HID vs Non HID
Old Jan 27, 2009 | 01:30 PM
PRuane's Avatar
PRuane
Default HID vs Non HID
How can you tell the difference? Is it the color, I mean obviously the bulbs are different but from the pictures I've looked at the headlight housing and everything inside looks exactly the same.
I think my headlights are HID's... but I'm not sure. I'll put a picture up in a few, I'll need to go take one.
Old Jan 27, 2009 | 01:33 PM
burner's Avatar
burner
If your Z is anything but a base, it has HID's. If its a base, it has halogen headlights. The case is exactly the same.
Old Jan 27, 2009 | 01:51 PM
PRuane's Avatar
PRuane
The one wouldn't attach.
Old Jan 27, 2009 | 01:55 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You have HIDs.
The 03-05 base models had halogen lights. All other models and other years have HIDs.
Old Jan 27, 2009 | 02:01 PM
PRuane's Avatar
PRuane
Okay thanks, I thought I had HID's but I've never seen two Z's one with HID's one with Halogen, so I couldn't tell the difference.
Old Jan 29, 2009 | 10:19 AM
gyotar's Avatar
gyotar
Are the HID and Halogen headlight different? Not the bulbs but the headlights themselves. Could you swap halogens into a HID housing of you took the ballast out of the equation?
Old Jan 29, 2009 | 10:24 AM
Spork's Avatar
Spork
The base of the bulbs are different.
Old Jan 29, 2009 | 10:30 AM
gyotar's Avatar
gyotar
So the housings are different then? You can't plug a HID bulb into a Halogen connector?
Old Jan 29, 2009 | 10:41 AM
cgy350z's Avatar
cgy350z
Sure you can put HIDs into a Halogen housing...it just looks bad and you will blind anyone in front of you.
They make HID kits that have the HID "bulb" on the Halogen base that twists into the Halogen housing. But because Halogen housings have no cut off like the HID projectiong housing does the light goes everywhere, including up into the faces of people in front of you.
Old Jan 29, 2009 | 10:48 AM
gyotar's Avatar
gyotar
Thanks
Old Jan 29, 2009 | 10:50 AM
35oZephyR's Avatar
35oZephyR
The housing looks the same for 03-04 HID/halogen owners. Some base owners, such as myself, have retro-fitted/installed HID harness/ballast/and bulbs.
Biggest ringer is when you first turn them on. They should be a darker blue/ purplish color and then charge up to a bright white.
Old Jan 29, 2009 | 10:57 AM
gyotar's Avatar
gyotar
What happened is I have an 03 Touring that for some reason has Halogen headlights...I have Leather/Bose/TDS/VDC/Cruise Control so it's for sure I don't have a base but I'm sure the previous owner must have swapped out the HID's...not sure why. So going on that assumption I bought some bulbs that obviously didn't fit into the halogen fixture. Now I need to sell them but no one is interested...
Old Jan 29, 2009 | 01:48 PM
~SpInNeY~'s Avatar
~SpInNeY~
Old Jan 29, 2009 | 03:01 PM
Spork's Avatar
Spork
HIDs have a "charge-up" period when first turned on. You'll notice them flash on bright, get dim, and progressively get brighter. This happens within the first 5 seconds of light startup.
Old Jan 29, 2009 | 04:57 PM
Get_Zwole's Avatar
Get_Zwole
yeah the Z were my first set of hid's i thought it was awesome when they did that haha.
Old Feb 27, 2009 | 10:27 AM
Master Shake's Avatar
Master Shake
Do the halogens also have the projector lens?
Pleask
Dec 21, 2021 03:17 PM
Fall-Line
Apr 9, 2003 03:56 AM
Daddy
Feb 4, 2003 11:13 AM
mikeyngo
Nov 20, 2002 10:52 PM
dvlad
Sep 15, 2002 07:48 PM
