Engine Swaps For all your engine swap experiences, ideas, questions, & more..
My 2JZ-GTE VVTI swap thread.
Old Jun 17, 2013 | 06:11 PM
  #141
kellam's Avatar
kellam
Very cool sir. So you installed first the engine using factory 2jz mounts and worked backwards?
Old Jun 17, 2013 | 08:07 PM
  #142
420og35's Avatar
420og35
so do you have to get a custom driveshaft if you shorten the shifter assembly???
Old Jun 18, 2013 | 02:50 AM
  #143
3fidzhr's Avatar
3fidzhr
Yes you need to take out 4.75 inches
Old Jun 18, 2013 | 08:29 AM
  #144
graffkid732's Avatar
graffkid732
Nice. Now the engine sits center in the bay? Have you or can you measure from the intake side to the strut tower and the exhaust side to the strut tower? If these work, then it shouldn't matter which trans you run. As long as the engine sits "properly", any trans will bolt to it and may need some trans tunnel massaging. Then from there a custom mount, shifter asy., and drive shaft.
Old Jun 18, 2013 | 11:47 AM
  #145
3fidzhr's Avatar
3fidzhr
As you prob already know the 350z crossmember is slotted so there is Room for side to side movement to get it perfect. As far as the tunnel it's a great fit.
Old Jun 18, 2013 | 12:35 PM
  #146
420og35's Avatar
420og35
so who are you using for the custom driveshaft?
also are you guys vvti? i heard that changes things too?
Old Jun 18, 2013 | 01:13 PM
  #147
midz350's Avatar
midz350
I sold the VVTI. I will use non VVTI.
Old Jun 18, 2013 | 03:12 PM
  #148
graffkid732
I'm non vvti
Old Jun 18, 2013 | 06:05 PM
  #149
420og35's Avatar
420og35
damn bc ive only been able to find vvti at a decent price the non is doubled. i think for the price ill just do cams and lifters or does it really make that much of a difference???
Old Jun 18, 2013 | 06:34 PM
  #150
midz350's Avatar
midz350
The problem with the vvti usually is finding an ECU that can run the vvti or make a special harness to use the AEM or other ones.
Old Jun 18, 2013 | 07:03 PM
  #151
420og35's Avatar
420og35
What about just changing cams and valves and lifters. Wouldn't that take vvti away???
Old Jun 18, 2013 | 07:38 PM
  #152
midz350's Avatar
midz350
But you have to machine the head then.
The best thing to do is change the head, harness and OEM ECU to a non vvti. Or just the head and get an aftermarket ECU and pick up a cheap OEM non vvti engine harness.
Old Jun 19, 2013 | 02:34 AM
  #153
kellam's Avatar
kellam
there are many options on ebay for non vvti in the 2200-2400 range.
Old Jun 19, 2013 | 07:14 AM
  #154
420og35's Avatar
420og35
can the harness be a 2jzge or does it have to be 2jzgte?
Old Jun 19, 2013 | 08:07 AM
  #155
3fidzhr's Avatar
3fidzhr
Has to be 2jzgte
Old Jun 19, 2013 | 08:12 AM
  #156
graffkid732
I would think GTE but not 100% sure. Honestly it wouldn't be much more expensive to have one made. If I remember correctly, a GTE harness is a few $100 used.
Old Jun 19, 2013 | 09:13 AM
  #157
midz350's Avatar
midz350
3fidzhr, what clutch/flywheel set up are you using?
Old Jun 19, 2013 | 09:57 AM
  #158
Resmarted's Avatar
Resmarted
Pretty sure you could buy a ge and convert the harness to gte.... But research that before you go with it; I'm not entirely sure.
All I would focus on with the harness/ecu is non vvti, and swap over to coil on plug.
Old Jun 19, 2013 | 01:22 PM
  #159
420og35's Avatar
420og35
How about running a vvti engine with a 2jzgte non vvti and aem v2 would that work
Old Jun 19, 2013 | 01:27 PM
  #160
420og35's Avatar
420og35
Does it have to be front or rear sump
