Question about Nav Cubbies (not the usual)
Old Dec 25, 2008 | 06:38 AM
rotarynemesis's Avatar
rotarynemesis
Question Question about Nav Cubbies (not the usual)
Ok so I did a search and could not come up with what I was looking for however I did find this and thought it would help.
First off I have a 2005 350z touring with out navi.
What I am wanting to do is hopefully get the 2007 center nav piece with no door and put an aftermarket nav in there.
My question is does anyone know if the 2007 center cubby dash piece will fit into the 05?
This is all I found in my search.
Originally Posted by BhashaZ
Yup. Like I said, if you have factory nav on an 04 or 05, you have power retractable nav cover. But you can retrofit an 03 manually retractable cubby into an 04 or 05 and it will fit, but the 03 was dark grey in color, while 04+ are black.
Here's a summary:
2003:
Non-Nav: manual and retracts into dash
2004-2005:
Non-Nav: manual and flips up
Nav: powered and retracts into dash
2006-2007 (new dash style):
Nav: No nav cover at all*
*I believe some early 2006 models had powered and retractable covers like the 04 and 05 Nav models, but they discontinued them for some reason
Old Dec 25, 2008 | 07:29 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Nissan redesigned the entire waterfall IP for the '06-08 models. None of the trim pieces (including 2-DIN headunit or cubby) have the correct dimensions to fit from an '03-05 to an '06-08 IP.In order the refit your '05 with an '06-08 cubby, you'd need the entire center stack- including the console and plastic trim areas around it. This kind of interior swap was detailed in a past issue of Nissan Sport Magazine with the 350Z street project.
A much more cost-effective route would be to simply remove, or modify your existing cubby and spend time and $$ on mounting the nav unit.
Old Dec 25, 2008 | 07:54 AM
datsunHEAD's Avatar
datsunHEAD
check out the audio section of the forums they know there sh*t
issyz
Jul 2, 2017 03:04 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
