Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Jun 28, 2015 | 09:49 AM
  #401
midz350's Avatar
midz350
Just received the Hoke Shifter Relocation Mount and should pick up the Collins adaptor later today.
Made from billet 6061 and the finish is amazing. Thanks for Austin and his outstanding business.
Will install above + AC + cams and springs later this month at a different shop.
This kit will keep the reverse lockout feature.
Some pics of the car ready to be picked up
I need a bigger FMIC!
The wheels fit nicely. 19"×10" +15 Fronts 19"×11" +15 Rears wrapped in ContiSportContact
Old Jun 29, 2015 | 12:29 AM
  #402
midz350's Avatar
midz350
And the Collins adaptor kit is finally here. Thanks Brett.
Attached Thumbnails My 2JZ-GTE VVTI swap thread.-img-20150629-wa0011.jpg   My 2JZ-GTE VVTI swap thread.-img-20150629-wa0015.jpg
Old Jul 9, 2015 | 02:11 PM
  #403
midz350's Avatar
midz350
Filter installed.
Just sent the car to the other shop to install the Collins adaptor, Hoke shifter relocation kit, Titan 272 cams + BC titanium springs, A/C, change the TB since this one isn't closing fully. I might even let them tune it on the dyno.
Still not sure how to get the OEM water temp gauge to work sine I removed the engine harness completely!! I don't want to run an after market one.
Old Jul 9, 2015 | 03:29 PM
  #404
NOLAGG's Avatar
NOLAGG
Looks sick mid, who are the guys doing all the work
Old Jul 9, 2015 | 05:25 PM
  #405
midz350's Avatar
midz350
A shop in a different city that I should have went to from the beginning. It would be probably finished almost 20 months ago. They install 2jz/RB into everything.
Old Jul 10, 2015 | 08:33 AM
  #406
Highway Riding's Avatar
Highway Riding
Man don't feel bad. Shizz happens. I had similar issues with a few shops in the past. In the end almost all cut corners and or just stop giving a eff when they run into little issues that require thinking or just a little research. Once I removed the twins myself I started notice this myself first hand. Kinked wastegate lines, loose sway bars, missing motor mount bolts etc... Felt violated to be honest LMAO!
Old Aug 13, 2015 | 12:05 PM
  #407
Pengu's Avatar
Pengu
Any updates? Loving the build, been reading through most of them today haha.
Old Aug 13, 2015 | 01:36 PM
  #408
midz350's Avatar
midz350
The engine and tranny are out and they sent the head to the machine shop to install the springs and cams.
This shop is in a different city than where I live and too busy to visit them.
They will do everything that is not finished yet and install the AC.
Old Aug 16, 2015 | 07:54 AM
  #409
midz350's Avatar
midz350
Just my luck, this thing rarely happen to the timing gear in the 2JZ and mostly happens at high power/RPM situations.
So we weld it like Titan do:
Also found most of the rod bolts were loose, so ordered new rod bearings and will tighten them back to spec.
Old Aug 16, 2015 | 06:03 PM
  #410
Resmarted's Avatar
Resmarted
You're going to get arp rod bolts right?
Old Aug 16, 2015 | 11:16 PM
  #411
midz350's Avatar
midz350
I thought about going full build, but at this point Im done spending on this car and I just want to drive it at 500-600whp level.
Will do full overhaul. New bearings, gaskets, oil pump, piston rings, valve stem seals..etc.
The arp rod bolts would be useless with OEM rods IMO.
Old Aug 17, 2015 | 05:15 PM
  #412
Resmarted's Avatar
Resmarted
Oh if you're taking it all out you're fine. Some people like them so they have more insurance when revving higher, but if you get NEW toyota ones you'll be set.
I personally would just figure out the perfect ring clearances for the power level you want. I know 2jz's are fine stock block, but might as well do it right. Could be oem clearances, or might be just a bit bigger than oem.
Old Aug 18, 2015 | 09:45 AM
  #413
midz350's Avatar
midz350
The never ending project.
The crank and block need machining, so fwk it. Im going to build the short block.
Found a good deal for about $1900. Manley Rods, JE pistons, ARP head and main studs, timing belt, and bearings.
Old Aug 18, 2015 | 10:17 AM
  #414
Pengu's Avatar
Pengu
Sorry to hear that . Excited for the end results though.
Old Aug 18, 2015 | 03:49 PM
  #415
midz350's Avatar
midz350
Just bought a built short block for only $2400.
The cheapest 2jzgte short block you could ever find.
Old Aug 18, 2015 | 05:05 PM
  #416
Classy's Avatar
Classy
Lol, so much for finishing it!
Old Aug 18, 2015 | 10:39 PM
  #417
Resmarted's Avatar
Resmarted
My buddy bought a built block from someone online for a great price. That 2j **** it's self shortly after.
Didn't you have problems with your built vq35's? I'd be really weary.
Personally I'd probably go for a factory toyota new short block. They're about 3 grand. Titan sells them I believe. They're actually from toyota.
$2600, you'll pay a ton for shipping, but it's from toyota.
http://www.titanmotorsports.com/fatosh.html
Old Aug 18, 2015 | 11:08 PM
  #418
midz350's Avatar
midz350
This guy is known builder here and guaranteed it. He will start the engine after installation and test run it and offered to tune it for free just to make sure it's running flawlessly.
Here, they build 2JZ/RB engines in their sleeps.
Old Aug 19, 2015 | 11:34 PM
  #419
Resmarted's Avatar
Resmarted
Oh if its local to you thats totally different. I thought you were shipping it over there
Old Aug 21, 2015 | 01:28 PM
  #420
IanP's Avatar
IanP
Did you get the shifter relocater installed?
how was the fitment?
