much current. You would have to run the ground for a coil on a relay through the stock switch. That relay would then supply power to the blinker relay.
Or you could just run a toggle switch like I ended up doing. Much easier in the end. Then you don't need the extra relay. Just the blinker relay.
Old Jul 26, 2011 | 10:20 AM
  #249
can'tZme's Avatar
can'tZme
Well I've found me a ls2 dropout from a 06 GTO with 5,500 miles on it. It comes with everything except the ecu. What can I do about the ecu?
Old Jul 26, 2011 | 01:19 PM
  #250
Cass007's Avatar
Cass007
Just source it online or from a junkyard. Or you could run a stand alone and not bother with the ECU at all.
Quamen... I don't need to disable the VATS system if I run a stand alone correct?
Old Jul 26, 2011 | 03:03 PM
  #251
Quamen's Avatar
Quamen
Nope. If you run a full fuel and ignition standalone therebis no need to disable it.
Old Jul 27, 2011 | 04:02 PM
  #252
Royal_T's Avatar
Royal_T
Okay started my build thread today.. So stay tune for all the good info...
https://my350z.com/forum/engine-and-...nuff-said.html
Also thanks Cass for the info..
one last thing.. I think we should post everyones build thread link at the beginning of this thread so people can reference them. thoughts?
Old Jul 27, 2011 | 04:58 PM
  #253
Cass007's Avatar
Cass007
You are welcome sir!!
Links to build threads added to first post of thread. BTW, we are kicking around the swap forum again. Our little crowd keeps getting bigger.
Old Aug 2, 2011 | 04:26 AM
  #254
can'tZme's Avatar
can'tZme
Quick question: would the SIKKY kit work for an 07 z? It doesn't say on their website if it does or doesn't.
Old Aug 2, 2011 | 06:15 AM
  #255
Quamen's Avatar
Quamen
I would assume so because I believe the cross member is the same. Not sure about the sheet metal in the tunnel though as the exhaust is a bit different and there could be interference with the headers. I would give Sikky a call and see what they say.
Old Aug 2, 2011 | 11:26 AM
  #256
bbs350z's Avatar
bbs350z
for those of you going with the sikky wiring service, here is what i have come down to. after installing all the proper plugs to there sensors, i was left with a few more sensors, kinda wondering what goes where. (i left the maf/iat sensor out as those were pretty obvious)
crank sensor on right rear of motor (behind starter)
oil level sensor (not needed-just checks oil level and doesnt work on our cluster anyways)- and the purple starter wire. the starter wire hole is only sized to fit on the smallest threading on the back of the starter so you cant really mess it up.
reverse light sensor-front right side of the trans
these were the egr and ac wiring-uesless for this application. im choosing to leave these in case i cant get the factory z ac unit to work on this motor
more egr wiring
and the motor as it sits now. touching up a few things so it looks neat and tidy, moving the fpr, and welding my intercooler piping as well as finding a place to hide my coils. this harness is actually very simple and straight forward
Old Aug 2, 2011 | 12:00 PM
  #257
can'tZme's Avatar
can'tZme
I emailed them and he said I should have no problem.
Old Aug 2, 2011 | 12:11 PM
  #258
Cass007's Avatar
Cass007
Nice bbs... coming along well. I am trying to make a decision on what route to go with the wiring now. Thanks for the info on the plugs. Did SIKKY send a diagram or label the plugs at all for you?
BTW, what did you use to make the hole for the clutch line.... a screwdriver
Old Aug 2, 2011 | 04:11 PM
  #259
bbs350z's Avatar
bbs350z
they only labeled the 350z ac (which i asked them to keep) fan high and fan low, no diagram or anything. the harness was pretty self explanatory once it was placed on the engine. the factory injector clips are all labeled on the clip themselves, its not a rat nest like the factory z harness!
and that hole... my girlfriend used her nails i was out of tools, and time so i used a drill and some pliers lol. its getting smoothed out and a proper grommet in there eventually
Old Aug 2, 2011 | 07:37 PM
  #260
Quamen's Avatar
Quamen
Buy a unibit...
