Engine Swaps For all your engine swap experiences, ideas, questions, & more..
The Official LS Swap Info/Questions Thread
Old Jun 9, 2011 | 10:31 AM
  #41
Cass007's Avatar
Cass007
Quamen, you said you had that intake laying around, can you say what kind it is and where you got it? Thanks.
Old Jun 9, 2011 | 10:46 AM
  #42
Quamen's Avatar
Quamen
It was just some cheap $30 China twin intake tube that I found on Ebay last year. The thing was powder coated green when I got it. The intake was originally straight from the merge point backwards. I cut it shorter and welded on the downward bend that allows the intake to angle downward.
Old Jun 9, 2011 | 01:19 PM
  #43
bbs350z's Avatar
bbs350z
Originally Posted by Quamen
This weekend bbs is coming over and I'm going to modify his stock 350z pedal to work with the cablE throttle body. Good opportunity for a small write up.
yep complete with pictures and all!!
and im super jealous of your radiator fitment
Old Jun 11, 2011 | 01:41 PM
  #44
TehkMob's Avatar
TehkMob
Finally did it, Ordered my Engine today. Picked up a zero mile, ASA LS1 engine, rated for 450hp. Only decided to go with this because I've hear alot of Minute mod brings this engine to 550-600 hp. So!! I'm trying to get my wap in and running by july 17, My B-day. Plus decided building a engine isnt in my budget for my goals, so this is a humble start.
Looking forward to getting this bish going. Been too long coming.
What ignition royal? And i wanted those ast's...!
Old Jun 11, 2011 | 02:01 PM
  #45
Cass007's Avatar
Cass007
Congrats... mind sharing a link to where you purchased and the price paid to help others make decisions?
Don't get too crazy. My research suggests that somewhere over 450hp the stock internals should be upgraded. The block doesn't need to be bored, just forged internals swapped in.
Old Jun 11, 2011 | 02:36 PM
  #46
TehkMob's Avatar
TehkMob
I picked it up from a old hotrod guy off ls1tech. Paid 4k longblock with all accessories. These engines are discontinued. I believe the ASA stock car series went with another route. This comes with forged internals, 226/236 cam .525 and lingenfelter heads.
Fisrt mod, new intake and Throttle body + tune.
Early goals 550-600 hp NA
12-18 month goal TTLSX 850-900 (pump gas) 950-1100 on race.
Old Jun 11, 2011 | 06:33 PM
  #47
TehkMob's Avatar
TehkMob
Swap out to cadillac cts v accessories, Best clearance.
Old Jun 11, 2011 | 06:37 PM
  #48
bbs350z's Avatar
bbs350z
eventually, and i also eventually wanna get a remote power steering resevoir. right now i just wanna get this damn thing running! only thing holding me up is my intercooler piping and waiting on my wiring to return from sikky.
also fyi for everybody, you need your factory ls1 security settings on the ecu disabled to start up. i am going through benchmark tuning in illinois for that as well as a complete tune. there are other places i found online who can do it. cheapest security disable ive found online was $110 + shipping
Old Jun 15, 2011 | 05:40 AM
  #49
Royal_T's Avatar
Royal_T
^^ thanks for the info.. Also if you want a remote power steering reservoir look into KRC.. they have the best products and I love my Drift power steering pump.
Old Jun 15, 2011 | 06:50 AM
  #50
Quamen's Avatar
Quamen
I am actually suprised that more people other than me haven't tried using the stock 350z pump and reservoir.
Two simple aluminum spacers and pounding the stock 350z bracket flat and you can bolt the pump directly to the block/heads.
You can see in the first picture that I took the factory 350z zinc plated bracket and pounded it flat. Then there is one long spacer at the top and one short one at the bottom (Actually the middle spacer right below the head in the first picture).
Old Jun 15, 2011 | 07:01 AM
  #51
Royal_T's Avatar
Royal_T
^^ Very nice,, I never really thought about using the 350z factory PS.. I just wanted to upgrade due to me hitting the track a lot once done..
Old Jun 15, 2011 | 07:43 AM
  #52
Quamen's Avatar
Quamen
And the KRC unit is darn nice to say the least!
Old Jun 15, 2011 | 12:38 PM
  #53
10-E-C-350Z's Avatar
10-E-C-350Z
sub'd. anyone here using HPtuners?
Old Jun 15, 2011 | 12:53 PM
  #54
Royal_T's Avatar
Royal_T
^^ I think most are,, I know I will be running HP tuning..
Old Jun 15, 2011 | 01:35 PM
  #55
Cass007's Avatar
Cass007
Put some accurate measurements to this please. What spacers,what size holes and what lengths... this is the info we need to give others options. Thanks Quamen.
Also, I saw the retro fit answer, why JB weld? My old oil pressure and temp sensors were fine with just some plumbers tape.
Old Jun 15, 2011 | 02:38 PM
  #56
Quamen's Avatar
Quamen
I can try to take some measurements this weekend. The length will vary depending on the crank pulley you use though.
JB weld is just my personal preference since I have never had a failure. With taper threads like NPT and BSP I feel it's safer since you don't have tighten them as much and risk hairline cracks in the castings (i.e. a common issue with the VQ oil sensor port).
Old Jun 15, 2011 | 05:24 PM
  #57
Rambo's Avatar
Rambo
subscribed. I will be doing this swap in my G this winter. Learning all that I can now!!!
Old Jun 16, 2011 | 09:54 AM
  #58
STL 350Z's Avatar
STL 350Z
Sub'd. Will be saving for the swap kit and engine this coming winter.
Old Jun 16, 2011 | 11:36 AM
  #59
str8dum1's Avatar
str8dum1
you can still remove the sensor with JB weld on the threads?
Old Jun 16, 2011 | 01:46 PM
  #60
10-E-C-350Z
What is everyone doing for the fuel system? does it require a return system? If so, I assume a basic AAM unit would work fine, right?
