installing racing harnesses
Old Oct 30, 2006 | 02:41 PM
itsjoshufocker's Avatar
itsjoshufocker
Default installing racing harnesses
so im putting in racing harnesses from hopupracing.com into my 300zx. and in just wondering, what are some ways you guys put in harnesses in the 350? i know that the shoulder support has to be at or above shoulder level... what did you guys do for this? does it require extensive fabrication for a bar? or are there any available prefabricated bars out there that just simply bolt onto the floor and side walls? thanks for anybody's help!
Old Oct 30, 2006 | 02:44 PM
THE TECH's Avatar
THE TECH
It will depend on how the harnesses that you bought mount to the vehicle.
Old Oct 30, 2006 | 02:52 PM
Vamos_Rafael's Avatar
Vamos_Rafael
my old set up ...
Old Oct 30, 2006 | 02:53 PM
THE TECH's Avatar
THE TECH
BTW, NEVER use harnesses without a cage.
Old Oct 30, 2006 | 02:54 PM
Vamos_Rafael
thats true if you are racing...
but for street set up... you are not pulling enough latteral forces in the corners to flip the car... (well unless you are seriously pushing it and suicidal)
a lot of the people with harness are doing it for show..
Old Oct 30, 2006 | 03:07 PM
josephchihweilu's Avatar
josephchihweilu
ive seen custom work where the harness is attached to the rear strut bar.
*for 350zs, forgot that you were talking about 300ZX
Last edited by josephchihweilu; Oct 30, 2006 at 03:08 PM. Reason: forgot original post
Old Oct 30, 2006 | 04:02 PM
itsjoshufocker
Vamos_Rafael did you just weld a bar into your side walls? thats what im thinking of doing too.. but just want to make sure that theres nothing easier than that to do..
Old Oct 30, 2006 | 04:10 PM
THE TECH's Avatar
THE TECH
Are you willing to bet your life on it? That's the real question. Yes, people will continue to do idiotic things no matter what, but some things just aren't worth it.
Old Oct 30, 2006 | 08:13 PM
RA11325's Avatar
RA11325
Then why do legit racing companies sell harness bars?
Old Oct 31, 2006 | 05:42 AM
THE TECH's Avatar
THE TECH
Just because someone sells a product, doesn't mean you shouldn't use your head before buying it.
Old Oct 31, 2006 | 09:21 AM
Acree's Avatar
Acree
Well maybe you could explain why you shouldn't use a harness without a full cage?
Personally, I don't see what's wrong as long as the mounting point for the shoulder bar is at the correct angle from shoulders. Please enlighten us.
-Acree
Old Oct 31, 2006 | 09:50 AM
THE TECH's Avatar
THE TECH
-Acree
The main reason that you don't use harnesses without a cage is that if the car were to turn over, you would be crushed because you would not be able to move out of the way. With the stock 3 point belts, you would still be able to move your shoulders and head. A cage makes sure that the roof of the car cannot be crushed and therefore come down on your head.
Old Oct 31, 2006 | 12:10 PM
Quamen's Avatar
Quamen
I see what your are saying. Basically, with how many four point harnesses are you only have neck movement as compared to 3-point stock which allows for more body movement also and is designed for more forward restraint than side-to-side.
Old Oct 31, 2006 | 02:10 PM
jakesford's Avatar
jakesford
it works both ways, you should never run a cage in a street car, unless you wear a helmet all the time.
Old Oct 31, 2006 | 04:07 PM
SmokyTyrz's Avatar
SmokyTyrz
+1
Old Oct 31, 2006 | 04:17 PM
Nitrouz's Avatar
Nitrouz
Back to Z
my old set up ...
I have the same bar now in my car.
Old Oct 31, 2006 | 04:21 PM
first350's Avatar
first350
4-point harnesses are also a no-no...they're no longer legal for racing organizations. The main reason is that under high decelleration (front impact crashes), a persons body can attempt to slip forward (under the belts) and crushes the internal organs, causing severe damage! Use 5 or 6 point harnesses.
Also, Harnesses aren't street legal (at least in Cali).
-Peter
Old Oct 31, 2006 | 07:08 PM
three_fitty's Avatar
three_fitty
Who makes that bar i want it.
Old Nov 3, 2006 | 09:43 PM
three_fitty
BUMP
HoBrahYouStink
Jun 24, 2016 10:58 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
