Fog light installation.
Old May 29, 2006 | 08:01 AM
Ruining's Avatar
Ruining
Default Fog light installation.
Okay, I know very little about structural integrity and crap.
I'm wanting to install some fog lights on the Z behind the grill because I do about 3-6 hours of night driving every weekend and I can't see crap when I turn my brights off.
Anyway. Can I drill into the aluminum bumper support to install the lights, or will that screw things up? I've searched and can't come up with anything. Thanks.
Old May 29, 2006 | 03:26 PM
overZealous1's Avatar
overZealous1
you should be fine to just put some screw holes in it.
Old May 31, 2006 | 05:43 AM
If you want functional fog lights, why install behind the grill?
Old May 31, 2006 | 08:03 AM
Ruining's Avatar
Ruining
I've read about having them installed behind the grill, and haven't heard anyone say it was a waste of time or anything. I have a baby on the way. I can't justify the cost of a new front bumper or having the stock one cut up right now, (though that would be ideal). I'll install them and hope for the best.
Old May 31, 2006 | 08:46 AM
sq40's Avatar
sq40
They do make those flat/thin ones that should fit through the slats.
http://www.piaa.com/Lamps/Lamp-pages/2100.html
Old May 31, 2006 | 09:44 AM
iceman21_23's Avatar
iceman21_23
if you cant see anything on the road, have u tried to adjust your headlights?
http://www.hypersprite.com/auto/tech-z-003/index.asp
Old May 31, 2006 | 10:18 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
This might help you out: http://www.3 50Z-tech.com/zwiki/Tuto...s_Installation
NOTE: Once you click on the above link, you must remove the space between the "3" and "50Z..." and then hit enter/go.
Old May 31, 2006 | 10:52 AM
Ruining's Avatar
Ruining
Thanks, guys.
Yeah, I've adjusted the headlights up and installed PIAA dims and brights. The headlights aren't giving me enough side vision since I live in an area with a LOT of deer. I've already run the wire into the car and all I have to do now is install the lamps.
I'll be getting it finished tomorrow when I make it to a lift at the shop.
BTW. If these don't work as well as I need, I'll try some of the narrow ones that work in between the slats.
Old May 31, 2006 | 12:55 PM
05-Z's Avatar
05-Z
I'm thinking about flush mounting driving lights into the bumper....possibly on either side of the grill.
Of coarse they would have to come with a bezel/trim ring or something.
Old Jun 1, 2006 | 06:01 AM
Ruining's Avatar
Ruining
I would really like to do that. I would want some of the larger lights for that. As it is, I'll just keep them behind the grill until I get some cash. I need a new front bumper anyway.
Old Jul 18, 2006 | 02:47 PM
mg350ZR's Avatar
mg350ZR
Default Fog/driving lights installed in outer grill?
Anybody install fog/driving lights into the outer grill area (in front of the black plastic pieces)?
I am considering doing such an installation using some 4" round lights with approximately 2.5" depth. I will likely have to cut out portions of the outer sections of the grill to allow the lights to fit better (don't like "behind the grill" look, even if the lights fit). If the portion of the grill that I cut out does not look right after I am done, I would have to get some kind of mesh over-grill (and possibly cut out round openings for the lights in it).
Anybody attempted this kind of fog/driving light installation on their Z?
Old Aug 29, 2006 | 02:42 AM
daequitz's Avatar
daequitz
I am considering doing such an installation using some 4" round lights with approximately 2.5" depth. I will likely have to cut out portions of the outer sections of the grill to allow the lights to fit better (don't like "behind the grill" look, even if the lights fit). If the portion of the grill that I cut out does not look right after I am done, I would have to get some kind of mesh overgrill (and possibly cut out round openings for the lights in it).
Wondering too?
Old Oct 28, 2006 | 03:51 PM
Amiricanmade's Avatar
Amiricanmade
anyone with any pictures of fog lights?
Old Oct 29, 2006 | 05:55 PM
05-Z's Avatar
05-Z
https://my350z.com/forum/showthread....ht=flush+mount
page 2 links to pics
Old Nov 1, 2006 | 11:40 AM
porschekiller's Avatar
porschekiller
I am also goingto install myself the flat type of fog/driveing light and all I don't really see is how to get my wireing through the firewall to my switch. Also Not to sure about getting my lower left side dash off to mount the switch in the blank switch hole. Does any one have any advise or tips they could throw my way?
Old Nov 1, 2006 | 03:38 PM
Cannysage's Avatar
Cannysage
raising the headlights helps quite a bit.. people think I have my highbeams on, and I only raised it, super tiny bit. I've installed Hella lights on my old 4runner and I think you'll have to drill holes on your bumper. xenon fogs are expensive, but gives you much nicer consistent beam.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
