Z 06 tail lights used as turn signals?
Old Feb 4, 2007 | 12:06 PM
Shinin350z's Avatar
Shinin350z
Default Z 06 tail lights used as turn signals?
Last night I was behind an Infinity suv it had LED tails. When they went to turn on their turn signal it was the whole tail light that flashed. On my Z I wanted to make just the brake light flash instead of the lower turn signal. If I remove the bulb and run wire to splice into the brake light bulb will this cause a fuse to blow? I think it might look nice. Has anyone else done this? Thanks
Old Feb 4, 2007 | 12:16 PM
DIGItonium's Avatar
DIGItonium
You need to use 12V relays for the switching effect. Is it really worth it?
Old Feb 4, 2007 | 12:17 PM
playa6tnine's Avatar
playa6tnine
the newer muranos with LEDs do the same thing.
Old Feb 4, 2007 | 12:21 PM
Shinin350z's Avatar
Shinin350z
I just thought it would be different. I dont know if I'd do it for sure.
Old Feb 4, 2007 | 01:48 PM
jinsei888's Avatar
jinsei888
being different doesn't always equate to a "good idea"
then again you can try and innovate, just don't blow out your LED taillights during experimentation as they are not as simple as replacing little bulbs; if attempting to repair
Old Feb 4, 2007 | 03:41 PM
davidf's Avatar
davidf
I've had the same thought before, just don't know how to make it work.
Old Feb 4, 2007 | 04:35 PM
Voboy's Avatar
Voboy
Sounds like a good idea. I like it.
Old Feb 4, 2007 | 05:44 PM
bofa's Avatar
bofa
People have been doing it on motorcycles for the last few years. If you contact a manufacturer they may be willing to make a kit.
Here's one: http://www.customled.com/PRODUCTS/IN...ntegrators.htm
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
