New 2006+ tail lights: Installation help please!
Old Oct 23, 2011 | 01:14 PM
axial_pro's Avatar
axial_pro
Default New 2006+ tail lights: Installation help please!
I had figured that I would be able to find an answer to this using the search function, but it was not to be.
Just bought some new-to-me 06+ LED tail lights.
Removal if the original lights went fine, but the connectors for the new lights don't fit. They are the same design but are vertically inverted. See pics to make this clear.
How can I fix this? I could just take a utility knife and trim my factory connector. Any other ideas?
Thanks
Attached Thumbnails New 2006+ tail lights: Installation help please!-2011-10-23_13-08-29_892-1.jpg
Old Oct 23, 2011 | 02:30 PM
cgkp0925's Avatar
cgkp0925
Yup, that's what I had to do. I thought why the hell did they do that. use a utility knife and then sand.
enjoy the LEDs!
Old Oct 23, 2011 | 02:41 PM
beezee's Avatar
beezee
I am getting one of these soon so I guess I can steal some help here. So what are you trimming?. Thanks
Old Oct 23, 2011 | 05:14 PM
cgkp0925's Avatar
cgkp0925
if you look at the provided image, you can see the slots where the tail light plug "should" slide into. but the plug's extensions are inverted, so it will not slide in at all.
I can't remember exactly but I believe I shaved off all of the extensions except for the bottom extensions since they fit. it's okay to shave them off since the plug snaps into place on the bottom.
my LEDs have worked great ever since I installed them back in July.
Old Oct 23, 2011 | 05:37 PM
axial_pro's Avatar
axial_pro
Resolved.
Took a utility knife to all of the ribs on the white connector pictured above (except for the snap-in connector at the left in the pic).
With careful trimming, no sanding or other mods were required. I used electrical tape to completely seal up all connectors to the light. Not necessary - especially as my car never even sees rain - but it also helps the mechanical connection. Sure can't hurt!
Old Oct 23, 2011 | 05:41 PM
cgkp0925's Avatar
cgkp0925
Originally Posted by axial_pro
Resolved.
Took a utility knife to all of the ribs on the white connector pictured above. With careful trimming no sanding or other mods were required. I used electrical tape to completely seal up all connectors to the light. Not necessary - especially as my car never even sees rain - but it also helps the mechanical connection. Sure can't hurt!
yes, sanding is optional. just makes for a cleaner appearance, but no one will see it anyways.
Old Oct 23, 2011 | 05:43 PM
Waiz's Avatar
Waiz
That's weird, I don't remember having to do this to my lights.
What year is your Z OP?
Old Oct 23, 2011 | 05:49 PM
axial_pro's Avatar
axial_pro
Old Oct 23, 2011 | 06:18 PM
beezee's Avatar
beezee
Oh Ok. I see it now. Thanks. I have an 05 and I will look out for that.
Old Oct 24, 2011 | 05:10 AM
cgkp0925's Avatar
cgkp0925
2003
as is mine. it must just be the 2003 model that the plugs were designed like this.
Old Oct 24, 2011 | 09:22 AM
sluggoZ's Avatar
sluggoZ
correct, only the '03's....I have a '04 with no problems.
The JDM '06 + tails do need some trim work.
Old Oct 24, 2011 | 01:47 PM
bbs350z's Avatar
bbs350z
^i have 03 and mine went in no problems from an 08
Old Oct 24, 2011 | 04:18 PM
Done Deal DR's Avatar
Done Deal DR
Yep, I have an 04.5 and had no issues mounting 06+ OEM LED tails.
Old Oct 25, 2011 | 04:23 AM
cgkp0925's Avatar
cgkp0925
hmmm maybe it was the earlier '03 models? my sticker says it was manufactured in August 2002.
Old Apr 29, 2012 | 04:23 AM
pduong0726's Avatar
pduong0726
Hi everyone. I really need help on this. The previous owner of my car has cut off the connectors that plugs right into the lamp. Now that I don't have connectors but a bunch of wires twisted and taped to the wires of the altezza tail lights (dislike it -_-). Currently, I have bought a pair of oem led tail light, I need some suggestions on where to buy these connectors. Been searching for them but never found one.
Thanks in advance
350z82
Oct 1, 2015 06:25 PM
