Sponsored by:
Sponsored by:
Can Halogen Headlamps accomodate OEM HIDs?
Old 08-08-2008, 07:50 AM
Qwiksillva
Qwiksillva's Avatar
Default Can Halogen Headlamps accomodate OEM HIDs?
It's a pretty simple question. My current set of headlights on the Z look like crap because the lens is scratched up and starting to suffer from tiny stress cracks. I was wondering if I could buy like a cheap pair of headlights online and swap out the bulb and ballasts from my OEM pair into the halogen ones from online. Would that work? Please take into mind that I know nothing about lighting.
Old 08-08-2008, 07:52 AM
Z04
Z04's Avatar
a simple answer is no, it can not be done. just search and you will find other threads asking the same thing because some have tried this and basically got stuck with a crappy set of lights (or they bought first then asked). it has to do with the housings being completely different.
Old 08-08-2008, 07:55 AM
Qwiksillva
Qwiksillva's Avatar
Okay thanks. I looked and searched but did not see them. I'll look some more.
Old 08-08-2008, 07:56 AM
Z04
Z04's Avatar
you can also PM our resident light experts and ask them, i think they even tried and said it was not worth the effort
Old 08-08-2008, 08:00 AM
No.
Old 08-13-2008, 06:18 AM
Qwiksillva
Qwiksillva's Avatar
I guess I could always buy a pair and swap out just the lenses then?
Old 08-13-2008, 06:22 AM
savvy
savvy's Avatar
I have an 05 base model and swapped out the stock bulb for new HID bulbs and ballasts. I noticed a good improvement over stock, much brighter and clear at least.
2005daytonaZ
2005daytonaZ's Avatar
Im guessing you are talking about buying the OEM 03-05 base model lights which only came with the halogens? If so you can use the OEM HID's. I have done the swap on my base model along with plent others on this site and had wonderful results. No condensation inside the housing or anything like that and I've had the kit for almost 2 years now. PM the user JUN since i believe it was him that was selling the kits when I bought mine and get his input on the situation.
Hopefully I'm not off on your question but maybe this will help in some way.
Pleask
12-21-2021 03:17 PM
04-22-2021 09:42 PM
10-04-2015 07:55 PM
350z82
10-01-2015 06:25 PM
Quick Reply: Can Halogen Headlamps accomodate OEM HIDs?
