Airbag light
Removed the passenger side seat and installed it back. Now I have an airbag light that stays on. Is this related? Could I have instalkled something wrong?
I also removed the center console. Could this be the problem.
I was installing stereo equipment.
Thanks
Thanks
I have exact same problem also. I have 03 Touring with Power/Heated seat.
I removed center console and pass. seat and put all harnesses back but my air bag lights are on and driving me nuts. I may try to reset ecu tonight and will let you know what happends (if i do reset it). hang tight brother.
haha. that was simple and straight way to reset it i guess.
but after that, do you still have airbag lights on?
Originally Posted by 350xfire
We'll se e tomorrow. I just unhooked it today.
My Z is in the dealership now. They are installing Nismo clutch/flywheel and asked them to run some test. (86 dollars for the test!!!!) After I explained about air bag, they asked me if I upgrade audio system and I did install valentine One. They belive that run the test and reset Airbag computer. I will let you kow if it turns off or not.
Did either of you guys disconnect the battery before working on your cars? That seems to be a common problem in that if you disconnect some systems while power is still on at the ECU, then you will get a CEL thrown once you hook the systems back up.
here is the procedure..
ign off to ign on (ACC) wait 7 secs.. within 1 sec of the airbag light flashing turn off ign
wait at least 3 secs.. then repeat the above 3 more times (total of 3 or 4 times).
then just turn on and the airbag light will no longer flash
hey ,350xfire, can you try this tonight and let me know asap?
as you know my car is at the shop and they will run the test (at $86!!!!!).
if this works, I will call my dealer NOT to run the test.
Please let me know. Thanks!
(finger crossed...)
(finger crossed...)
(finger crossed...)
(finger crossed...)
Originally Posted by ether
here is the specifc procedure.. after the last step turn off the ign then turn on and the bag should be off if there is no failure in the airbag system
Thanks
